1500 Mile Trip - 77MPH hwy - 25-55 MPH cty - 40MPG Average
Discussion in 'Gen 2 Prius Fuel Economy' started by bigmahma, May 29, 2007.
  1. bigmahma
    bigmahma New Member
    226
    Also did 2-3 stints of leaving the car on for 20-30 minutes and not moving for the air conditioning (baby needed to sleep while we went and did stuff)
    Am I on track?
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Your milage seem a little low but not strangely so.
    I don't do 77 mph regurarly
    If you do a lot of short "5 minute" city trips it could explain it. I tend to do a few short trips during the weekend (groceries, dog park, errands) and it really kills my mileage
  3. bwilson4web
    16,161
    <div class='quotetop'>QUOTE(bigmahma @ May 29 2007, 06:48 AM) [snapback]451390[/snapback]</div>
    Considering the speeds:
    Yes.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(bigmahma @ May 29 2007, 04:48 AM) [snapback]451390[/snapback]</div>
    You left a baby in the car alone?
  5. priussoris
    priussoris New Member
    1,005
    F8L, look at their avatar, the baby had a bottle of milk with him, so the baby was not alone! :)
  6. bigmahma
    bigmahma New Member
    226
    <div class='quotetop'>QUOTE(F8L @ May 29 2007, 12:55 PM) [snapback]451494[/snapback]</div>
    Yes - she was in line of sight of us. (about 10 feet through a window)
    I was fairly certain that she would be just fine.
  7. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Seems normal for the speed you were doing. It takes quite a bit more fuel to go 77mph vs 60mph.
  8. SomervillePrius
    944
    Somerville, MA
    Wow that graph shows a SHARP drop over 65mph!
    So doing 75 instead of 65 will make your mileage drop a lot!
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(bigmahma @ May 29 2007, 12:50 PM) [snapback]451620[/snapback]</div>
    Makes sense. It sounded much worse in your original post though. lol
    I sympathathize with the low milage. I doubt your weight is influencing much. I have aftermarket wheels and another 120lbs worth of stereo equipment in the car so we should even back out. I am goig to guess your speed is playing a big part according to the data I've seen. Maybe times yourself on a normal commute and see what kind of time difference there is between 77mph and 65mph. Maybe if the time difference is small enough it will give you more incentive to slow down some. I know it worked for me and now I cringe when I have to go faster than 65mph because of the flow of traffic.
  10. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    <div class='quotetop'>QUOTE(bigmahma @ May 29 2007, 07:48 AM) [snapback]451390[/snapback]</div>
    My much shorter 140-mile trip from northeast Baltimore to Southwest DC on I-95 pulsing and gliding between 65 and 78 mph with the A/C set to low and 78 F with 46/44 psi gave me 50mpg yesterday.
    So I think your experience is relatively similar.
