Where Is The 12V Battery On A Gen5 HEV?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Sep 24, 2025 at 7:18 AM.
  1. VelvetFoot
    VelvetFoot Junior Member
    89
    New York State
    2025 Prius
    I'm up to page 80, and I do agree it should prove useful. I do have the pdf version. There's no way I'll remember all those warning symbols, if one should pop up.
    edit: Plus, it may prevent some stupid questions on the forum. :)
    #21 VelvetFoot, Sep 25, 2025 at 6:58 AM
  2. Paul Gregory
    Paul Gregory Senior Member
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    For what it's worth, I had a maintainer on my Gen 3, and a few times it failed to keep the battery up.
    At first, I blamed it on a faulty maintainer, but later I learned that the alligator clips are unreliable. They tend to lose connection over a few weeks. That's why I connected my current maintainer through ring terminals.
    VelvetFoot likes this.
  3. VelvetFoot
    89
    New York State
    2025 Prius
    Your maintainer can stand the weather it sees on the '24, under the hood at least? May I ask which one you use?
  4. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    I had a NOCO Genius 3 for over a year, with zero problems. Before that, I had tried several brands that were less reliable. They kept turning themselves off, and I got tired of having to open the hood to check all the time.
    Recently, I upgraded to a NOCO Genius 5 so that I'd have enough power to keep the 12V cooler running while I was parked and plugged in.
    When I did the upgrade, I took a shortcut, using the old wiring harness, which had a 4A fuse, which finally blew. I upgraded the fuse, and all is now well.
  5. VelvetFoot
    89
    New York State
    2025 Prius
  6. Mendel Leisk
    40,983
    I’m using CTEK, they’re getting pricey though.
  7. VelvetFoot
    89
    New York State
    2025 Prius
    Do you think the Genius 2, ie 2amps, would suffice for normal maintenance purposes, if it was even necessary? Genius 3 isn't made anymore, apparently.
    NOCO - 2A Direct-Mount Battery Charger and Maintainer - GENIUS2D
  8. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    without knowing anything for sure, 2A should be plenty to compensate for any drain.
  9. Hammersmith
    Hammersmith Senior Member
    2,185
    2,190
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Maybe you've said it before, but are you going to be leaving your car sitting unused for a week or more on a regular basis? Or are you only going to be doing trips of 10min or less with no longer trips for weeks at a time?
    If the answers to both those questions are no, you almost certainly don't need a maintainer. If the answer to either one is yes, you might need one. If the answers to both are yes, I'd say a maintainer would be a pretty good idea.
    I'd also take Paul's advice with a small grain of salt for two reasons. First, he owns a Prius Prime where you're getting a regular Prius. Primes are a little more susceptible to draining their 12V batteries because of the added monitoring of the HV charging system. There's been a TSB and software update about it that has helped things, but Prime owners have been having 12V battery failures at a higher rate than regular Prius owners.
    Secondly, Paul's car is far from a typical use case. He's added a bunch of stuff to his 12V system that you won't have on your car. Setting aside completely whether those changes were wise or not, it does mean his car is not going to behave the same way as your car will. I'm not saying to ignore his advice or anything, just saying to view it through the proper lens. What's needed in his case might not be what's needed in yours.
  10. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    I can only speak from experience. 99% of the time, the maintainer does its job, and the battery is good. But it can drain very quickly at random times, so I always carry a booster pack.
  11. Gokhan
    Gokhan Senior Member
    5,919
    2,338
    Paramount CA
    I thought you were using a hand-cranked one, Mendel, like your tire pump. :p
  12. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    Just for the record, nothing added to my car can cause excessive battery drain.
  13. Gokhan
    5,919
    2,338
    Paramount CA
    Here is a question to the true Gen 5 geeks here. Exactly which Gen 5 models have that spare-tire screw hole? I am guessing none of the PHEV models but all of the HEV models perhaps with the exception of the HEV AWD models.
    If Mendel or some others ever have to buy a Gen 5, they will have to know.
  14. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    Not that I feel personally insulted, but I have mentioned dozens of times that the battery drain problem appeared at least six months before I added any electrical accessories. Regardless, several trolls have deliberately ignored this fact, and claim that I have caused my own problems. Nothing I have done could possibly cause the type of battery drain I was experiencing.
    I have gone to 3 dealers with the battery problem, but none of them could keep the battery from going dead. One dealer even replaced the battery to no effect.
    My mods consist of:
    A plug in voltmeter.
    A live socket wired off the battery, which is for charging my cellphone when the car is off. Nothing is drawing power when I take my cellphone out of the car.
    An auxiliary lithium battery, which is fully isolated from the 12V system and can not draw from it, except when I want it to, through the smart isolator. The purpose of the isolator is to prevent accessories from drawing down the main battery.
    Everything is working perfectly, and I not the idiot who has caused his own problems as trolls have claimed. I am fairly sure that the wireless updates are responsible for the drain.
  15. Brian1954
    Brian1954 Senior Member
    2,014
    786
    South Central PA, USA
    What are you using for the cut-in and cut-out voltage settings for the isolator?
  16. Gokhan
    5,919
    2,338
    Paramount CA
    If we can stop the ongoing thread hijacking, can we discuss something useful? (Hint: Gen 4/Gen 5 Prius HEV/PHEV does not have a 12-V battery issue for 99.99% of owners.)
    So, all Gen 5 Prius HEV versions, including the AWD versions, have a spare-tire screw hole, but none of the Gen 5 PHEV versions have it.
    HEV LE:
    HEV XLE AWD:
    HEV PHEV:
    #36 Gokhan, Sep 26, 2025 at 2:49 AM
  17. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    The cut-in voltage is 12.3, and the cut-out id 12.8.
    Brian1954 likes this.
  18. VelvetFoot
    89
    New York State
    2025 Prius
    These updates are performed at the dealership to the wireless systems?
    Last time, and I think maybe I had two total, my MINI got a main ECM (I think that was the only controller) update at the dealer, it took hours.
  19. Paul Gregory
    1,974
    501
    Alberta
    2024 Prius Prime
    XSE
    I don't know what's causing the drain, and neither do 3 dealers. I'm forced to use a workaround, which has been satisfactory so far.
  20. Hammersmith
    2,185
    2,190
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    All gen5 HEVs have the spare tire screw hole. No gen5 PHEVs have it. Trim levels don't matter.
    The only difference between the FWD and AWD screw holes is that the FWD version is a stand-alone part, while the AWD screw hole is part of the bracket that mounts/protects the rear motor HV connector.
    Gokhan likes this.
