realy bad MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Flying White Dutchman, Mar 8, 2008.
  1. Flying White Dutchman
    4,376
    313
    today i drove 3 km and made a really bad 7,2k/100
    if i drive every day short trips then i better buy a smaller car
    so what can i do to make that better?
    i think i really need to make it plug-in SOON
    edit
    even wurst 7,8l-100 on 5 km now:mad: i try the heavy foot ( but no racing )
    ok i am feeling a bit under the weather wright now:rain:
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    You're probably right, if ALL your trips are short, you would be better off with a small conventionally powered car. However, you might have trouble even with that, you're exhaust system would rust out because it would not get hot enough to evaporate the water in it. Of course, if the weather's nice, you could just walk or bike that 3 km, your health would benefit greatly. An engine block heater would help you somewhat to decrease your car's warmup time, but for only 3 km, I'm not sure. My commutes are around 24 miles in 40 minutes, perfect for my Prius to give me over 50 mpg, this tank is 57 since the ethanol went away :)
  3. Flying White Dutchman
    4,376
    313
    normally i bike but i wanted to use the prius for elec drive that short:)when its cold outside:smow:
    mmm i was actual going to the gym:blush: lazy mee:couch2:
  4. qbee42
    3,076
    All cars do poorly on short trips. With the Prius, you have the instrumentation to see how bad you are doing. Walk, bike, or drive something electric if you can.
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    You'll see dramatically better MPG with an engine block heater for short trips.
    Ken@Japan
  6. Flying White Dutchman
    4,376
    313
    thx
    thats a good one!
  7. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    dutchman, u need a couple of variable resistor to trick the car into thinking its warmed up
  8. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    I see very few situations in which it's a good idea to "trick the car". I generally assume that the engineers who designed the thing made it act the way it does for a reason.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    You sound like the PERFECT candidate for an all electric car!
  10. Flying White Dutchman
    4,376
    313
    ;):p:D
    :car::peace::amen:
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Get an enclosed electric mobility scooter or a warm coat and some waterproof shoes.
