Milage - display vs the calculator
Discussion in 'Gen 2 Prius Fuel Economy' started by RadGash, Mar 14, 2005.
  1. RadGash
    RadGash New Member
    25
    While talking with a friend of mine, who owns a honda hybrid, he said that what his display told him his MPG was and what he calculated THE OLD FASHION WAY were two different things. He was actually getting far less than his display said. I have yet to try this (I'm an impatient guy) ... has anyone compared the milage stats in this manner? Also, I have had my car now for about 400 miles... will my milage improve as the car breaks in, or am I there already?
  2. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    I haven't found any significant difference between the display and my calculations.
    Everyone says that after you have driven about 5000 miles the car will be considered broken in and the mpgs will improve. I just hit 4800 and noticed an improvement after about 4600. Hang in there, it will get better. In the meantime, be sure to check your tire pressure and learn the fine art of coasting. There are a lot of discussions here on getting better gas mileage. Check them out.
  3. jkash
    jkash Member
    889
    West Hills, CA
    The difference between the display and calculator after 1 year and 12,000 miles was about 1 mpg. The display was higher.
  4. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    At 29,908 miles, my difference is 1.4 MPG.
    (Details are on my lifetime spreadsheet.)
  5. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    At 9000 miles my delta is 1.3 mpg. See my graph. The display is more consistent tank to tank. The calculated varies over a wider range (bladder changes, different gas pumps, etc.). Over time they end up within a couple percent, which is pretty good.
    The weather has been warming in Texas and my latest tank was over 57 mpg. My two lowest tanks were highway trips to west Texas with a full load in the car and a cold headwind in both directions!
    www.enerjazz.com/prius
  6. rflagg
    rflagg Member
    947
    Springfield, VA
    24k+ miles, difference between the two is less than 1MPG. I strictly follow the computer figures for figuring DTE (Distance to Empty) and have yet to run out of gas.
    -m.
  7. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I think if you calculate one tank, there might be a noticeable difference. Over the course of many, many miles and tanks, the difference is trivial. I won't say "nonexistent" but almost statistically insignificant.
    Like John1701a and EnerJazz, I invite you to look at my spreadsheet (in my sig) and see for yourself that in the end, it's not so bad.
    [Edit]
    Sorry, I misspoke there. I'm not showing calculated MPG versus Display MPG per tank. Rather, I'm showing an average of all MFD MPGs versus actual miles drivern divided by gallons consumed. Still, though, in the grand scheme of things they are pretty close.
    [/Edit]
  8. RadGash
    RadGash New Member
    25
    Thanks to everyone for your input. I was curious and am now relieved that the readout is pretty right on.
  9. Graz
    Graz Member
    179
    28
    I sure wish I could agree. But my displayed verses calculated is substantially different. Can't imagine why either. (see below)
    If anyone has any idea, I would be open to any comprehension.
    TIA
  10. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I find I am about 3% off, with the display being higher. Almost 2 MPG difference.
  11. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Last fill-up needed 10.53 gallons where the display told me 10.00 would be more appropriate.
    Seems like 5.3% inaccuracy on somebody's part.
    I crammed gas in last time, just like this time, so either this pump wasn't accurate or I need to REALLY stick to the 10x refill rule to be safe...
  12. darkpyro
    darkpyro New Member
    Chino, CA
    I too notice a slight difference between what the mfd says and thew old fasion way, however, I also noticed that when i refueled my new prius at the pump it only took 9.059 gallons before it clicked off. This leads me to believe that I had another couple gallons in my tank. Does this sound right? I stopped for gas very soon after noticing my gas bar was down to one blinking light. How much can one drive when gas is like this? My MFD at the time said 46 mpg and i had 414 miles since my last fill up. Could I have safely driven until i reached 460 miles? Lastly, are there any other warnings i could rely on aside from the last blinking bar?
    Thanks!
    -Andrew
  13. prius04
    prius04 New Member
    1,161
    NorthEast USA
    As with almost all above, I've stopped calculating my MPG the old fashioned way when my first 10 tanks revealed that the difference was about 1 to 2 mpg off, with the display always higher.
    As TonyPSchaefer said above, the numbers may be different when you compare one tank to the display, but when you average them out, the display is pretty predictable, albeit slightly higher than what you are really getting.
    Graz, is your difference predictable and consistent? If so, there may simply be a software glitch. You seem to have a problem that most of us don't have.
    And 25 points for your sign off:
    Limit your funding of international terrorism!
    Drive a hybrid.
  14. Frank Hudon
    Frank Hudon Senior Member
    4,147
    after one year my lifetime is 3 mpg lower than the MFD. Canadian gallons in US gallons that works out to 2.5 mpg lower. Pretty close to what Dan figures. I chalk it up to bladder effect and pump volume inaccuracy.
  15. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Mine has been more optimistic than most. At current, I'm still showing a 3.4 mpg difference over the lifetime, with the MFD being higher. Mine's an 03, so I don't know what software changes Toyota may have made when they reworked the system.
  16. silly
    silly Junior Member
    49
    Jacksonville, FL
    I've had my Super White since 11/2004 and have driven 8,124 miles. So far the car's displayed MPG is 1.55 MPG optimistic.
  17. Frank Hudon
    4,147
    I blame most of this on pump inaccuracy/flow corrected to 50F and to a lesser extent the Bladder effect.
  18. propking
    propking New Member
    33
    Pineville, Louisiana
    Well for me, the numbers really don't matter. B.P. (Before Prius) I was only getting aroung 18MPG, so even if I averaged 36 MGP (twicw what I was Getting) I would still be happy beyond belief. I could sit here and complain about a 1 to 2 MPG difference but I just think of the time B.P.
