Transmission Glitchy After Descending Big Hill
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JohnInHawaii, Apr 8, 2025.
  1. JohnInHawaii
    JohnInHawaii New Member
    Honolulu, HI
    I have noticed on occasion after going down a long steep hill that our 2017 Prius has issue with its transmission changing gears as we accelerate again. It revs up and then may finally bump into gear. Turning it off and then back on helps clear it.
    At our last servicing our dealer told us the after market battery in the car was failing their test. subsequently we had daily episodes of gear switching issues after descending a steep hill near work and read that a failing 12V could cause problems with the transmission. We replaced the battery. Things seemed to work fine for a week or two and then we noticed the issues again, always after going down the steep hill. I recently decided to put the car in neutral going downhill. Three days in a row and magically we have not had any trouble after descending the hill when using neutral. I suppose it would be better if we used B mode on the stick, but it is surprising that we have this issue particularly after going down long hills. It seems the transmission gets glitchy from the stress of the hill if left in gear going downhill. Anyone else have these issues?
  2. Mendel Leisk
    41,463
    How long of a steep hill? Post a google map route, end-to-end?
    for the steepness: have you tried shifting to B, and is braking still needed?
  3. BiomedO1
    3,629
    1,872
    SacTown, Ca
    I drive though the Sierras all the time and haven't had that issue.
    Has the ATF ever been changed or checked?
    Are your sure it isn't the ICE kicking-on because of low traction battery? This car will rev a bit higher while it's trying to provide power & recharge the traction battery at the same time. It's does act a bit sluggish while doing so in Eco mode. Switching to normal or sport mode will usually fix this.
    FWIW: Placing the car into neutral on the highway isn't a good idea - If you need to jump on it, to avoid something - you'll simply engage and rev your engine - if you forget to put it back into gear; before jumping on it..........
    #3 BiomedO1, Apr 9, 2025
  4. rjparker
    10,158
    6,316
    A low capacity hybrid battery will fill up quickly on long descents and automatically go into an engine braking mode where it is spinning the engine by the wheel torque.
    Doug McC likes this.
  5. BiomedO1
    3,629
    1,872
    SacTown, Ca
    I've found, at least on mine; there is no engine braking unless I have my cruise control set and active. The ECU will fire-up engine braking around 8-10 mph over set limit; otherwise it'll just keep gaining speed with the engine-off. If I cover the brake pedal, engage the switch but not really brake, I can get full regen bars vs a partial. Release the brake pedal; system will go back to partial regen. This is under Eco mode; that's my normal setting.
    The other way to engage engine braking is to place the car into B-mode. I only do that on very slow, steep down hill descents <35 mph.
    That's been my experience....
    #5 BiomedO1, Apr 9, 2025
  6. ChapmanF
    18,215
    Because our transmission doesn't have any gears to change, just a fully variable ratio between the engine and wheels controlled by a computer, glitching and bumping into gear aren't things. It's just varying the engine-to-wheels RPM ratio the way the computer is telling it to, and the computer has various reasons for the choices it makes, including the battery temperature and state of charge. There's no need to do anything to "clear" it. While that's a way you can get it to forget what it was doing and why, and so return to doing something more like what you expected, there's no benefit other than being more like what you expected. What it was doing was what its normal rules tell it to do.
    Tande, Doug McC and BiomedO1 like this.
  7. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    The problem is most likely in the overheated high-voltage battery, which first helps to climb the hill, then quickly absorbs energy during the descent. If the battery has a couple of weak modules, the computer will limit the use of the battery after such stressful ascents and descents.
    BiomedO1 likes this.
  8. BiomedO1
    3,629
    1,872
    SacTown, Ca
    Yes; check your traction battery cooling system. Clean it out and use your AC system.
    I've forgotten how hot and humid it is there and how someone would get used to it after a while....
  9. JohnInHawaii
    Honolulu, HI
    I'm so sorry for the late reply. I wanted to post a video of the descent as well as a picture from the bottom looking up. I have been using B mode on the stick and it is just fine.
    I tried to post with video and image link but am being denied because I am a newbie to the forum. I have uploaded the image, but can't upload the video of the drop. The drop is about between 37 and 45 degrees. Pretty steep.
    I am not sure how to check the traction battery cooling system. But shifting down into B is helping the situation most definitely!
    --John
  10. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The degrees are greatly exaggerated.
    The steepest section, from the "Downhill" sign to 18th Avenue, is 1,050 feet long, the difference in height between the top point and 18th Avenue is 120 feet.
    The slope of the slope is α=6.7° or 11.905%
    #10 MAX2, Apr 16, 2025
  11. Mendel Leisk
    41,463
    Beat me to it lol.
  12. BiomedO1
    3,629
    1,872
    SacTown, Ca
    You really shouldn't need B-mode for that bunny hill. I only use it on something like long 10% grades.
    Here's a video I found. After the first minute, it shows the decent into South Lake Tahoe. Turns are 25-30 mph down that grade. If you use your brakes the entire way down, you'll barely have anything left when you get to the bottom. The was a stop light down there that was replaced with a large roundabout - looks like it was cut from that video. There was horrific accidents there, when flat lander couldn't stop at that light. I still see skid marks, on occasions, going straight through the center of the roundabout.The last three minutes of the video was the decent from Tahoe to Carson City. Since we're talking highway speeds (65+ mph), best to lock-down the cruise control and let the ECU control and manage everything, if you've got adaptive cruise control. I believe B-mode in that situation would place undue stress on the power-train.
