Differences between V and non V CVT?
Discussion in 'Gen 3 Prius Technical Discussion' started by black_jmyntrn, Mar 28, 2023.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,692
    393
    2013 Prius Plug-in
    great point! but... it's my understanding it's not in all PRIME's, it appears to be the later models, and not in the 17-18 first-round models.
    I've been lead to believe that no, the V doesn't have this. I'm actually using that extra part in my build with the 2.0L engine with a Prius CVT.
  2. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    The v definitely doesn't have it
    All Primes definitely do.
    The PiP was the question mark. So if the PiP doesn't have it, then EV mode travel is speed limited, unlike the Prime- meaning you're not losing a feature.
    If the PiP did have that clutch, you're potentially giving up a feature or having to do more work to integrate a clutch.
  3. bisco
    51,058
    i think the pip is limited to 84mph, but i could be misremembering. i've never gone that fast
  4. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    Without the one-way clutch, the engine would be forced to spin starting around 40mph. And if you're going to spin it, you might as well run it.
  5. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    No, the Gen 1 PHEV aka Plug-in is speed limited. Keep in mind I am still learning here. When you say clutch, what are you referencing?
    I wish, the Gen 2 PHEV aka Prime I need to go drive it to confirm but I think you are right.. or 78mph.. somewhere in there it does kick on the ICE.
  6. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    I had to have a new flywheel made with the crank bolt pattern of the 2.0L yet the same diameter of the Prius flywheel so it would fit into the Prius CVT. That's how now we have lightened flywheels available for the Prius and the new 2.0l motor. Now, in my head what I know of to be the clutch in a manual transmission vehicle on the Prius is called the damper assembly, right? So when you say clutch we are talking about the same parts right? The clutch is lying on its side to the left of the motor next to the wheels right?
  7. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    No, I mean the one-way clutch.
    There's a priuschat thread for it as well.
    While we're rolling, I understand the v transaxle also has a pitch suppressor (probably not the right name) but I had understood that to be an electronic feature- something in the MG2 inverter control. The idea was that it could dampen or eliminate rhythmic pitching sensations related to the longer wheelbase of the v.
    And just other stuff to think about: does the v transaxle inverter(s) give you what you need with respect to air conditioning and power steering?
  8. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    not too sure about that one Mr. Foot... I'm a visual guy and after taking all this apart to build my Tesla eater.. I need to see it.. this image below appears to indicate we are speaking about the same...
  9. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    If this is what makes the ICE stay off while in EV mode at higher speeds, I would agree with you. In speaking with those who have possibly changed more Prius motors than a master tech, when I relay the information presented to me it said that the first few years of the Prime doesn't have it and they were caught off guard seeing this new part installed on the newer model as it wasn't on the early ones.
  10. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    I can't really vouch for the picture in an old Prime marketing brochure.
    But the important part is that you're able to spin the planet carrier freely and easily without making the engine turn. If you were to try back-spinning the planet carrier, it would immediately dig in and force the engine to rotate.
    With one-way clutch: EV mode goes as fast as the battery allows
    Without one-way clutch: EV mode cancels/stops being useful from about 40mph on up... engine starts and helps out from there to the top of the speedo.
  11. ChapmanF
    17,227
    If you take the flywheel right off a Prius Prime engine, you see this on the back of the engine block:
    Notice the circle of fixed teeth around the crankshaft bearing. (They look sloppy because of grease on them. They look tidier without the grease.)
    That right there is the (PNC 32528) "1-way clutch holding plate". It's just fixed, immovable, bolted down on the back of the engine block.
    If you then put the 35790D "1-way clutch assembly" back on and take a picture of the boring side, it looks, well, boring, and you don't see what's going on with the teeth.
    The less boring side of it is the other side, but the member who started that thread didn't take a picture of the interesting side, and there don't seem to be a lot of other pictures of it in the wild. Oh, well.
    But there are generic videos on how sprag clutches work:
    In the Prime, of course, it's the inner portion of that clutch that is fixed: the teeth on the fixed holding plate. The rotating part is the outer part and is able to spin freely in the normal engine-operating direction, but will engage the fixed teeth and never let the engine spin backwards.
    When the engine is turning in the normal direction, those little sprag elements in the rotating part are held outward by centrifugal force and they don't even contact those center teeth, so there's no added friction or ratchety noise.
    So, the sprag clutch is something you see on the back of the engine block, and on the engine-facing side of the flywheel. It isn't anything you see just taking the transaxle off, or looking at its damper, which goes between it and the flywheel.
    The parts diagram above is funny, because it shows both 1-way clutch pieces, and then next it shows the transmission input damper, and it doesn't show the engine flywheel in between the clutch pieces and the input damper! The flywheel gets its own picture over in the crankshaft and pistons diagram, and that one doesn't show the 1-way clutch. :)
    It also is not my understanding that the sprag clutch does anything to change the nomogram of the transmission. All of the familiar relationships between the speeds of the engine, MG1, and MG2 have to still hold. At high forward speeds without the engine turning, MG1 still has to do some pretty high reverse revs. If they have raised the road speed they allow with the engine stopped, they must have raised the limit on MG1 revs, as a separate refinement from the sprag clutch.
