Inverter: How much power? and how?
Discussion in 'Gen 3 Prius Audio and Electronics' started by andreimontreal, Dec 10, 2020.
  1. andreimontreal
    andreimontreal Active Member
    380
    118
    37
    Montreal
    I remember reading years ago about this guy in FL powering a house from an inverter hooked to his Prius. He had maybe 1500-2000 Watts (?) ottomh. What's the maximum pure sine (I understand this is the best?) inverter I can attach to my main battery?
    I'm working on a Prius camper-hatch project. If you know of a good tutorial on how to do this, hook me up. I'm on it too.
    Andrei
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,950
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Andrei,
    Please be careful as the battery voltage can kill. Make certain that you have the skills (or learn them) to deal safely with high voltages before starting this project.
    JeffD
    andreimontreal and Raytheeagle like this.
  3. ChapmanF
    18,560
    Up to around 1000 watts, connection to the 12 volt aux battery is practical, and those inverters are common and easy to get. I've seen people push that and put a 1500 or even 2000 watt inverter there, though they are unlikely ever to get that much out of the car's 12 volt system. Sometimes it's just because they got a good deal on that inverter.
    For attaching to the traction battery, there's a lot more power available, but that's a much less cookie-cutter procedure. Inverters that can handle that input voltage are harder to find, and designing a safe way to cable one in is more challenging. The original iteration of Randy Bryan's inverter business sold 2000, 3000, and 5000 options. 5000 watts is less than 25 amps from a 202 volt battery, so even that's no sweat for the car, but those inverters are chunky.
    Randy's current business sells (newer, different) 3000 and 5000 options, but I can't find very much about them on the web site. There was a recent PriusChat post by someone who had bought one, if you can find it. Had pictures. Not a small package.
    andreimontreal likes this.
  4. andreimontreal
    380
    118
    37
    Montreal
    @jdenenberg : Thanks for the concerns Jeff. I've recently done 110V work at my folks house and no issues. I got enough knowledge not to hurt my self, been playing with electricity since I was a kid so I should be good. Besides, by the time I do something, I hope I'd learn what is what - I don't tend to go in blind doing anything.
    @ChapmanF : I think I'd want to do it on the trac battery and I imagine it will take some improvised bolt on heavy duty connection like in a home electrical panel. For size, if we're talking roughly 4x10x20 inches like this 3000W AIMS, then I should be o-k. Yes, it's a bit big. Electricity is a must so I'll have to make/find room for it - I'll find a way 100%, I'm cutting plywood sheets now making this interior furniture covering the whole interior save for the diver's seat. This will be my mini Millennium Falcon on wheels.
    Is that what the traction battery is 202V? That's how green I am, didn't even open it to read it with a multimeter. I think I should be good with 3000W (I'd buy 5000W maybe just for a good safety margin if I ever want to help a stranded house during an emergency - or literally something along the lines of) - the lowest I'd go is 2000W ( I would have appliances of 1500-1600W running for 1-5 min if needed, on at a time) .
    What's the max amperage the trac battery can put out? Since you mention it, I wonder.
    Andrei
  5. ChapmanF
    18,560
    It's 202 volts nominal—that is, 28 modules ✕ 6 cells/module ✕ NiMH nominal 1.2 V/cell, 201.6. Keep in mind that when charging, that can rise to 1.6 per cell or so, therefore anything you connect had better be comfortable to at least 270 volts input.
    The car will happily use up to 100 amps or a bit more, in or out, in normal operation. Lay a metal tool across the terminals inadvertently and you'll find out what the real max is it can put out, and you won't like it. There's a fuse built into the service plug, so you could look at that for the actual max-that-won't-blow-the-fuse.
    Here's hobbit testing one of Randy's earlier 3000W offerings, after removing the casters from the bottom to reduce the height a bit.
    #5 ChapmanF, Dec 10, 2020
  6. andreimontreal
    380
    118
    37
    Montreal
    I found a how to for connecting an inverter to the trac battery . Some details in the comments but no inverter model; PSA: get proper wire gauge . The idea is simple, finding the unit is another story.
    @ChapmanF How do I determine if an inverter is comfortable at 270v, it's in the specs, right? It should have a min/max? If it says just 220 VDC, should I assume it has a range? Looking at that AIMS unit, I see that it's rated for 9.5-16 V DC. Most of what they have there is 12-48vdc. Why am I starting to get this feeling that what I need is not that common. Looking around there's no clear answer for 220 VDC to 110VAC units. (Edit: found some China stuff 220 vdc to 110vac - if units like that are slim like that, then I'm in business big time, just need something reliable Edit2 : found this inverter rated 200-247 VDC for input, so that kinda answers something)
    Randy's setup pic shook me well :confused:. Is that what it takes to do 220VDC to 110V AC, nothing else smaller?
    Would a 220vdc to 12vdc transformer hooked to a low voltage inverter (like the AIMS above) work? Thinking out loud.
