2009 Prius - Warnings and will not engage.
Discussion in 'Gen 2 Prius Technical Discussion' started by KitsuneVoss, May 21, 2024.
  1. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    2009 Prius. Had it for a few years and has about 250,000 miles.
    Was driving Wednesday afternoon. Threw me the orange triangle but no codes from a standard OBDII code reader. was not near home so could not use Techstream. Had driven about 200 miles since then but nothing happened between then and driving to work. On my way to work, threw me the same orange triangle. Same thing, no codes so just cleared it with my regular reader.
    Went to the gas station and once fueled up, tried to start the car. No orange triangle at first but the dash lit up like a Christmas tree and would not go out with check engine light. Would not switch into drive but would switch into neutral. Tried a number of times with turning it off and on but would not go into gear. Never heard the engine come on either. Eventually got the orange triangle after a number of tries.
    Was stuck at the gas station for 6 hours because of how long it took AAA to send a tow truck. Eventually towed it home because Toyota was closed. Thought that it might just be the aux battery. Had a booster pack which I used to test the aux battery and got 12.5 volts but the booster pack was beeping at me. Tried jumping as well to see if that could make a difference.
    Working a double today to make up for not working yesterday so cannot do any testing until Wednesday. Will post Techstream when I get a chance.
    Any first impressions on what the issue might be without Techstream data?
  2. ChapmanF
    17,711
    Wouldn't surprise me if the code turns out to be P0AA6, but if your time is scarce, it's better spent finding the actual code than pursuing my guess.
  3. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    "Hybrid Battery Voltage System Isolation Fault"
    When I get home from work tonight I plan to find the Techstream sensor. First thing in the morning I plan to test the car with Techstream. I think I know where it is but have not used it in a year. How hard is that problem to fix, assuming that? I have replaced the whole battery on a 2003 Prius. Will not buy anything until I am pretty sure I know where I am going.
  4. ChapmanF
    17,711
    The isolation fault could be anywhere in the car's high-voltage system: air conditioner, transaxle, inverter, cabling under the car, or battery.
    Still assuming this is even the code you have, with Techstream you can also retrieve a three-digit INF code that would at least help you focus on one region of the car:
    Without that information, you'd just be stuck getting access to a megger and poking around the whole high voltage system with it, nose to tail.
    So as you can see, there's really no better way to spend your time at the moment than retrieving the codes with Techstream. They might even be completely different from my guess.
    If you can't get to the car with Techstream until morning, just don't stress about the car between now and then. There must be other stuff on your to-do list, or or something fun to do in the meantime.
  5. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    Well, I think you called it. Posting some other stuff too but likely either not an issue or minor stuff
    I know nothing is ever 100% but does it look like I need to simply replace the module on the battery? 612 matches the ECU location and surrounding area. There is a module on the battery on the 2003 and assuming it is something similar? Also, assuming the module is the most likely cause, do I need to match any codes or can I just order any tested module from eBay?
    Ugg, is that ECU also the device that stores key information and other stuff? If so, do I need to get one reflashed?
    #5 KitsuneVoss, May 22, 2024
  6. ChapmanF
    17,711
    Funny how that diagram is drawn so not-to-scale. It makes the ECU look huge. That little column of small long-line/short-line pairs to the left of it? That's the whole stack of battery modules (accounting for much more of the real size and weight of the battery than the ECU does!). The 612 area includes everything from the orange service plug and its socket, the battery modules and ECU and their wiring, up to the supply-side terminals of the SMRs. (The load-side SMR terminals are where the 614 area starts.)
    You still have the job of finding out where within that whole 612 area you have a current path between something and body ground (or something and the 12 volt wiring). But at least that's an easier job than if you didn't have the INF code, and had to look for the problem somewhere in the whole car.
    The C1259 and C1310 codes that are also showing are just codes the brake system will post when it knows there's a hybrid-system issue, so those are just there because of the P0AA6. No need to be concerned with those.
    The U codes I don't have a ready story for, but anyway, after the P0AA6-612 is fixed, there'll be time to look into those, if they're still present.
    No, there are about a dozen ECUs in a gen 2. The one inside the battery is just responsible for monitoring its current, voltages, and temperatures.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,013
    1,947
    NJ-USA
    Typically, a 612 sub code results from a minor electrolyte leak from one of the battery modules.
    It's possible to have corrosion damage at the orange voltage sense connector on the battery ecu (and on the ecu circuit board), but that causes other problems (usually not P0AA6).
    Are you planning to try to repair this yourself?
  8. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    I really would like to fix it myself. If I have to buy a whole remanufactured hybrid battery on credit and replace it myself, it would still be many times cheaper than Toyota and likely cheaper than even a non Toyota Hybrid shop. I have replaced the whole battery on a 2003 Prius on my own last year. Had physical help getting it in though.
    Now that I have the P0AA6 and 612 sub code, I am really looking for easy things I can replace or test to see if I can solve the problem. If something is super easy and cheap but an unlikely cause, I might likely try that. An example on computers is to replace the battery on a computer motherboard even if NOT the likely cause. Yes, I work on computers as a hobby.
    Edit: I think my next step is to get at the battery and other stuff tied to it and have a look?
    #8 KitsuneVoss, May 22, 2024
    Brian1954 likes this.
  9. mr_guy_mann
    4,013
    1,947
    NJ-USA
    Yes, disassemble the outer case and inspect the base where the modules bolt down. If there's a leak, you'll often see some corrosion or discoloration on the sheetmetal.
