ABS failure
Discussion in 'Gen 3 Prius Technical Discussion' started by Imran Toor, Jan 9, 2020.
  1. Imran Toor
    Imran Toor New Member
    Lahore
    One month before I had issue with my ABS brakes. Now four lights are on includes Traction & brakes. Before that I noticed fluid whistling sound while pressing brake at stop position. Brake fluid is also less from low level position. After having fluid to upper level, some times these lights disappears. When it disappears the abs works as normal, but the whistling sound again comes on pressing brake at stop position. I want to know the possible cause of problem. Is it some brake fluid service or anything else..
    51,028
    welcome!
    you may need a new brake actuator, but it's hard to say without reading the trouble codes
  3. Eddie25
    Eddie25 Active Member
    483
    203
    MI
    Sounds like you are leaking brake fluid. See if you can find where it's leaking from.
  4. ChapmanF
    17,186
    I'm with bisco: easier to help if you post the trouble codes.
  5. Imran Toor
    Lahore
    C1391 is the code
  6. Imran Toor
    Lahore
    No leakage observed
  7. bisco
    51,028
    see this thread: 'Error code C1391'
  8. ChapmanF
    17,186
    The C1391 is a report of pressure leakage, so leakage has been observed, just not by you. :) The leakage can be (and often is) internal, so no brake fluid ever leaves the car, just finds its way back to the reservoir.
    In a Gen 3, there are two different assemblies where such leakage could be happening: either the "booster assembly with master cylinder (includes actuator)", or the "pump assembly, brake booster" (also known as the accumulator). Neither one is a picnic to replace, so if you have a way (if it's leaking fast enough, a mechanic's stethoscope might work) to determine which assembly you need, that could save some time and money.
  9. Mendel Leisk
    40,472
    Found this salted away, a custom instruction for replacement of the lower component. The earlier instruction, in the Repair Manual, says to remove the full lower rear support beam, and I guess the dealership mechanics revolted.
    #9 Mendel Leisk, Jan 11, 2020
  10. Mendel Leisk
    40,472
