Cold starting
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Feb 5, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,154
    566
    Alberta
    2024 Prius Prime
    XSE
    Except for the fossil fuels burned to produce the electricity.
  2. ChapmanF
    18,215
    sounds like a chance to calculate and compare two numbers.
    i wouldn't be surprised if threads exist on pc where that's already been done. block heater threads are common.
  3. Paul Gregory
    2,154
    566
    Alberta
    2024 Prius Prime
    XSE
    Ask any mechanic, even an honest one, and he will err on the side of caution, saying you should use a block heater.
    He wouldn't want to be liable for engine damage from giving the wrong advice.
  4. mva
    mva Member
    137
    82
    B.C. Canada
    2024 Prius Prime
    SE
    When I had my Gen 2 Prius, and lived in Northern BC, I installed an 120 volt electric cabin heater and I ran that instead of the block heater. It was nice for me and the hybrid battery to have the interior prewarmed before driving.
    Like Paul, I had confidence that the ICE would start and run with its synthetic oil. Which it did down to -30C. That was long before 0W16 - I think it was speced for 5W30 at the time.
