DVD upgrade and reversion for '04 to '08
Discussion in 'Gen 2 Prius Audio and Electronics' started by efusco, Apr 13, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I need somebody with a better memory or better search skills to help me out.
    CRickeyHirose has some '08 NAV DVDs for sale in the Private sales section.
    I'd love to update but seem to recall that the '04/'05 disks are not compatible with the '06+ disks. That you can get updates, but you have to order the specific part number for the '04/'05 MY which is different.
    Check my memory on that.
    Next, I'd need somebody smart with the right tools to make me a hybrid disk (I may have a local resource) since I definately do NOT want to lose my Easter Egg NAV override.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    You wont be able to use the 08 disk. You have to use an update for an 04-05. 06-08 can all use the same disk.
    I would offer to make a hybrid disk for you but I would have no way of testing it. If you could wait for Hybridfest I can make backups and hybrids discs with my cars PC. :D
  3. efusco
    19,891
    1,194
    Nixa, MO
    That's what I thought.
    Let's do that at Hybridfest!:rockon: Does that put much drain on the dilithium crystals?
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Cool. Not much drain. Takes about an hour to copy and an hour to burn. Its a slow burner. :(
  5. efusco
    19,891
    1,194
    Nixa, MO
    Not like there's a lot else to do during Saturday at the Fair anyway!:bored:
  6. whitslack
    whitslack New Member
    Gainesville, FL
    Those are gen 5 v07.1, meaning they are 2007 discs with 2006 map data on them. Calling them "'08 nav DVDs" is a bit misleading. As far as I have been able to determine, Toyota has not yet released version 08.1 for any generation of nav system.
  7. tkil
    tkil New Member
    158
