Driving it like a regular car, MFD off
Discussion in 'Gen 2 Prius Fuel Economy' started by craigk, Jun 30, 2007.
  1. craigk
    craigk Member
    139
    Golden Valley, MN
    My summer tanks have been 51-54 mpg (winter 40). I watch the MFD all the time and try for good mpg. I decided to see what would happen if I drove without watching the MFD, and even used the a/c a couple of times (only because I had passengers, otherwise it's sunroof only!) I drove my same city/highway routes, and was not as careful with the accelerator pedal (can't call it "gas" pedal??) After 380 miles I couldn't wait to look any longer and my tank average was 49.6mpg! I'm keeping it off for awhile, it was much more relaxing not watching the MFD all the time.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Congratulations, Craig. I often recommend to new drivers that they turn off the display to learn the feel of the car. Can you feel regen? Can you feel the ICE kick in? I'm still learning to glide by feel alone.
  3. craigk
    craigk Member
    139
    Golden Valley, MN
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 1 2007, 12:22 AM) [snapback]470902[/snapback]</div>
    Thanks Bill,
    I can definitely feel when the ICE kicks in and shuts off, I can only assume the regen when I'm in the condition where it should happen, can't feel it.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Now, go the other way. Install a tach and try keepin' 'er in the
    sweet spot range whenever it *is* running, and see how you do...
    It *is* actually useful to know when the engine is on or off; helps
    do more effective P&G.
    _H*
  5. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    <div class='quotetop'>QUOTE(hobbit @ Jul 1 2007, 08:42 AM) [snapback]470976[/snapback]</div>
    Hi Hobbit,
    I was told that the high efficiency range is when MPH is less than 2xMPG. While it has helped me improve my MPG considerably, I was wondering if you had some similar formula from your own experiences.
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    This is great advice. I followed the directions on Hobbit's page to install an inexpensive tach and it has done wonders for the FE driving experience. It has done wonders for my highway mileage in particular since I can now use the hills to keep the engine in the "good" RPM range. Lately I've been considering a cheap vacuum gauge to get the full picture. ;)
    Analog gauges mounted on top of the dash are much less distracting than an MFD-style readout. One glance and you've got your info.
  7. agron1979
    agron1979 Junior Member
    28
    I've had my prius for a week and I can not get better than 48mpg, still beats the 2000 LX470 I traded in that got a lousy 14mpg :eek:
  8. agron1979
    28
