Regression Testing Mileage vs Average Temperature
Discussion in 'Gen 2 Prius Fuel Economy' started by TonyPSchaefer, May 25, 2007.
  1. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    So I'm working towards my Six Sigma Greenbelt certification. I decided to perform a regression test using my mileage chart. Below is what I got from Minitab. There are some outliers in the cooler temperatures, but all in all I'm pretty confident that there is a direct correlation between average temperature and mileage.
    [attachmentid=8330]
  2. tochatihu
    tochatihu Senior Member
    9,753
    3,761
    Kunming Yunnan China
    2001 Prius
    Ahhh, polynomial regression with confidence intervals! Way to go, cousin Tony.
    But with temperatures based on oF, I am sure you can appreciate how this equation could 'blow up' at more extreme temperatures (esp. negative ones).
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    That would support my anecdotal evidence. Anything below 65deg and my milage starts to drop significantly. Above 80deg and I begin to have the ability to see 50+mpg using the same speeds and routes.
  4. TonyPSchaefer
    14,816
    2,500
    66
    I'm thinking that those outliers might be contributed to things such as highway driving versus city driving or even heater usage. Unfortunately for this example, I did not keep data on those items.
  5. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Tony,
    Do not forget about Humidity (less air drag) and Rain (more rolling resistance).
  6. berylrb
    berylrb Member
    308
    san francisco?
  7. bwilson4web
    16,187
    <div class='quotetop'>QUOTE(TonyPSchaefer @ May 25 2007, 08:29 AM) [snapback]449719[/snapback]</div>
    What is your average trip distance?
    My experience has been that longer distances and higher speeds reduce the temperature penalty.
  8. TonyPSchaefer
    14,816
    2,500
    66
    <div class='quotetop'>QUOTE(donee @ May 26 2007, 08:36 AM) [snapback]450362[/snapback]</div>
    I'm not going to minimize the possibility of interconnected variables. I simply did not keep records on the dry-ness of each day and humidity and barometric pressure. There is one data point in particular in which there were something like 7 rainy days of the 11 for that tank. The mileage is bad for that temperature.
    <div class='quotetop'>QUOTE(berylrb @ May 26 2007, 11:35 AM) [snapback]450428[/snapback]</div>
    It occurred to me a couple years back that my chart would be much more accurate if I tracked mileage on a daily basis. Then reality/life/sanity hit me. So I decided to continue simply taking records when I refilled.
    <div class='quotetop'>QUOTE(bwilson4web @ May 26 2007, 10:47 PM) [snapback]450647[/snapback]</div>
    It seems true that on long distance trips at highway speeds, the impact of ambient temperature is reduced. I can see that when driving from the north side to the south side of Chicago. My average trip is 20 miles one-way to work, taking approximately one hour.
  9. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    <div class='quotetop'>QUOTE(TonyPSchaefer @ May 26 2007, 11:56 PM) [snapback]450684[/snapback]</div>
    Wait!! You've been to the south side of Chicago, like south of Madison Ave., like south of US Cellular Field?
    I've seen no flares go up in the past couple of years :p .
    Wayne
    Who is currently relaxing in beautiful Estes Park, CO.
  10. TonyPSchaefer
    14,816
    2,500
    66
    The South Side of Chicago. You know, South of Oakbrook.
    :p