    #12 BiomedO1, Apr 16, 2025
  13. ChapmanF
    18,215
    It's hard for me to imagine B mode putting undue stress on anything. The engine is burning no fuel, the cylinder pressures are very low because the throttle is closed, and the torques involved are a fraction of what they are when you're using the engine to accelerate.
    The car is just spinning a bunch of nice oily gears and moving some nice oily pistons. It could do that all day.
    A tip for those big descents: there will be a steepness of grade, and a speed of the car, for which even the maximum available engine braking won't hold your speed, and you will be going gradually faster and faster even with the engine singing away at 4900 RPM to hold you back.
    In those situations, you can either take a less steep descent, or take it more slowly. Usually there's not the option of changing the slope, so that leaves slowing down. You can (nearly) always find a slower speed that the car will be able to hold. (Sometimes, though, it might be slower than the drivers behind you want to go.)
    #13 ChapmanF, Apr 16, 2025
  14. BiomedO1
    3,629
    1,872
    SacTown, Ca
    Call me old school, but I just don't like hearing the engine whine like that - especially at those speeds. Adaptive cruise will max out regeneration braking before engaging engine braking - it helps that the Prime has a larger battery to fill. It'll get to about 70% when I've made that run in the past.
    If you need to use your brakes; use them. Pulse them and gave them a chance to cool down - DO NOT DRAG them!!!
    FWIW; There's a stop lamp at the base of that run too.
    #14 BiomedO1, Apr 16, 2025
  15. ChapmanF
    18,215
    Unlike downshifting in a conventional car, where it's your job to make sure you don't overrev the engine, the Prius ECUs know exactly the maximum RPM that they like hearing, and will never exceed that while engine braking. If the resistance at that RPM isn't enough to hold your road speed, they'll just do their best without exceeding that RPM and you'll pick up a bit of speed and have to snub with the friction brakes from time to time.
    Once I recognized that, I decided to just let that sound become music to my ears.
    Tande and BiomedO1 like this.
  16. BiomedO1
    3,629
    1,872
    SacTown, Ca
    And if you do manually apply the brakes; the CC system will disengage.
    You can re-engage using the resume, toggle up.
  17. JohnInHawaii
    Honolulu, HI
    On a lark I asked my wife what she would estimate the slope of the hill being and she guessed 30 to 35 degrees. When I told her it was a 6.7 degree slope she had a laugh. I jumped on Google Maps and Google Earth and used the elevation and distance and calculated it and it just doesn't seem to comport with reality. Kilauea drops and then flattens out at each intersecting avenue. I did the math and there are sections where the angle is 10 degrees by Google's numbers, but I swear it doesn't feel that small. But I am open to the idea that my perception of angle is off...
    Regardless, today I forgot to shift into B and by the time I reached the school after the intersection at the bottom, my engine was revving high. I turned off the engine for a few seconds, but later in traffic I found the transmission sluggish to change gear on flat road. Shut it off again and it returned to normal. But it seems by downshifting to B mode and applying brakes until the school I can avoid all of the issues. So I will continue this method, but am curious as to the underlying cause.
  18. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    I did not find any sections with more than 7 degrees.
    At each section 15-16, 16-17, 17-18 the elevation drops 36-46 feet, the distance between the intersections of the road with the streets is 340-360 feet.
    From 18th Avenue the section becomes more gentle and at 22nd it is almost flat.
    Measurements "by eye" and practical measurements are quite different things.
    I believe that your problem lies in the high-voltage battery. The battery has deteriorated its characteristics and cannot store all the energy that can be obtained when descending this hill without taking into account the braking of the brake pads.
    After the battery is charged, the internal combustion engine begins to assist with braking.
    Try monitoring the battery charge, battery temperature and the current that comes during the descent from the hill.
    The free Hybrid Assistant app for Android phone will help you in this process very well.
  19. ChapmanF
    18,215
    My angle perception is off in the same way. I think it's pretty common. I've come home after a bike ride and looked up some hill on the map and thought "no way is that only α degrees!".
    Again, at the risk of repeating post 6, don't do that. The car is doing what it's programmed to do, and interfering with that doesn't help. Descending the hill in D instead of B meant the balance of regen braking vs. engine braking was more in favor of regen, where the balance in B is more in favor of engine braking. The heavier regen made the battery hotter on the way down. The car had to bring in engine braking anyway because of the size of the hill, and may have chosen to continue spinning off energy at the bottom to get the battery into a more comfortable range.
    Again repeating post 6, there are no gear changes, only a computer calculating what the ratio of the continuously-variable transmission should be at each given moment. When it chooses a higher ratio (which might make you think "sluggish to upshift"), it calculates that based on real needs at the time, such as the temperature and charge state of the battery.
    Don't try to outthink the car's programming or trick it into acting the way you think it should instead of how it thinks it should. It knows more about its current operating conditions and needs than you do.
    Yes, selecting B is a good idea on that hill, as it reduces the heavy charging forced on the battery. Using your brakes (sparingly, as needed) does the same.
    MAX2 may be right that your battery is in a worse condition than a new one, and so you'll be more likely to see behavior like this than you would if the battery was new. But in any case, the car is simply managing the needs of the battery; it would do the same with a spanking new battery on a big-enough hill. You could choose to replace your battery now, or you could choose to wait. The car will do its best to operate within the parameters of the battery it's got, to prolong the life of that battery—as long as you quit trying to second-guess it and stop it from doing so.
  20. BiomedO1
    3,629
    1,872
    SacTown, Ca
    Looks can be deceiving; that's how magic works....
    Enter the scientific method, calibrated, measurement test equipment. No guessing involved.
    #20 BiomedO1, Apr 18, 2025
