Range on EV Mode
Discussion in 'Prime Main Forum (2017-2022)' started by Mike SBP, Apr 16, 2026.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Standard means an agreed up measure, so it does matter. In other words, temperature extremes... like Minnesota... are intentional exclusions... hence the fine print for those estimates provided. Another example is speed limit... like South Dakota... where 80 mph driving would be grossly misleading.
    #21 john1701a, Apr 19, 2026
  2. john1701a
    12,840
    5,311
    58
    Again... That "6" was stirred in discussion because it was the mile-mark in the EPA test where there was a hard acceleration to highway speed, triggering the engine to run briefly.
    kWh available for electric-only driving = 11 miles
  3. bisco
    52,484
    exactly, so no reason op shouldn't be able to achieve 20 with the nexcell battery
  4. Mike SBP
    Mike SBP New Member
    Chehalis WA
    I checked my trip gauge and I am getting 100 mpg on 1364 miles. It's hard to calculate how many KW I have poured in to the system, but at local electric rate of 7 or 8 cents per KW, this has to be a good deal. I assume we will all be mostly driving full EV cars within a few years. The war on Iran has done a lot to promote EV or plugin hybrids with some decent "drive around town" range. We thought about going full EV this time, but decided to go with the plug in hybrid.
  5. bisco
    52,484
    there are two consumption meters on the display that show ev percentage iirc.
    we moved from the pip to the chevy bolt after 11 years. it's a great gateway drug, and the '23 bolt was 23k new.
    7k less than we paid for the pip in 2012.
    BiomedO1 likes this.
  6. BiomedO1
    4,310
    2,260
    Left Coast
    Yep; people forget the TCO factor and don't realize how much more it's costing them by focusing in on only one thing...:rolleyes:o_O
    The more variables you can account for; the clearer the overall picture. ie. early Tesla adopters that paid over $100K for their cars. I personally know someone like that. He thinks that he'll breakeven some day and he's correct. He also spent $15K on a new battery a few years ago too. Told him that really pushes back your breakeven point......o_O
    #26 BiomedO1, Apr 21, 2026