  10. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    If I end up replacing the whole battery, will there be an issue with the Hybrid ECU/ECM not recognizing the keys / car?
    Going to look at cells first though. Right now I am watching a video on how to take the battery out.
    Edit: If I don't see anything, I figure I can take pictures of the battery from all sides and a video and see if someone sees something I don't
    Edit-2: Will the cell, assuming it is a cell, show any other signs of failure such as showing bad with a battery tester? Will resistance between the battery lead and the case / frame be zero?
    #10 KitsuneVoss, May 23, 2024
  11. Leadfoot J. McCoalroller
    7,986
    7,466
    Pennsylvania
    2018 Prius c
    Just a bit of clarification- the hybrid ECU is somewhere in the front half of the car. It communicates with another ECU, often but not always referred to as the battery ECU.
    During a hybrid battery swap, it is normal to keep your old battery ECU and move it to the new battery. It won't make any difference to the keys & security system.
  12. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    When I replaced the battery in the 2003, the ECU was part of the swapped battery. I did not need to change it out.
    From the way it sounds, the battery ECU does not effect the keys and/or security system?
  13. Leadfoot J. McCoalroller
    7,986
    7,466
    Pennsylvania
    2018 Prius c
    Toyota has changed the name and location and division of "labor" of the battery ECU over the years, and it doesn't surprise me to learn that a swap wasn't needed with a 1st generation car- I know very little about the oldest ones.
    Either way I'm confident it won't mess with your keys & security.
  14. ChapmanF
    17,711
    There are roughly a dozen ECUs in a gen 2 Prius, and the ones that keep track of key registration are nowhere near the battery.
    The one in the battery is responsible only for watching the battery current, voltages, and temperatures.
    In gen 3 they stopped calling it the "battery ECU" (it got bucked to "battery smart unit" or "battery voltage sensor") but it still has pretty much the same responsibilities.
  15. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    A lot of pictures incoming
    Video
    1. What is the next step here?
    2. Does the resistance test on the individual cells where I test from the post to the metal chassis work? I know I have to remove the bolts and the plates between cells.
  16. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    I just noticed something myself. Staining on the metal right under the cells from cells 11 to 15 going from the right.
    Is that what I am looking for?
  17. mr_guy_mann
    4,013
    1,947
    NJ-USA
    Certainly suspicious.
    Set your digital multimeter to DC volts (if yours has manual range setting, go with 2.0V).
    Put one lead on one of the battery module studs, and the other on the sheet metal base. Ideally you should read 0.0V.
    If there is any voltage, even 0.01V, then that module either leaking or is connected to one that is.
    Carefully remove the nuts and bus bars and recheck. (this isolates blocks from each other, eventually you will have the individual module(s) that are leaking).
    If-once you find the problem, then you get to do research on how to fix it. "Just" replacing failed modules is cheap but is only occasionally successful.
    Charge - discharge cycling modules takes more equipment, time, and knowledge. There's grid chargers that cycle the entire pack vs RC hobby chargers that do individual modules. Do it right and you can get a few years out of it. Do it wrong and it won't work at all.
    Then there's "refurbished" packs (either of the above processes done by someone else, with the same possible outcomes).
    Or getting a new pack - such as from Toyota. Should last 10 + years.
    There's many days of threads to read about all of this.
  18. Carall
    Carall Active Member
    303
    100
    Harrisonburg, VA
    What I see is the battery at the end of its life.
    If you replace the leaking module, the next leaking one will appear again.
    I was able to find which one was leaking only when the battery was warm, having just been removed from the car.
    Unscrew all 56 nuts and remove the bus bars off the modules. Then set your multimeter to the continuity mode and hook one lead to the battery case and with the second lead touch the module terminals one by one on the left and on the right side.
    The leak in the photo is visible in blocks 8 and 9.
    #18 Carall, May 24, 2024
    JON KIRKEGAARD likes this.
  19. KitsuneVoss
    KitsuneVoss Member
    322
    48
    Virginia
    I know I may be repeating things already said but just want to verify.
    If i am understanding, while nothing is ever 100%, it is almost certain that the issue is the battery pack and stuff tied to it?
    1. I can try to replace the cells, the four that are likely bad, but it is likely not to solve the problem? Is there any point in testing the cells in such a case?
    2. My best option is to replace the whole battery pack?
    a. I can get a reconditioned one such as this one
    Reconditioned 2009 Toyota Prius Battery (Generation 2) - Exclusively Hybrid
    Give me year warranty but they are still old cells and could give out at any time?
    b. I can get one with new cells but a slightly different configuration but suppose to work
    New Toyota Prius Battery (Generation 2) - 4/yr-Warranty
    Give me new cells and a four year warranty but twice as expensive
    c. I have seen Li-Ion batteries but even more than the all new cell one and people here are not sure about them?
    d. Does Toyota even make new batteries or have new batteries available? Would they not be like $5000 if they are available? I don't have $5000 for a new battery if they do.
    My current temptation and seeming best option is option 2b but want to make sure that I am understanding everything?
  20. rjparker
    9,846
    6,078
    Toyota OEM are available for $2250 installed around here and you get 10 years out of them. Even if you sell the car in a few years, the genuine modules will be a big selling point. Reliability of the battery won’t be a concern.
    The cylindrical NiMH modules are new but many only get two years out of them. Even if the guarantee of four years is honored, repeated downtime and poor reliability is a concern.
    However they are better than reconditioned which may fail multiple times in two years.
