Dangerous Heatwave & A/C Died
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid Hobo, Jul 5, 2026 at 4:17 PM.
  1. Hybrid Hobo
    Hybrid Hobo Member
    215
    New Jersey
    I posted about 2 weeks ago that my climate control was making odd noises. But it was still blowing ice cold and working fine.
    Based on the lack of responses to that post, I wrote the noises off thinking I might be making a mountain out of a molehill.
    But the noises got worse & worse over the course of the next 5 or 6 days, until the a/c started blowing hot air on the 27th of June.
    To say that it has been a TERRIBLE week would be an understatement. I've gone though the worst heat wave in 20 years while living in my car with no a/c. Had to check into a motel for a few days as my health was suffering.
    I've been to 3 mechanics thus far...
    The first shop did a diagnostic and found nothing wrong. Pressures were good, etc. This was probably because the a/c was still blowing cold at that time, and it was also in a shop out of the harsh sunlight, so the load/strain was much less (no noises).
    The a/c died the next day.
    I then bought a used compressor and had a second mechanic install it for me, along with putting in new freon. He initially told me that the compressor wasn't working, but when I picked the car up the next morning he said that everything was fixed! It was blowing freezing air while in the shop. This mechanic also said that my "low switch" was disconnected and that "might have" been the problem. About 20 minutes after leaving the mechanic the a/c started blowing warm again...like heater level warmth.
    Took it to a third mechanic who said that - based on everything I explained - it could be the expansion valve. He replaced the fuel filter (strainer & cotton pad) and upon inspecting them, we could see tiny metallic particles on them. This is when we started to think that the system grenaded. Which might explain the very loud noises I heard before the a/c went hot.
    He checked the pressures on each line and they were way out of whack and acting unusual. So he tried vacuuming/flushing the lines out to remove any debris in case there was a clog or to remove any of the metallic particles. This did nothing.
    Today, he replaced the used compressor with a brand new one. He also vacuumed/flushed the lines again for a longer duration this time, to hopefully get any residual debris out of the system, along with removing the old freon and adding a new batch.
    His thinking was: Let's try a new compressor first. If it works, great. If not, odds are high that it's the expansion valve.
    After completing all of this, the pressures were both stable and normal this time. We started the car, and, once again, the a/c was blowing ice cold. However, within 15 minutes of leaving his shop it was blowing warm, just as it did before.
    This debacle has cost me almost $1,000 and I'm still stuck at square one.
    If it's the expansion valve, there's no way I'm getting that done. It's a tremendous job that requires 6-7+ hours of labor, in addition to the parts.
    Is there anything else that this might be aside from an expansion valve?
    The likelihood of THREE compressors being the culprit are astronomical (my original, the used one I bought, and the new one installed today).
    Not sure if there's anything else that I can check, or if I should just sell the car as-is because I'll be moving into my camper soon.
    I'd very much like to have the comfort of a/c over the next 5-6 weeks before the Prius is sold, as this heat is dangerous due to my health issues. And selling the car sans a/c will cost me a lot of money because I'd have to reduce its price by a lot.
    Thoughts, please.
  2. JC91006
    JC91006 Senior Member
    16,930
    8,640
    You probably have a failed inverter coolant pump, that shuts down your ac when the car gets hot. You can check if the pump is working by having the car in ready mode and look into the inverter coolant reservoir, see if the fluid is agitating/moving. If the coolant is not moving, then you just have a failed pump
    Hybrid Hobo likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,384
    5,408
    Pacific Northwest, USA
    Because the mechanics are making assumptions based on pressure I'm thinking all of them need to give you a full refund because its a variable pressure system and the amount of refrigerant they added is supposed to be based on weight not pressure. If the weight is off by only an ounce or two you can kill the compressor.
    If I were you I'd very carefully ask questions to get the mechanics who worked on your car to admit they added refrigerant based on pressure not weight. If they say the pressure looked fine and you ask about exact weight of refrigerant and they can't tell you exact number then you caught 'em. If you document that admission then you can raise hell with the manager/owner of the shop and get a full refund(s) or get it fixed free of charge.
    As for lack of comments about your concern with AC noise, it's fairly common for an 18 year old Prius to not sound so great with HVAC system so its hard to be helpful in that regard.
