P3000 & C1310 codes -- troubleshoot sequence?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brka-brkb, Dec 13, 2025.
  1. brka-brkb
    brka-brkb New Member
    New York
    Good evening!
    My 2005 Prius with 94K miles is showing P3000 & C1310 codes with the red triangle after sustaining a light water damage (i.e. floodwater got into the car but did not go above the floor level) earlier this year.
    The trustworthy local auto mechanic says the range of possible issues--likely tied to hybrid battery--is too broad to be worth the likely cost of the repair ($4,000-$5,000) given the age of the car, but the car drives fine and as you can see in the attached photos, it's otherwise in a pristine condition so I'd like to at least do my due diligence and attempt to troubleshoot what could be wrong with the car.
    1. What would be the logical initial troubleshooting steps to take?
    2. Would getting a new (or refurbished) hybrid battery possibly be a better option? If so, from where?
    Thank you very much and happy holidays!
  2. ChapmanF
    18,513
    P3000, if I remember right, is kind of a catch-all code in the HV control ECU for a bunch of different conditions, and will have an associated 3-digit INF code that you really need in order to know what it's going on about.
    Here is a thread about scan tool options that will be able to read the INF code:
    Gen2 OBD2 app review | PriusChat
    The C1310 you don't need to worry about. That's the brake/skid ECU saying it knows there's a code from the HV control ECU (i.e. the P3000 you already know about).
    The P3000 in the HV control ECU might (or, again, might not) be set because of some other code set in the battery ECU, and sometimes people get codes using scan tools that can't communicate with all the ECUs in the car, so might be reporting the code in the HV control ECU but not reporting a code in the battery ECU even though one might be present.
    A scan tool recommended in the thread linked above (for showing INF codes) should also be able to talk to all the car's ECUs and so not miss any codes.
    I would not try too hard to guess at what the problem might be, before getting the rest of the information the car wants you to have about it.
    brka-brkb likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    You've taken wonderful care of your car and you deserve to keep it on the road at a reasonable price!
    Your mechanic is predicting the upper end of the repair cost because they likely don't spend enough time working on hyrbid cars to know how easy the fix can sometimes be.
    Best case scenario, your P3000 means corrosion from the hybrid battery terminals made its way to battery ECU and is sending bad signals because first pins in plug are starting to create micro-shorts/signal noise. I was just working on a battery pack today with this problem and it hasn't even yet thrown the error code, but it will soon had I not cleaned it out. (See pic below)
    Do you have a friend or family member, or do you have basic skills working on cars? Cause all us folks at Priuschat can walk ya'll through any repair and you'll save a fortune.
    And if it becomes certain problem is not as easy to fix as described above and will cost more we can walk you through the other options that could go as high as 1/2 the price the mechanic estimated.
    In meantime, buy one of these for your glovebox: http://www.ebay.com/itm/265484403768 It only costs $20 and can one day be the difference between waiting for a tow truck and just clearing error codes and driving home. As in this device plugs into socket under dash near steering wheel and allows you to connect phone to car diagnostics via phone apps like Dr. Prius app.
    For example, if you used this device to post a screenshot from Dr. Prius app tonight we'd have enough info to confirm that you have the least expensive hybrid battery warning light repair.
  4. brka-brkb
    New York
    Thank you both for your very thorough and encouraging responses!
    The water had seeped in while I was out of town for about two weeks (I travel often for work), so it could very well have been the moisture/humid air inside the cabin with the heat of the summer that corroded key contact points, which hopefully I can do a DIY fix on -- I'm reasonably handy with tools, e.g. I do my own oil/transmission oil and brake pad changes.
    I have actually bought this Veepeak OBD II scanner some time ago (photo attached), but didn't get a chance to try it out yet and I don't know if it can detect the 3 digit INF code. Would this model be a sufficient diagnostic hardware for the OBD apps?
    I am out of town for the holidays but should be able to perform at least the initial troubleshoot on my own at the end of this month and share my findings here.
    EDIT: Also, should it turn out that the repair involved is beyond my DIY skills, does this forum have a searchable database of mechanics that specialize in Toyota hybrids (preferably not dealership shops due to cost -- they quoted $600 just for the initial diagnostics)? I'm in 11360 zip code and hopefully there is a shop nearby.
    Again, thank you so much for your advice and support. :)
    #4 brka-brkb, Dec 14, 2025
  5. ChapmanF
    18,513
    I don't know about that one offhand, but you might see if it's one of the ones reviewed in that thread I linked. If it's there, the review should tell you.
  6. PriusCamper
    13,021
    5,291
    If your car has been sitting for 2 weeks then your problem is the self-discharge nature of NiMH battery chemistry... As in the cells in an OEM battery pack lose their charge when sitting for a long time and cells in older packs tend to self-discharge at different rates so your P3000 is pointing towards a pack that the 14 blocks of cells are no longer all the same voltage.
    To fix it you you need to put the pack on a high voltage trickle charger to fully charge and then balance the pack and you'll be good to go. Hybrid Automotive and Maxx Volts sell an overpriced product to do that for you... Or you can build your own for $100: http://www.priuschat.com/threads/build-hybrid-battery-maintenance-gear-for-under-100.224153/ Or at the end of that thread is a link to an option on amazon that is variable power supply and you need to charge the pack at 1/3 of an amp at 250 volts.
    You can also see if a shop with equipment to do the job is near you on this map: http://www.hybridautomotive.com/dealer-map/ And that website also has the best instructions for connecting the wires and charging and balancing the pack, as well as best FAQ page to help you understand everything you need to know about getting as much life out of your pack as possible.
    #6 PriusCamper, Dec 14, 2025
  7. brka-brkb
    New York
    PriusCamper and ChapmanF,
    Happy new year! I hope you both had wonderful holidays and wish you all the best in 2026.
    I am still traveling for work but will be returning home next week to give my loving attention to our beloved ultimate grocery pickup machine.
    ChapmanF: I will get a new OBD reader that can scan for INF codes and report back here with my findings. I'm leaning towards
    PriusCamper: I will also get a trickle charger and charge the battery, and hopefully that will solve the problem. If I might ask a few questions on corrosion:
    - For minor corrosions, how would I go about cleaning them, especially in narrow spaces like the picture you sent me? I assume some sort of specialized brush like this one would be needed, and for cleaning chemical, would something like these be okay to use?
    - If the corrosion has spread so much that it's better to replace the connectors/connection points, I am totally willing to do that too. For starters, I have identified these points that others on this forum have found:
    - Copper bus bar
    - Sensing harness
    - Fan connector
    - HV ECU pins
    - 12V battery terminal
    If there are other possible corrosion areas that I should be looking for, please let me know.
    Again, thank you so much for your continued guidance!
  8. Brian1954
    Brian1954 Senior Member
    2,396
    960
    South Central PA, USA
