AUX-POD for 2004 Prius?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Bruce, Jul 15, 2004.
  1. Bruce
    Bruce New Member
  2. eak354
    eak354 Member
    447
    HI
    sure would be great if it's integrated with the MFD! i won't be surprised if someone came up with one.. :mrgreen:
  3. Bruce
    Bruce New Member
    Yes! I would pay a good chunk of change for integration that slick. I hear Alpine is the only one with plans for display integration with ipods however. And that's only for their display, I doubt the builtin MFD would be used. Sigh.
  4. bbangert
    bbangert New Member
    I'm not too concerned about the MFD integration, as I prefer using the actual iPod interface, I doubt anything done on the touch screen can replicate the ease of navigating a large collection quite like the iPod's touch scroll wheel.
    I do plan on getting one of these to use with my #9 Prius, I've noticed that other people have either had problems or been told various interfaces will only work with non-#9 Prius's. I'm wondering if this is because they make the assumption that you still actually want to use the in-dash CD player.
    I have no interest in using the CD player, so if its plugged in using Toyota's standard harness, I see no reason I couldn't just unplug that and plug in either the AUX-POD or the AUX-BOX. Anyone know if this is the case? Or does the #9 have some strange non-standard harness?
  5. aarons12
    aarons12 New Member
    704
    long island, NY
    i believe (though i don't own one so i'm not 100% sure) that the ipod has a unique interface. i have a nomad jukebox zen, sort of similar without the cachet and the price, and it has a standard 1/8" output jack and USB... but there aren't enough of them that somebody will be designing a special interface for it.
  6. bbangert
    bbangert New Member
    That's why the purchase of either the AUX-POD or AUX-BOX is needed. The AUX-POD interfaces with 2nd generation iPod's, then plugs into the car's stereo unit via a harness. The AUX-BOX simply has stereo RCA jacks to connect any device with RCA output to your stereo.
    All they need to get the music into the stereo, is the appropriate wiring harness. This post in another thread on this forum is from a guy who is selling his 6-disc CD changer that was installed in his Prius. He didn't have the #9 option I believe, so I'm not sure if this is the same that is in the #9. If it is, and if that is the standard Toyota wiring harness (a lot of if's), then the AUX-POD/BOX should work in the #9 Prius assuming you don't care about not having your 6-disc CD player plugged in. ;)
  7. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    I'd be happy with any aux input. Still waiting...
  8. Jonathan
    Jonathan New Member
    74
  9. ipod2car
    ipod2car New Member
    yea, like jonathan said ssiamerica.com has an aux input or if you want to control your ipod u can go to www.ipod2car.com same pricipal as aux in - hooks up to changer port in place of changer but lets you control the ipod from the prius radio.
  10. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    CD Changer port available without JBL changer?
    Hello,
    Does anyone know whether there is a CD changer port on the back of the head unit, if you ordered the package without the 6-CD changer?
    Anyone know if the radio is "satellite ready", (i.e. has a satellite port beneath the CD changer port?
    Thanks for your help,
    Ryan
  11. Jonathan
    Jonathan New Member
    74
    Yes, there is a CD changer port in the back of the single disc changer. I used it yesterday to plug in my aux-neo box for my non-Ipod mp3 player. I did not see a satallite specific port however. Check out the roady2 for XM it's already got the reciever in it and it's smaller than a deck of cards $129. Took me 30 mins to install.
  12. aarons12
    aarons12 New Member
    704
    long island, NY
    <div class='quotetop'>QUOTE(Jonathan\";p=\"41020)</div>
    i already have the changer in my car. anybody know if there is a port on the back of that unit that will accept the input from the aux-neo? sounds pretty cool as it would let me use either XM or my MP3 player...
  13. mlr848
    mlr848 New Member
    You mentioned the installation took about 30min. You had to remove the radio to get at the CD-changer port? Where did you look to for instructions on how to do this?
    Was thinking of buying the iPod2Car but I am not sure if I am up to install it myself. Or if my local Toyota dealer should/would install it for me.
  14. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    Re: AUX-NEO BOX?"
    What is the AUX-NEO BOX? I have the AUX-BOX. What is the difference?
    Where did you get it and for how much?
    Thanks. I am also interested in hooking up my non-Ipod.
    Ryan
  15. Jonathan
    Jonathan New Member
    74
    Keep in mind that the part from Toyota needed ($18) is a Y-cable and may allow you to use both, though, as one guy said, you don't need a changer if you've got an MP3 player with you..?
    Check out ssiamerica.com for the input.
    <div class='quotetop'>QUOTE(aarons12\";p=\"41035)</div>
    [/b][/quote]
  16. KaniS
    KaniS New Member
    <div class='quotetop'>QUOTE(Jonathan\";p=\"41871)</div>
    ssiamerica sells the Neo box, which is what I purchased (and waited 3 mos for them to fix to work with the Prius). The original poster was asking about the PAC aux box, which looks very similar, but seems to be a different company. It is also cheaper, and available from www.cardomain.com.
    BTW, I just released my 2004 Prius stereo accessory installation guide. It steps you through disassembling the dashboard to install devices like the Neo (aka ipod2car) or the PAC box.
    Guide is here: http://www.chrisdragon.com/prius/
    Have fun!
  17. knowledgeseeker
    knowledgeseeker New Member
    57
    Walnut Creek, CA
    Very nice! (Accessory Installation Guide)
    <div class='quotetop'>QUOTE(KaniS\";p=\"42967)</div>
    The guide is extremely well done! It definitely belongs in the knowledge base, prominently. Thanks.