    #3 PriusCamper, Jul 5, 2026 at 8:09 PM
  4. Tombukt2
    13,796
    2,500
    Sounds like when the AC is on you're making cold air what's happening after that is issue as stated above the AC has to be maintained by the inverter system etc anything going on in those systems can render you with no air so!. All of those other things need to be maintained and verified working . . It's really hot join the two water hoses at firewall so no heat present in cabin possible . Will need to be reconnected at winter but this only takes a second you'll barely even lose a half cup of coolant . But in a high heat area this can keep the heat out of your cabin
  5. Hybrid Hobo
    Hybrid Hobo Member
    215
    New Jersey
    To address the responses thus far...
    *All mechanics measured the amount of freon by weight. This I can confirm 100%.
    *After both compressors were installed (used & new), all of the loud moaning, vibrating, and droning noises have disappeared.
    *The a/c was working well, and blowing ice cold at all mechanic shops prior to leaving, and remained so for roughly 20-45 minutes after leaving. Then the air would turn warm again. This seems to happen once the car becomes stationary, but there might be no correlation there.
    *No warning lights or codes are being thrown. This makes the inverter cooling pump idea that someone mentioned less likely IMO. But I'll check that out tomorrow. I replaced my inverter cooling pump 2 or 3 years ago, and I did get a warning light & code at that time.
    *The filter basket and cotton filter tied to the original compressor were both taken out and inspected. The cotton filter thing (that looks like a tampon) was literally black on one end. From what I was told, it is not supposed to look like that. The tiny filter cup/basket appeared to have itty bitty metal filings/flakes on the screen, as did the cotton piece. This is what led the mechanic to think that the compressor grenaded and compromised the entire system. That might explain the harsh, worsening noises before the a/c failed.
    *After removing the used compressor today (so we could install the new one), the mechanic emptied the oil to see what it looked like. It was a gray metallic color, like mercury. He said the oil should be a dark honey color. He pointed to this as strong proof that the system was corrupted by metal due to the grenaded compressor.
    *The mechanic vacuumed/flushed the lines 2 times in order to clear any debris/filings from the system, in case his grenaded compressor theory is the cause. The hope was that once the lines were cleared (even mostly so) with a new compressor added, that the a/c would work correctly.
    Things we'll be checking tomorrow...
    Inverter cooling pump (just to be sure)
    Cooling fans
    Clogged condenser exterior. The outside of the condenser might have debris, which can easily be cleaned. Conversely, if the inside of the condenser was corrupted by a grenaded compressor, this would be very difficult to clean and would likely need to be replaced.
    If any of the above 3 things aren't the culprit, the likelihood of it being the expansion valve is very, very high. At that point, I'll simply sell the car sans a/c and take a hit on the price.
    I don't have the time or money to keep investing in this issue. So hopefully we'll catch a break tomorrow and find the cause.
  6. Tombukt2
    13,796
    2,500
    The things you want to know are when this no cooling business starts does anything change on the gauges that should be connected to the high and low side of the system just for monitoring. If that fat silver hose is cold . Then the the car should have same coming out of some vents in that car . If the heater hoses on the firewall are joined together with a small piece of pipe I believe it's 5/8. Then you know no heat can be in the car just for summer . Mite help .
  7. rjparker
    10,964
    6,877
    Obviously the radiator fans have to be running anytime the ac is on and the car is not moving. An easy check.
    Has anyone actually verified there is no refrigerant leak? A big leak would have similar cooling when recharged and no cooling soon after. You should observe the sight glass next to the H access point when it is trying to cool as an easy no tool check. Solid column of liquid flowing is good, foamy bubbles is low refrigerant, no fluid movement is compressor failed or no refrigerant.
    Its best to see the sight glass when full and good ac to compare. This was 5 oz low.
    If the heater air blend door has failed, you would get cold ac with the engine is cold but the vent air would warm up as the engine warmed up.
    If it does not blow cold with the engine cold, the heater hose bypass is useless.
    You can also feel the difference in air flow as the blend door opens when set to max heat and then closes when set to max cool.
    The same logic applies to an inverter ac shutdown due to excessive inverter coolant temperature. When cold it should work and if too hot it should code.
    Assuming a compressor grenaded, the condenser is first in line followed by the receiver dryer mounted vertically on the right side of the condenser. Then its the expansion valve under the dash just in front of the evaporator.
    If dryers and expansion valves get clogged a flush does nothing because both have very small openings.
    Expansion valves are always changed after destructive compressor failure. Often condensers are also changed.
    #7 rjparker, Jul 6, 2026 at 12:47 AM
