Are people really getting 40+ MPG in Gen 2?
Discussion in 'Gen 2 Prius Fuel Economy' started by timmyjane, Apr 12, 2017.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Oh wow glad you got to enjoy the area! It’s a very pretty place. Always love cursing the country roads around here
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    That looks like the kind of typo I tend to make. :ROFLMAO::ROFLMAO::ROFLMAO: I once left the "f" out of "shift" on a motorcycle forum.
    Anyway, I love those curving rolling hills. Just totally relaxing. It's the roads here in the Tampa area that I actually curse. :D
    Aaron Vitolins likes this.
  3. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Hahaha that’s too funny! yes it’s definitely a typo, even though I do love cursing :)
  4. fuzzy1
    10,412
    A long ago, somebody at Corporate left the "f" out of "shift register" on the descriptions that were automatically filled in on our material lists. It took a while to convince my very straight-laced boss that I didn't write those descriptions, they were force-fed from some new process pushed on us from above.
    #324 fuzzy1, Nov 22, 2020
  5. stylinnnn
    stylinnnn Junior Member
    36
    san diego
    Many folks get 50 mpg plus.
  6. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,280
    I find I'm getting anywhere between 20mpg and 60mpg all depending on how and where I drive it. Pulse and glide over long distances really increases the fuel mileage. Driving short trips starting with a frozen sub zero engine through slush and snow with studded snow tires and tire chains and heater on full blast really decreases fuel mileage.
    audiodave and Data Daedalus like this.
  7. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    I’m a sr citizen and not in a hurry.
    My ‘06 consistently lists 45.1-45.6 mpg on the consumption screen.
    I only reset if I’m required (battery disconnect, maintenance)
    It seems to me that the CA fuel is mainly responsible for the mileage drop.
    Although I used to coast & glide like a madman years ago to increase mpg. Most of the time, back then, from 2008-2014 my consumption screen was in the 48mpg range
    Now I just drive slowly mostly, no longer in a hurry.
    My wife, on the other hand, has an ‘09
    She sits in parking lots with the air conditioner on.
    Starts it in the morning when it’s cold, and sits in the driveway for 5min or longer.
    So her screen consistently reads 42-43 mpg
  8. Isaac Zachary
    2,541
    1,280
    Sounds like my wife.
    Data Daedalus likes this.
  9. caliwaves
    caliwaves Member
    65
    33
    TX
    Drove 1500+ miles over the last few days // ~75mph on cruise and averaging 43mpg
    2006 prius @ 148k miles
  10. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    That's about where ours has been on our multi-state trips since we bought the car almost 5 years ago.
  11. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Are you guys using the screen readout for mpg or calculating it? If calculating, doesn't the silly fuel bladder give inconsistent readings? I've had the Prius for a few years now and I don't think the bladder has ever been completely full.
  12. jerrymildred
    11,517
    14,148
    Tampa, FL
    Indeed it does. But they average out. If you put in less one time, you would probably put in more the next time. The averages tend to be just a few mpg less than the readout, which is also true in Gen 3 and Gen 4 but it sure is nice to be rid of that stinkin' bladder.
  13. Isaac Zachary
    2,541
    1,280
    I think I already said this, but I calculated the hybrid Avalon's fuel mileage for a year and got exactly the same reading the dash did.
  14. lpf
    lpf Member
    137
    39
    Greece
    I always trust what the pump says. Usually it is 0,1 or 0,2 litres more than the car's reading. So when I have a reading of 5,2l/100km I expect 5,4 litres of real consumption.
  15. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    2009 —-74,000 mi —-47+ mpg measured
    2013—-77,000 mi ——47+ mpg
    Both measured manually not display estimates.
    Isaac Zachary likes this.
  16. Jamez P
    Jamez P Junior Member
    34
    Brownsville Oregon
    My 06' has nearly 300k and I can get 50ish mpg out of it usually. I run Chevron regular and just do the speed limit...mostly ;)
    caliwaves likes this.
  17. bisco
    51,851
    excellent!(y)
    Jamez P likes this.
  18. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    2004 still has it! Even though today is warm in the 50s this week has mostly been colder in the 30s-40s here in Nashville.
  19. Smw013
    Smw013 New Member
    Ohio
    My 2007 is only getting 18 miles per gallon. Drives fine but I should have just bought an SUV.
  20. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    I highly doubt that, unless there is black smoke from the tailpipe, dragging brakes or nearly flat tires.
