12 volts in the trunk
Discussion in 'Gen 2 Prius Audio and Electronics' started by mtissington, Sep 3, 2007.
  1. mtissington
    mtissington New Member
    What do I need to do to get a 12 volt socket in the trunk of a 2007 ?
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Simplest way is to buy a 12volt socket, and wire it directly to the battery with a fuse.
  3. qbee42
    3,079
    <div class='quotetop'>QUOTE(Presto @ Sep 4 2007, 01:55 AM) [snapback]506649[/snapback]</div>
    Since the 12V battery is under the cargo floor.
  4. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    something like this:
    Drill a 1 in. and 7/16 or 3/4 hole some where there is space. I used the spare tire tie downs cubby.
    Use a blade fuse holder and a spare blade to plug into the battery distribution box. There is an unused male blade in the distribution box in the 05. In this picture I used a 10A fuse with stranded 18 AWG wire.
    And then enjoy 12v from the trunk!
