2006 Prius data analysis
Discussion in 'Gen 2 Prius Fuel Economy' started by TheForce, May 24, 2008.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Since I have finally been able to get my can-view data captured and decoded I have decided to do some data analysis with my 2006 Prius. Unfortunately I don't know that much about excel or OpenOffice to create my own graphs yet so for now I'm leaving it up to YOU to sort through the data. I'm hoping someone will volunteer to make some graphs for me. I know Bob Wilson likes to make lots of graphs with lots of info in them. If your reading Bob feel free to do what ever you want with my data. :D
    Here is my current fill up log in ODS format. ( Current as of 2012-01-14 )
    http://stuff.jaygroh.com/priuschat/priusdata/PriusLog.ods
    I'm no longer going to make an XLS file.
    Electric usage statistics
    August 2008 to the end of the year.
    http://stuff.jaygroh.com/priuschat/priusdata/wudn2008.ods
    http://stuff.jaygroh.com/priuschat/priusdata/wudn2008.xls
    Here are a few files from my trips to and from work. These are in CSV format. The naming of the files are in YearMonthDate-24hTimeStarted.csv. There are about 45 lines of data for every minute captured if you want to know how long the trip was.
    http://stuff.jaygroh.com/priuschat/priusdata/canviewdataCSV1.zip
    Last few days of May 2008 in CSV format. Each file is a whole day of driving instead of a single trip. File name is YearMonthDay.csv
    http://stuff.jaygroh.com/priuschat/priusdata/2008MayCSV.zip
    June 2008 data
    There are about 7 days of missing data because my screen broke and I could not record the data. This zip contains the RAW bin files. You will need to use my V4+ decoder software found here to convert the data to CSV.
    http://stuff.jaygroh.com/priuschat/priusdata/2008June.zip
    July 2008 data
    July 16-17 are combined. July 31 I ran the tank down to %0 to get the E10 out of it.
    http://stuff.jaygroh.com/priuschat/priusdata/200807.zip
    August 2008 data
    Aug. 14th is where the Hymotion battery data starts.
    http://stuff.jaygroh.com/priuschat/priusdata/200808.zip
    September 2008 data
    I'm still on my first PHEV tank.
    http://stuff.jaygroh.com/priuschat/priusdata/200809.zip
    October 2008 data
    Firtst tank with PHEV ended on October 11th.
    http://stuff.jaygroh.com/priuschat/priusdata/200810.zip
    December 2008 data
    http://stuff.jaygroh.com/priuschat/priusdata/200812.zip
    January 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200901.zip
    February 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200902.zip
    March 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200903.zip
    April 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200904.zip
    May 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200905.zip
    June 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200906.zip
    July 2009 data
    http://stuff.jaygroh.com/priuschat/priusdata/200907.zip
    August 2009 data Last month of logs.
    http://stuff.jaygroh.com/priuschat/priusdata/200908.zip
    I will no longer be logging data unless I feel like logging certain situations. I will still be updating my fuel log when I fill the take up.
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I hope someone picks this up as I am interested in all thing Prius!
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Updated my fuel log and added can-view data for the last few days of May 2008.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I was just doing a little noodling over some other data sets
    last night, as an exercise in figuring out how to graph stuff
    in excel -- normally I hate all things microsoft but that's what
    the scantool runs under and it squirts out .csv files so I might
    as well do the reduction right there. I made good progress,
    although trying to determine any fine points between fuel burn
    rate vs. output power is being sort of indeterminate. At least
    I know how to apply simple formulas to new columns and control
    what goes into graph axes now.
    In your sets, what are the units for fuel flow? And where does
    the "vvti" figure come from and what are its units?
    _H*
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    My first set of CSV files are in metric units. My last few days of May are in US units.
    Fuel flow is from CAN message 0x38 in Liters/hr but converted to Gallons/hr. Not sure if this is the correct location for the data but I'm just going by what was originally written in Morris's decoder program and Vass's spreadsheet.
    Same thing for VVTi. I got it from CAN message 0x526. The VVTi value I get is the same that is displayed in the can-view.
    If you have a list of all the different data and its location in the CAN messages I would appreciate it if I could get a copy off of you. There are still some data points I would like to be able to graph out like IGN BTDC. I don't know if its included in the can-view dump because I don't have the location of the IGN information.
    Also you don't have to use excel if you don't want to. I'm using OpenOffice Calc to do work with my CSV files. I've been MS office fee for many years now. Now I just have to work on getting MS OS free. :)
  6. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Hobbit, Jay and I have been working together on this ... actually he more than I. ;) The tentative formula he has for the mystery fuel flow units and/or location seems to be in the ballpark. This is a (MS Excel) chart from a segment of my commute from earlier in the week:
    Using his gallons/hour calculation, I created an Excel formula to figure iMPG. The chart results are pretty consistent with my historical CAN-View observations of the RPM/MPH/iMPG relationship. I plan to cross-check the fuel flow formula tomorrow with CAN-View's displayed values.