    What the sprag clutch does is let them go further and use MG1 in that situation, to contribute more torque. If the sprag clutch weren't there, that would only spin the engine around backwards, a waste of energy (never mind how well the engine tolerates spinning backwards). But with the sprag clutch, the flywheel digs in then and won't budge, so the MG1 power acting against it has to be contributed to the transaxle output.
    But if you add the spraggy teeth and 1-way bit on a car that didn't have them, the programming in the power management control ECU still won't know it is able to apply MG1 torque then without the engine spinning backwards, so it's still never going to try.
    #31 ChapmanF, Apr 1, 2023
  12. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    holy boner batman! reading.... finally, I can see it but need to read and will ask if this is what they remember seeing.
  13. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    I'm certain I need to read more to correct my own understanding of it, but thanks for this post!
  14. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    So then, if this is controlled by a clutch. one would assume the ECU for the transmission plays little part in the control of the CVT during this process! But, I cant touch the Prime until I've replaced it with something better is the rule. I need to see if the part number for the V transmission ecu is the same or not. I initially thought the PHEV Plugin has more differences but the transmission ecu is the same as a non PHEV. If the transission ecu of a V matches even better for my end goal but for my general build knowledge i've been focued on making sure FrankenPrius gets the benefits of the PRIME like higher EV power usage and that trick of charging HV battery with engine by pressing a button.
  15. Leadfoot J. McCoalroller
    7,841
    7,306
    Pennsylvania
    2018 Prius c
    The trick is that the logic in the ECU is going to be different based on the presence or absence of said clutch. Re-read the last paragraph of @ChapmanF's post 31.
  16. ChapmanF
    17,227
    Interesting if true; would mean the programming in it knows how to roll with either a spragged or spragless engine, and would need some way of determining which one it's got, maybe from when the VIN is programmed in, or through communication with some other ECU in the car that knows.
    Or did you compare the right ECUs? There's one called the transmission control ECU, whose one and only job is to slide in and out the hunk of metal that stops things when you're parked. (At least that's what it's called in Gen 3.) The hybrid vehicle control ECU is the one that really conducts the powertrain orchestra.
    From what I'm seeing, the hybrid vehicle control ECU can be 89981-47780 or -47830 in a 2017 Prime, but -47557, -47576, -47B00, or -47B10 in the non-Prime (depending on whether the non-Prime is a ZVW50 or ZVW51, and I haven't kept up with what's the difference between those).
    HEV CONTROL COMPUTER. 2017 Toyota Prius Prime | Toyota Parts Center Online
    HEV CONTROL COMPUTER. 2017 Toyota Prius | Toyota Parts Center Online
    #36 ChapmanF, Apr 1, 2023
  17. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    still reading and deciphering but yes, I pulled the transmission ecu from a non-plugin gen 3. when I broght it back to my plugin, the ecu numbers matched. I found this odd but throughout all I am figuring out, Toyota has more interchangeable parts than we've been lead to believe... there's more I just have to confirm.
    also, I think you replied to me but one of my most knowledgeable Prius resources who has yet to steer me wrong states this clucth is not in the first few years of the Prime, that's why when we were talking on the discussion of this 2.0L swap and how id manage the power of this larger motor going in reverse to the Prius CVT his light bulb came on about what he remembers seeing.
    https://black.jmyntrn.com/2023/03/02/prius-phev-repair-cronicles/
  18. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    the only difference visually on the V is the additional cooler. now, if there is something different on the motor to dampen or eliminate rhythmic pitching, I would hope not for one. second, the discussions on the lightened flywheel and the metals/solid one-piece construction this did come did come up. It's why we used the same metal and solid one-piece design versus attempting any holes or pushing past the typically recommended 15% lightning. we do not know the pros or cons of changing metals and other design changes just yet so to venture too far into the category of the change with hopes of eliminating future issues, we went simple just to get it all to fit together.
  19. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    CORRECT!!!
    now, follow me here, what other ECUs have programming to know how to roll with the variation of hardware... if you take that and really think outside the box you'll be to where I am with the different possibilities to open up in terms of modifying the Prius to have more power while remaining fuel efficient. One might be able to say swap in another motor, even if it's from a different line of the family to have the ECU roll with this new motor which is relatively similar to its OE motor. Any differences in parameters not on the OE motor would then be programmed into the additional ECU of the PHEV which can handle the additional data in the unused areas of the memory banks.
    back to the CVT, I am in the perfect spot to test the thought of adding the plate when I do this first cvt swap using OE flywheel and such. if i do get higher mph in EV mode, its a win!
    #39 black_jmyntrn, Apr 1, 2023
  20. black_jmyntrn
    1,692
    393
    2013 Prius Plug-in
    This picture is concerning. This is with the flywheel pushed over the plate and all the teeth from the other image right? or does the flywheel and pressure plate go on top of this? Because this flywheel looks nothing like anyone I've seen for a Prius nor the new 2.0L from the ux250h
