Anyone ever deleted, and re-installed the software for Gen 4 Prius ?
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Jul 7, 2026 at 3:41 PM.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    425
    169
    Sacramento CA
    2019 Prius
    So I have had an ongoing issue with my 2022 XLE almost since new !
    I've talked about it on here many times.
    An AI overview pretty much spelled out my issues, word for word (in a nutshell, all kinds of false alarm pop up messages and such). The only thing that actually fails when the car is showing these messages is cruise control.... which is a big bummer, as I use cruise control a lot.
    The AI overview actually told me that their was a recall on 2022 XLS's.... but Toyota says that was in earlier 2022 production models, and my VIN # was past those, so they think they had already rectified this before mine was built.
    Well I'm sorry, but they did not. My car was screwing up since almost new, so what about warranty, right ? Nope. Toyota insists that my aftermarket stereo and alarm "could have" caused the problem. I even disconnected all of my aftermarket stuff, but they say, that's not enough, as it might have caused the problem when it was hooked up. {BTW, I had my alarm and stereo put in the first week I had it, and it didn't start all of this until 2 months later}.
    Anyway, this is where this story gets kind of stupid IMPO. So I asked Toyota, "Okay, so lets say that I were willing to pay to have my software re-flashed, how much would that cost me ? They told me between $300 and $400. Honestly, that's not a terribly huge amount (although it would be zero parts... and only like 20 minutes of labor) and again the principal of the matter > that Toyota should absolutely cover this.
    But then they told me, "Oh, and if we do this job, we cannot be responsible for the rest of your computer / electronics system.... So if that fails, it's on you".....
    WAIT ! Hold up.... so a multi-Billion $ corporation is willing to take my $300-400, but if that job fails, its on me ??? Honestly, this just sounds ridiculous ! Is this really how Toyota handles business ?
    Curious to hear some opinions on this matter. Thank you.
    PS, A person might ask.... "Well if it doesn't actually affect anything (besides cruise control), why would I go through all the trouble.... and risk" ? Well, in 1-2 years, my car is going to need to be smogged (in California) and if it has all kinds of warning codes, including hybrid system malfunction, its not going to pass, and I won't be able to register it :(
    #1 Chris Wolfgram, Jul 7, 2026 at 3:41 PM
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Have you tried disconnecting the 12v battery for a few minutes to do a full reset? You will have to redo the radio presets and cycle the electric windows, but the reset should clear the codes and hopefully they won't come back.
    JeffD
  3. Chris Wolfgram
    425
    169
    Sacramento CA
    2019 Prius
    I actually replaced my 12 volt battery a few months ago, so yes I did.
  4. BiomedO1
    4,502
    2,360
    Left Coast
    A decent smog shop doesn't care. As long as the CEL is OFF, all emissions systems are green, you haven't tampered or modified anything in the engine compartment - you should pass. They are focusing on pollution control; so if the car runs clean you should be OK.
  5. Chris Wolfgram
    425
    169
    Sacramento CA
    2019 Prius
    Unfortunately, all of my emissions systems are not green, as one of the messages is, "Hybrid System Malfunction" :(
  6. Mendel Leisk
    42,250
    Someone on Reddit with a Corolla Cross was complaining about a password prompt popping up repeatedly, on their touchscreen. While they're driving. Makes me increasingly enamoured of my venerable '10's screenless dash
  7. BiomedO1
    4,502
    2,360
    Left Coast
    Reflashing the firmware isn't going to take care of the "hybrid system malfunction", unless the underlying problem has already been addresses and taken care of. Depending on the level of the error; it should clear itself after passing a couple of test cycles. If the problem passes one test cycle, then fails another - the error code will remain.
