Bluetooth Phone Question
Discussion in 'Gen 2 Prius Audio and Electronics' started by DPIStorm, Jan 7, 2008.
  1. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    Whenever I select someone to call for a split second I get a loud very audible BUZZ. The phone then functions as usual (over the bluetooth). Any suggestions on what is causing this -- and how to remove it?
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    I have a 2005 Prius with Motorola RAZR V3xx. I have no such problem.
    It is very likely your cell phone that is the culprit. Maybe it is time for a new cell phone?:D
  3. aaf709
    3,862
    2022 Prius Prime
    I have a couple of questions...
    1. What is your phone?
    2. What is your carrier?
    I have a Voyager with Verizon and it doesn't have that problem (neither did the Moto e815 before that).
  4. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    Its an Iphone, and I have Cingular.
    Anyone else know what im talking about? Or suggestions on how to fix?
  5. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    For the record, I unpaired, deleted both profiles, re-paired the phone, and the buzz is gone.
  6. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    Its buzzing again.... grrr.
    I'm curious if this is an iphone issue?
  7. jaysonbelt
    jaysonbelt New Member
    Long Beach
    I have an '05 pkg 5 paired with an iPhone and have the same issues. In fact, I just had to swap out my phone for a new one and the new one does it as well.
  8. DPIStorm
    DPIStorm New Member
    42
    Big Bad Los Angeles
    So its not just me! AHA!
    Probably part of a larger iphone issue then i'd assume...
  9. bc104
    bc104 Junior Member
    57
    New York
    I've heard on a twit.tv podcast iphones occasionally buzzing. I don't own one, but I think they do that.
  10. Ron K
    Ron K Junior Member
    61
    Yorba Linda, California
    No activity on this thread for a while. No anwsers?
    I had a Treo 680. Initially no buzz, then suddenly it began to buzz (loud) after the number was selected from 1 touch, until it started to ring. I have no idea why it suddenly started.
    Now I have an IPhone, same effect. Loud and annoying. So it's not an IPhone issue.
    Ron
