Grand Unified Theory of High MPG-FE Hybrid Driving and Hypermiling
Discussion in 'Gen 2 Prius Fuel Economy' started by catgic, Aug 1, 2007.
  1. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    It's my understanding that you can't "save" those green bars once you get home. They go away and when next you start your car, you have to gain them again. So #1 is outa luck.
    Remember....you cannot buy coffee....you can only rent it.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    You realize that Einstein worked on his Grand Unified Theory pretty much until he died without success. Just sayin. :p
  4. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    <div class='quotetop'>QUOTE(dogfriend @ Aug 2 2007, 10:42 AM) [snapback]489237[/snapback]</div>
    Yes, and there are plenty of people still a huntin' for that final theory. It runs along the line of thinking that the human predilection for breaking everything down to its lowest common denominator or finding ways to explain life in a thirty second commercial spot or a thirty minute sitcom, can somehow be fashioned in such a way to do the same to the laws of physics. I wager that the universe isn't going to accommodate that wish.
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(Godiva @ Aug 1 2007, 06:20 PM) [snapback]488927[/snapback]</div>
    Out of luck? Why? Where does it say anything about "saving" green bars?
    It just says that maximizing MPG-FE generally requires avoiding using the battery as much as possible. Don't charge it, don't discharge it, unless absolutely necessary.
    IOW, pulse (accelerate at a rate that neither charges the battery nor draws from it) and glide (coast with the ICE off, and no regen or power drawn from the battery)
    I believe I've read that this is how the best MPG-FE has been accomplished so far, and as a matter of physics it makes the most sense to me.
    (sorry, had to defend my "theory")
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The car will work hard to keep sixpence in its little box in the
    back. Anything extra you get to spend, but anything less and you
    have to pay it back.
    _H*
  7. Danny Hamilton
    926
    94
    <div class='quotetop'>QUOTE(hobbit @ Aug 2 2007, 12:28 PM) [snapback]489369[/snapback]</div>
    If you don't spend it immediately and try to stuff some extra into the box in the back, a fee is charged both for the deposit and the withdrawl.
    Plus an additional fee.
  8. Earthling
    Earthling New Member
    441
    Somewhere, NY
    <div class='quotetop'>QUOTE(Godiva @ Aug 1 2007, 07:20 PM) [snapback]488927[/snapback]</div>
    I've had green bars in the morning, left over from the previous day.
    It's not all that often that I have green bars when I pull in my driveway...
    Harry
  9. Godiva
    10,339
    "If we knew what we were doing, it wouldn't be called research". - A. Einstein