    Now, as he suggests, it would be peachy if you have a handle on where in the data stream he can find ignition timing. Now that I finally have my CV data capture working, I'd like to analyze, among other things, the various operating parameters that folks are using in SHM.
    Jay, many thanks to you, BTW, for all your help on this! :first:
  7. hobbit
    4,089
    469
    Bahstahn
    That's sort of what I'm after, too -- more or less steady-state
    highway conditions > 41 MPH. Ignition timing can be queried,
    whether or not you know where it is [or not] in the passively-
    captured CAN chatter, it's just a bit slower data rate. I've
    found that if I try to hold a given set of conditions for some
    reasonable time [10 sec?] on the highway I can get reasonably
    consistent captures that match each other. Often the data for
    a given round of queries gets into weird edge conditions because
    running parameters changed over the window when a scantool asked
    for and received all the various parameters, but hopefully staring
    at a scatter graph allows seeing the basic trends and visual
    discarding of outliers.
    To me, the important params are RPM [usually used as my X axis
    in what I've been going over recently], injector time, measured
    ICE torque, and then maybe veh. speed and ignition timing. The
    first three allow calculation of power and fuel-consumption
    RATE, i.e. integrating injector times over RPM should give
    a figure that can be matched against (torque*RPM) to yield power
    and let time cancel out. But I'm not sure I'm calculating things
    quite right. I should probably convert everything to SI and
    take a wild-nice person guess as to "energy flow rate" based on roughly
    10 KWh or so of actual car-pushing energy available per gallon
    of fuel...
    There was also of course some recent stuff on the electrical
    side exploring boost voltage, but that's a totally different
    intent and approach.
    _H*
  8. bwilson4web
    16,129
    Sorry I haven't been able to help but let me offer a couple of excel tips:
    1. split "Y" axis scales - often we'll have more than one data values that when mapped on one scale make the other data look flat or throw it off the graph. To solve this problem, 'click' to select a graph line and then use the pulldown "Format" for "Selected Data Series" and choose "Axis" and select "Secondary axis." This will plot that data series on a new axis scale on the right. You can adjust it to have both sets of data displayed. I often use a special format like "lines and point" for data on one side and just "lines" on the other.
    2. insert gaps in graph - many times it is useful to have a 'gap' in a line to make it clear something changed. Just insert a blank "row" and a gap will appear in the line.
    3. careful about sampling errors - often some data points, say MG1 torque, can change very quickly and even polling ICE rpm adjacent to the MG1 torque can lead to 'impossible' values. For very dynamic data, consider 3-point averaging to reduce the effect. It can not be eliminated, just made "less bad."
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I added my data for June 2008 to the first post. There are about 7 days of data missing this month because of a screen failure. These files are in RAW format and need converted with my V4+ decoder software. Links are in my first post. All following data will be posted in RAW bin format so others can convert the data as they like.
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I added my data for July. July 16-17 are combined in to one file. July 31 I ran the tank to %0 to try to get as much E10 out of it as possible.
    I also updated my spread sheets for new tank data.
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    August data is now posted. Hymotion battery data begins on the 14th if anyone is interested.
  12. TheForce
    3,461
    537
    Wheelersburg, Ohio
    September's data is now uploaded. I'm still on my first tank with the Hymotion battery.
  13. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have posted Octobers data in my first post.
    I'm ending my data capture project as of October 31th 2008 because of technical difficulties. If I decide to start capturing again I will continue to post the data here. I may in the near future compile this data into a spreadsheet so people can more easily play around with the data. I will however continue to update my fill up log each time I fill up my car with gas. Since turning my Prius into a PHEV it may take months before the spreadsheet is updated.
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have updated my spread sheets to have a better layout for calculations.
    I created 3 sheets for my regular Prius, my PHEV, and the third sheet is averages, and totals. I would like to add a third page for graphs in the near future when I figure out how to make some nice ones.
    Please let me know if I can improve on my layout or calculations.
    You can find the link to both the ODS and XLS file formats in my first post.
  15. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have updated my spread sheets. I have added a few more things to the data sheet. I also added a graphs sheet but it does not have anything on it yet. I'm still figuring out how to make some good looking graphs.
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I am now continuing my data capturing since I have fixed my car PC issues.
    I have uploaded the last few days of December 2008.
    I have also updated my fill up log.
  17. TheForce
    3,461
    537
    Wheelersburg, Ohio
  18. TheForce
    3,461
    537
    Wheelersburg, Ohio
    January data is now posted.
  19. bwilson4web
    16,129
    Jay,
    The spreadsheet I downloaded has a lot of columns about electrical use but nothing that I could find that relates to miles or miles and fuel use. Did I miss something?
  20. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The electricity usage was strictly for charging stats. The data you see is from my Watts up .Net power meter which only monitors and tracks power from the wall.
