2010 Prius still shakes after head gasket job and EGR + intake cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by infinitepub, May 7, 2025 at 9:21 PM.
  1. infinitepub
    infinitepub New Member
    Yesterday
    Hello,
    My 2010 Prius had a blown head gasket with the typical symptoms of rough shaking, white smoke, and low coolant levels. I went ahead and did the job myself and followed a lot of the suggestions from this forum. I made sure to check for warpage, valve leaks, piston/rod condition, replaced water pump, replaced thermostat, replaced PVC valve, and replaced all required gaskets with OEM.
    The car ran smooth at first with the symptoms clearing up. I took it on a test drive for about 5 miles before I started to notice some minor shaking coming from the front.
    I assumed it was probably the EGR and intake causing it because I only cleaned them a briefly, so I took the intake & EGR out to thoroughly clean them. This time around I cleaned them until there was no carbon left in both components. I used oven degreaser for the EGR cooler, parts cleaner for the EGR valve, and purple power for the intake manifold.
    I just put the intake and EGR back onto the car and now it shakes violently upon start up. I scanned for codes and saw nothing. I let the car run for about a minute to see if maybe it would clear up or perhaps a code would pop up eventually, but neither occurred. I had a local Toyota technician stop by my house to assess the car and he suggests the shaking is coming from the transmission. He says it's possibly a component within the transmission which might have come loose that's causing this shake. I'm not too familiar with the transmissions in the hybrid Toyotas, so I am in need of help with diagnosing the problem.
    I am posting on this forum for possible leads/ second opinions on what could be the issue? What are some other diagnostic tests I should complete?
  2. Brian1954
    Brian1954 Senior Member
    1,586
    617
    South Central PA, USA
    Did you take the head to a machine shop to get it looked at?
    Did you double-check the timing of the camshafts to the crankshaft?
    There is a damper that is located between the engine and transmission. The springs in the damper can break because of the misfires due to the bad head gasket. How long (miles and time) did you drive the car after you first noticed the shaking during a cold startup?
    BiomedO1 likes this.
  3. BiomedO1
    2,593
    1,394
    SacTown, Ca
    Did you check the head & block for warps with a straight edge? Did you replace the head/stretch bolts, used a quality head gasket, torque-down the head bolts per OEM specifications and pattern?
  4. rjparker
    9,310
    5,674
    First, let's hope a rod was not ready to bend or break or the transaxle damper springs have not broken.
    I have seen head bolts that were not torqued properly pop a hg again.
    Compression test for serious rod or piston issues and a borescope with coolant system pressure for a possible repeat head gasket.
    This symptom is key. Hopefully it was with the engine running and car moving and not immediately after a stop light and subsequent engine start.
    Your definition of "minor shaking" is important. Was it way less than the violent shaking pre head gasket? If so it could have been a vacuum leak or similar now made worse after tearing down the intake and egr again. Maybe the plugs are now fouled by fuel or coolant or some hose is disconnected.
  5. Mendel Leisk
    40,260
    What miles did symptoms start at, and what miles did you do the head gasket replacement and (eventual) thorough EGR cleaning? Aforementioned damper (at engine /transaxle interface) and/or bent piston arm(s) are possible factors. Or another head gasket failure, depending on the delay between head gasket replacement and EGR cleaning.
  6. infinitepub
    Yesterday
    I inspected the head and block with a straight edge and feeler gauge multiple times before reinstalling. Not even 0.0015th of an inch (0.04mm) could fit between the straight edge and block/head. I thought it was good enough based on the information from the repair manual found on this forum (0.05mm being the maximum warpage). I didn't take it to the machine shop based on my assessment and I didn't want to risk having the head machined if it wasn't needed which could cause timing issues if the head was machined too much.
    I doublechecked the timing and made sure to lock the cam with a folded towel before taking it off. The timing marks were lined up and I quadruple checked before putting the tensioner on.
    I drove it no more than 5 miles before I parked it in my garage to redo the EGR and manifold cleaning since the small intermittent rattle/shake was bothering me.
    Do you have the specific name of that damper so I can research it more?
    Yes, I checked the head and block with a straight edge and feeler gauge. Not even 0.0015th of an inch or 0.04mm could fit between the straight edge & block/head. New headbolts and gasket from Felpro were used. I torqued them down to OEM specification with the right torque, pattern, and additional degrees.
    I'll do a compression test with borescope today. Just need to find an autozone that'll have both ready to loan.
    The first time I started the Prius after the head gasket it had the violent shake with some puffs of white smoke, but was expected and cleared up. The Prius idled smooth for about 10 minutes in maintenance mode before I decided to take it for a test drive. I drove it less than 5 miles before I noticed a minor shake that was less violent than the pre-head gasket. When I parked the car and let it idle after that I did notice there was a minor shake that was intermittent.
    That was when I decided to pull it in my garage and worked on cleaning the EGR and intake manifold. It took me about 2 weeks of soaking and rinsing with a pressure washer to get all the carbon cleaned out. Started the car 2 days ago after assembling everything and now it's a violent shake like pre-headgasket that is continuous.
    The Prius has 180K lifetime miles. I drove it for at most 5 miles after doing the headgasket job before parking it and haven't driven it since. At the end of the drive at maybe mile 4-5 I noticed the minor shaking which is when I decided to park and let it idle. I observed intermittent minor shaking that was a fraction of what the shaking was pre-headgasket. From then I decided not to drive it and did the EGR and intake cleaning which took about 2 weeks. There was only a delay in cleaning because there was so much build up and I needed to soak the parts and rinse them out numerous times.
    Started the Prius up 2 days ago with all clean intake and EGR system and was met with a violent shake that was continuous. The shake was on a similiar level to pre-headgasket shaking.
    #6 infinitepub, May 8, 2025 at 9:29 AM
  7. Mendel Leisk
    40,260
    Sounds like you got right on the EGR cleaning.
    Still this question:
    If it was protracted time/months, could be aforementioned bent piston arm and/or engine/transaxle damper failure.
  8. BiomedO1
    2,593
    1,394
    SacTown, Ca
    Sorry; I've NEVER experienced a violent shake or white smoke after a valve job or head gasket replacement. Something could've gotten bent and the head gasket could've blown again.
    Sorry....