    (Another idea, as a last minute back-up - get some batteries, charge those of 12V slowly, then use a low voltage inverter.)
    Andre
    #6 andreimontreal, Dec 10, 2020
  7. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    What you want is not common at all, and that specific availability is (probably) what gave rise to the Converdant business model.
    If an inverter's data sheet specifies x volts input, there is a range, but it will have limits and you cannot expect identical behavior at or beyond limits from different devices. This makes system design a bit of a challenge. Charger X may need to take the system up to 285 volts for its daily test program while inverter y may go into safety shutdown if it ever sees a peak above 279 volts. The numbers are made up to illustrate the point. You get to navigate a lot of awesome things like that.
    There is safety in numbers. I don't mean the inherently safer low voltage of 12v, I mean there's way, way more automotive & alt energy hobbyists working with 12v systems. Many more problem-solving parts and a lot more experience to draw on.
    You can get much more compact inverters in the "popular" DC voltage ranges. I suspect the converdant ones are that large because the expected sales volume meant using off-the-shelf casing and components rather than optimally sized items.
    Consider the demand side before you commit to building a huge system. What's going to draw all this power, and is there a smarter way to do reach the end goal?
    Minima Domum and andreimontreal like this.
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    For camping trips, traction battery connected inverters are overkill. How much electric load are you needing to run? Do some math and if your need is less than say 1.5Kw, then the 12v system may be far easier and cheaper.
    Randy's PLUGOUT POWER, LLC (formerly known as ConVerdant Vehicles) has a 3kW and a 5kW system for sale now. But they are more for running a whole house as a back-up generator. The system is not portable size at all. See my photo and comment in the thread linked below as well as attached sales docs from PlugOut I got from my recent visit with Randy. In the end, the price tag was too high for the smallish power I get from it as a back-up generator, I decided not to get it.
    Prius Whole house Converdant Inverter | Page 3 | PriusChat
    #8 Salamander_King, Dec 11, 2020
    andreimontreal and jdenenberg like this.
  9. ChapmanF
    18,560
    The bad news is transformers depend on Faraday's law, which says the voltage induced by a magnetic field depends on the rate of change of the field, so the field has to be constantly changing for the transformer to work, so a transformer has to be fed AC, and it produces AC. A transformer connected to DC is just a space heater that you might also be able to pick up nails with if you spilled a box.
    To get one DC voltage to a different DC voltage you need not a transformer but a converter. You've got one of those under the hood already, taking the traction battery voltage down to 12, but as mentioned elsewhere that one's only sized for around 1000 watts.
    The insides of a converter are pretty much the same as the insides of an inverter. It needs to take the DC input, make a changing waveform out of it, and get (by a transformer or otherwise) a waveform around the desired output voltage from that. It doesn't need the parts of an inverter that shape the output into beautiful sine waves; instead of those, it just needs to rectify and smooth the output back into DC.
    Needless to say, using a converter to change the DC input voltage to an inverter would make Rube Goldberg proud.
    Another and andreimontreal like this.
  10. jdenenberg
    3,953
    1,950
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Andrei,
    I am fully capable to install a HV connected AC inverter, but have an 8 kw ICE driven generator to handle my emergency electrical needs at home (except the air conditioner) and use a 12v inverter on the road as those needs are normally lower wattage. I agree with the Salamander_King.
    JeffD
  11. rjparker
    10,535
    6,616
    Interesting, just yesterday you were super confident but today not so much. The reality is "playing with electricity" is different than throwing together parts to take high voltage dc to clean sine wave ac voltage. Even Toyota did not have reliable high power mobile inverters until about 2016. Plus, the Toyota inverter requires active liquid cooling. All electrical conversions lose energy as heat. High power means high waste heat loads.
    If you are a well capitalized entrepreneur, you hire an experienced design contractor and eventually you get there. Or you buy someone else's prototype. For cost effectiveness, a 1000 watt inverter running off a paralleled Prius 12v battery would be my choice. Even then the Prius will be starting up many times an hour at a louder db than a decent Honda inverter generator.
    For whole house backup I would use a 14kw LP or Natural gas generator and transfer switch.
    Often we "don't know what we don't know" and as a result, don't know the questions to ask and are not well equipped to make good value judgements. Yes, anything can be prototyped and used for a variable amount of time. But it might cost five times more than a quiet Honda inverter generator and the Honda won't fry your loads and perhaps your Prius.
    #11 rjparker, Dec 11, 2020
  12. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I agree on all points and suggestions. But this person is either going big or go home, and he ain’t going home.
  13. andreimontreal
    380
    118
    37
    Montreal
    Looking around I've seen that the range is specified clearly; this Canadian unit went from 200-279 or something like that ottomh. Anything over and it shuts down. The cheaper Chinese units are under 250V, 200-250 ish.
    Just confident I won't kill my self - because that was his concern. I'm still confident I won't kill my self: no worries.
    @Grit - without your input I think I'd lose my self ...
