Garwin StreetPilot C340 on a ProClip
Discussion in 'Gen 2 Prius Audio and Electronics' started by Roger3125, Dec 9, 2006.
  1. Roger3125
    Roger3125 New Member
    199
    Orange County, So Calif
    I've talked about my Magellan2000 of which I am still happy with BUT was able to pick up the GarwinC340 for same price so HAD to compare. My problem is I cannot figure out how to connect the C340 to my ProClip. Any solutions someone has come up with?
    California law prohibits us from using the windshield.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Roger3125 @ Dec 9 2006, 10:55 AM) [snapback]359790[/snapback]</div>
    Take a look at the Garmin 10613 Dash Mount or 10609 Vehicle suction mount with 12/24-volt adapter.
  3. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(seasalsa @ Dec 9 2006, 12:40 PM) [snapback]359821[/snapback]</div>
    That really didn't answer the OP's question.
    The problem is that there are few aftermarket brackets that will fit the c3x0 series. The only one I know of is the RAM bracket. You can mount a RAM ball on your ProClip (both have AMPS hole patterns), then use a short (1") arm to connect the RAM ball and the RAM bracket.
  4. Roger3125
    199
    <div class='quotetop'>QUOTE(priusenvy @ Dec 9 2006, 10:48 PM) [snapback]359941[/snapback]</div>
    Thanks can you tell me where I would get a "ram ball" and how I would connect the power chord. The power chord as I see it on the orginal bracket is into the bracket and not the GPS.
    I'll look forward to you answer and again Thanks
  5. priusenvy
    1,765
    Silicon Valley, CA
    Online source for RAM mounts
    RAM Bracket for C3x0 - you must remove the power connector from the Garmin suction-cup mount and mount it in the bracket with two screws:
    RAM 1" Ball - mount this on your ProClip:
    RAM short arm - connect ball on ProClip to ball on GPS mount with this:
