Question about the 6-disk CD changer
Discussion in 'Gen 2 Prius Audio and Electronics' started by Potential Buyer, Feb 23, 2005.
  1. Potential Buyer
    Potential Buyer New Member
    287
    Options AI, BC, and BG include a 9-speaker sound system with 6-disk CD changer, but the in-dash 6-disk CD changer is listed as a separate accessory. Does that mean the included sound system uses an external CD changer instead of an in-dash one (unless you also buy the in-dash one, of course)?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    If you buy a package other than one including the 9-speaker JBL then you will need to buy the external 6 disk changer if you want that feature....I think that's what you mean...it installs in the lower slot in the 'stack', so it is 'in dash', but it is not a built in component of the basic stereo.
    The deluxe package 6-disk changer is built into the unit and you still have that lower slot of the 'stack' empty.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Older add-on changers went in the console.
  4. Tideland Prius
    16,435
    Like Evan said, the accessory one is an external AND in-dash CD Changer. It does not use cartridges.
  5. y2kroxy
    y2kroxy New Member
    24
    <div class='quotetop'>QUOTE(DanMan32 @ Feb 23 2005, 11:25 AM) [snapback]66733[/snapback]</div>
    I installed the 6 cd changer PART # 08601-47800 with wiring harness PART # 08695-00370 in my new 06 PKG 3 type 2 MFD. Everything seems to work and the MFD recognizes the changer, however, I cannot see the Disc# or Track # of the CD changer on the MFD. Is this the case or do I have defective MFD or cd changer.
