How to open hood with a dead battery?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by James Cooper, Dec 7, 2022.
  1. James Cooper
    James Cooper Junior Member
    Las Vegas, NV
    I have a 2017 Prius Prime Premium and the battery died this morning. I have searched the internet including You Tube on how to open the hood with a dead battery. I even called Toyota service on an 800 number and they said there is not a second way to open the hood when the battery is dead.
    It seems like a stupid idea for the hood latch to need battery power to open.
    Does anyone have any ideas before I call a tow truck and have it taken to a dealership?
    RoadPoppy likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    best chance is to look up 'battery' in the index of the owners manual.
    The 2017 Prius Prime owners manual says to go to page 694 for a dead battery
    It says to open the hood using the lever under the dash. A prime "premium" is differrent? If so, maybe your prime manual has better info
    2017 Toyota Prius Prime owners manual - OwnersMan
    #2 TMR-JWAP, Dec 7, 2022
  3. bisco
    51,839
    Just open the drivers door with the mechanical key, and pop the hood
  4. ETC(SS)
    7,133
    Yeah.
    University of Youtube.
  5. Mendel Leisk
    41,302
    Did they tell you the first way:
    Confession: first time I changed transmission fluid, on an 81 Civic, I was stymied by the socket0head cap screw style drain bolt. Basically a round headed bolt with a square recess on the head.
    Phoned the dealership to ask if they had a special tool for that. They guy that took my call checked with their mechanics, came back saying "they just use a 3/8" drive ratchet wrench, fit's the square pocket on the bolt".
  6. bisco
    51,839
    The hood latch does not need battery power
  7. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    It would certainly make for a crappy day if the hood release cable was broken..............
  8. Mendel Leisk
    41,302
    It's only a matter of time though... Parking brake went electric on 5th gen.
    #8 Mendel Leisk, Dec 7, 2022
  9. rjparker
    10,074
    6,239
    Our crv with electric parking brakes slammed on with my wife driving 60 mph. She left rear wheel skid marks but was able to overpower it with the fwd turbo. Hours later a tow truck took it 60 miles to the dealer.
    But she knows how to jump it or the Prius with the lithium jump box under the seat. Even if its locked.
  10. James Cooper
    Las Vegas, NV
    Before when I blew a fuse on power outlet 1 the hood wouldn't open, the fuse is ok. The car is not locked and pulling on the hood release does nothing as there is no resistance. I need to find a different way of opening the hood.
    I cannot pop the hood. Toyota even said that there needs to be power to open the hood.
  11. James Cooper
    Las Vegas, NV
    The cable isn't broken, the car needs electricity to open.
  12. James Cooper
    Las Vegas, NV
    Yes it does need power. Don't believe me? Call Toyota at 800-331-4331 and they will tell you what they told me.
  13. ChapmanF
    18,062
  14. ETC(SS)
    7,133
    Of course they did!
    Did they also tell you that you have to have maintenance done at the dealership or it will void your warranty?
  15. James Cooper
    Las Vegas, NV
    Thank you but it doesn't work. The cable isn't broken. Once before I blew the fuse to power outlet 1 and the hood wouldn't open because the fuse was blown. I changed the fuse and then the hood latch worked again. Now, with no power, the hood latch isn't working. I need another way to open the hood. Pulling the latch is like pulling the air, there is no resistance.
  16. Mendel Leisk
    41,302
    Sounds like broken/disconnected, mechanical cable. I know, we might all be wrong. Anyway, attached is from 4th gen Repair Manual. Unless there's something tricky with the Prime.
  17. rjparker
    10,074
    6,239
    The owners manual for a 2017 Prime says in order to jump it when you have a dead 12v battery you open the door and pop the hood. Without power. So if it does not work there must be something disconnected or jammed.
    5697BCF3-0B31-4E62-893B-3FA7A3EFCF89.jpeg 55D42CC0-16B8-469D-BF31-DECA54323EBC.jpeg
    #17 rjparker, Dec 7, 2022
  18. Leadfoot J. McCoalroller
    8,068
    7,552
    Pennsylvania
    2018 Prius c
    Has somebody already pulled the hood release? That would make a subsequent pull feel like "pulling on air."
    Maybe it's worth checking to see if the latch has already been released and the hood is just being held down by the auxiliary catch lever, the one you push out of the way with your finger.
  19. bisco
    51,839
    odd, with all the dead prime batteries we've seen, no one has ever reported not being able to pop the hood.
    and odd that not one response here is from a prime owner (n)
  20. BiomedO1
    3,470
    1,805
    SacTown, Ca
    Probably a very weak hood spring. Just need to sick your fingers underneath and lift. If you've got big sausage fingers; gently use a plastic pry bar. One of those tools to take apart interior molding.
    If the hood still doesn't release; have someone pull on the release cable while you lift the hood.
    #20 BiomedO1, Dec 7, 2022
