XM Installation instructions
Discussion in 'Gen 2 Prius Audio and Electronics' started by mgundel, Feb 25, 2007.
  1. mgundel
    mgundel Junior Member
    57
    Richmond, VA
    Finally broke down and ordered the Toyota XM kit from Metro TPN and wanted to pass along some simplified install instructions to anyone who may want to tackle this. I started by using the instructions linked HERE and quickly realized they are not completely accurate for an 06 (and probably an 07). I logged into Toyota Info Services and was able to get the official instructions which require much less dash disassembly and a very secure install placement of the receiver. I don't see any copyright info on the document so I thought I would share it.
  2. svbb
    svbb New Member
    27
    Great post, thank you!
  3. CheapChic
    CheapChic New Member
    40
    <div class='quotetop'>QUOTE(Martin Gundel @ Feb 25 2007, 09:32 AM) [snapback]396172[/snapback]</div>
    hI
    I have an 07 with Navi. It is suppose to be XM ready. Is ther a different kit that is easier than this.
    thanks
  4. mgundel
    57
    Richmond, VA
    <div class='quotetop'>QUOTE(CheapChic @ Mar 1 2007, 10:11 AM) [snapback]398441[/snapback]</div>
    XM ready only means that the head unit will display the feed provided by an XM tuner (purchased separately). You'll need a satellite tuner, antenna and subscription to listen to satellite broadcasts. The install for this wasn't overly difficult. Once I got the right directions, it only took about an hour and a lot of that time was because I actually fed the antenna through the roof instead of onto the dashboard.
  5. PaladinSF
    PaladinSF New Member
    <div class='quotetop'>QUOTE(CheapChic @ Mar 1 2007, 07:11 AM) [snapback]398441[/snapback]</div>
    All the satellite radio installs present the same problems and some seem to work better than others. I just had the Toyota XM installed in my 07 by a dealer. It did not seem worth the grief to do the install myself. I works great. The only negative is that it does not show the artisit or title- it only shows the channel and genre. I guess I need a lock pick3.
  6. CheapChic
    40
    <div class='quotetop'>QUOTE(PaladinSF @ Mar 1 2007, 11:20 PM) [snapback]398876[/snapback]</div>
    Hi
    Do you have the Navi ? No artist no title, I will get a portable with aux input instead
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    <div class='quotetop'>QUOTE(PaladinSF @ Mar 1 2007, 10:20 PM) [snapback]398876[/snapback]</div>
    On the '04/'05 it shows the artist and title....in fact on the '06/'07 I believe it's supposed to show more characters than the prior version....If you hit the audio button, then touch the button for the channel you're listening to does it not bring up another page that shows the artist and title?
  8. scott.sutliff
    scott.sutliff New Member
    <div class='quotetop'>QUOTE(efusco @ Mar 2 2007, 10:10 AM) [snapback]399045[/snapback]</div>
    Thanks for the info. My salesperson at the dealer said there was NOT an XM package and told me to go to an electronics store for installation. If i am reading right, i could get a Toyota installed kit for XM.
    Correct?
    Thanks much.
  9. airliner53
    airliner53 Junior Member
    17
    Thanks for the post!
    I printed out the instructions, and the first thing I noticed was that it says "Premium Audio/JBL required".
    I have the base radio ... No AM/SAT button ... just an AM button. I thought I remember reading somewhere that it will still work, that you will just use the AM button to access XM.
    Anyone know anything definitive on that issue? I would love to have XM!
  10. jobob
    jobob Junior Member
    Hi airliner. I just got my base 2007 and the dealer put XM in it. As mentioned earlier, i only have an AM button, but after you push it, you have access to SAT1, SAT2, and SAT3. works great with the only problem being the 10 character limitation.
  11. airliner53
    17
    <div class='quotetop'>QUOTE(jobob @ Mar 6 2007, 12:34 AM) [snapback]400704[/snapback]</div>
    jobob -
    Thanks for the info ... by the way, did they install the antenna on the dash or on the roof?
  12. TonyM
    TonyM Junior Member
    <div class='quotetop'>QUOTE(Martin Gundel @ Feb 25 2007, 08:32 AM) [snapback]396172[/snapback]</div>
    Martin,
    Thank you for the PDF file. I used it this morning to install my kit in my '07. Went off perfectly, had it installed in less than 1.5 hours.
    I'm amazed at how the dash is assembled..... :unsure:
    Thanks again, it made my install a snap and saved me the $ of having someone else do it.
  13. BethlehemPrius
    BethlehemPrius New Member
    180
    Bethlehem, PA
    <div class='quotetop'>QUOTE(PaladinSF @ Mar 2 2007, 01:20 AM) [snapback]398876[/snapback]</div>
    I had them install an XM unit in my car and it displayed the full artist and title, not sure why yours would not be showing it, but I would have them fix it.
  14. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Great Post! Thanks! This seems like a lot less disassembly then the one I previously read. One would think these would apply to the 07 version as well, anyone know for sure?
