new 08 Prius w/pkg 5...getting dealer installed Sirius part # is pts31-47060 Question is what is the character limit of this? I've heard some are 10 & some are 16. If it's 10,which one is 16? Thanks? Jim
i do not know the character limits DO NOT BUY THIS UNIT tell the dealer you want the cheaper TOY-SC1 interface and scc1 tuner its a newer part and only $146 for the parts the dealer will probably want the $500 msrp to install the older pts31-47060 part
The dealer unit is limited to 10 characters. Buy the Directed Electronics TOY-SC1 and SCC1 for around $150, then install them yourself. It is easy and you will save a bunch. The only difference is the Directed Electronics version has a 16 character limit and you can't use steering wheel controls for changing presets, instead it changes channels.
1!! install either unit yourself. have done both. 2 hr max for novice. the toyota unit $260 allows all controls to work. 10 characters. having the controls work is the most important vs 10 or 16