    I didn't get what Chap was saying initially. Overall, after looking, I do realize now that 200+VDC inverters are not practical solutions price/size wise. Just like @Leadfoot J. McCoalroller says, the lower voltage market is way more developed and practical - I'm facing the reality. The only unit that went over 270 vdc like @ChapmanF advises, is a bulky 3500$ unit in Canada that barely puts out 1500W. So no, even I'm not crazy enough to entertain that. I would need roughly 1600 Watts of power for a brief time 1-5 min; once or twice daily (blender etc).
    And I'm starting to think the solution with batteries charging at 12V, is the idea to go with. I wanted some V-mount batteries for cine/photo work. Looking at BH, I see that I'd have 90-100 Wh per battery so one battery should run 1600W for about 28min - if my math is right - more than enough.
    Andrei
  14. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    If they can handle that kind of discharge rate. Just because the energy is in there doesn't mean you can get it all out on the schedule you're hoping for. I'm not familiar with any photo or cine batteries that would handle this load gracefully.
    Run an extension cord out to the car and cook in it for a weekend on shore power and ask yourself if you're really going to keep that up for long. There are some innovative and useful ways to heat at least certain foods in a car and many of them don't use much electricity. Crockpots and warmer ovens are cheap and easy to live with.
    The amount of power needed to run a blender and to heat wash water to sanitize it is a really serious commitment energy wise.
  15. rjparker
    10,535
    6,616
    I believe those batteries are 6.6ah.
  16. ChapmanF
    18,560
    I'm a deliriously satisfied Instant Pot customer, and the three-quart models pull 700 watts.
  17. andreimontreal
    380
    118
    37
    Montreal
    Right! I was looking into this - seemed a bit to extreme in my head too, straight up murder, but I first hope and then despair - in that order. My two top power uses would be a hair dryer and a Blendtec blender. Normally these two take on average 1600W. For cooking I have an adventure multi-fuel gas stove (Optimus Polaris). It crossed my mind I could find lower power units, something which operates under 1000 watts and call it a day like everybody else - something like a mini bullet and a mini hair dryer. (I'm going home @Grit ... maybe)
    Now, do you know of any batteries which can take that kind of a discharge rate? At least to know what it takes. Ottomh, I've seen vanlife ppl use Blendtec/Vitamix off batteries+inverter so there's got to be something. How is this capacity measured?
    Yeah, 6.8 Ah .
  18. rjparker
    10,535
    6,616
    I think you are on the right track now but those 100wh / 6.8 amp hour batteries won't run a 1500w inverter at any kind of load. An inverter that big needs at least 125 amps of 12v at full load. If the Prius 201v to 12v dc to dc is used it is fused at 125 amp 12v current. The car needs 12v power to operate so most suggest limiting an external inverter to about 1000w which is still over 85 amps at full load.
    To handle short term high current a decent solution is to add a high amp hour agm with proper isolation to protect the 40ah hour 12v car battery. A 100ah battery can drive a 1500w inverter for 30-60 minutes at full load, much longer at part load. Most of the equipment can be found at off grid suppliers.
    #18 rjparker, Dec 12, 2020
  19. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Yes, it can absolutely be done. An AGM battery similar to the 12v Prius battery would be a good starting point. I'd probably go larger to gain access to more commonly available and possibly cheaper (by the w/hr) sizes with deeper reserves.
    That load is going to be described in amps. A common storebought inverter is likely to deliver 80% efficiency. While handling the start surge of a blender labeled as "1600w" it will probably tax the battery for ~230 amps at first, falling to 150 or so once it gets up to speed. That's somewhere between "motorcycle starting" and "car starting" kinds of electrical demand, so it should give you an idea of the battery needed to back it. You'll probably run the blender longer than you would need to start a car engine, so think about that too.
    Then you need to choose whether you drive the inverter from the built-in 12v battery, or add a second one with its own charging scheme.
  20. andreimontreal
    380
    118
    37
    Montreal
    That right there is something that was on my mind. It is only logical, am aware that it would start using the car battery if just simply connected on it and I was thinking of checking how vanlife ppl set-up their batteries. I'll def look into it and if you have time and don't mind drop some lines regarding proper procedure for proper isolation - some terms, details might help with research. So to recap what I understand by the end goal: permanently have the large utility battery connected, when the car is running it gets charged as well, and when the car is off, the 12v Prius battery can't be used in this circuit but you can run the utility battery until it's drained.
    The AGM battery+pure sine inverter seems to be the tried and tested campervan/boating method. It's been on my mind for sure. First I wanna see how my things (water system, cooking utensils and surfboards - that's the whole point surboards!) fit in there and probably will assess just how insane is my ambition after I get a taste of life like that (and to think I am considering a 20-30L Dometic in there too ... this would be the most insane tiny travel project if I can make it work smoothly :cool: ).
    Thanks guys, every bit helps as it puts me on track and speeds up the research process.
