How to close windows automatically on door lock?!
Discussion in 'Gen 2 Prius Audio and Electronics' started by SillyBilly, Jan 18, 2009.
  1. SillyBilly
    SillyBilly New Member
    Moscow
    Hiya. I'm used to use a car that rises all the windows shut on door lock. Unfortunately my Prius does not!
    Is there an easy hack to do this? I'm not going to modify Priu's REALLY complicated schematics with an aftermarked solution, for sake of reliability. The car does have everything needed for this - smart doorlock system, and smart power window system, - we need only some jumper in between... :rolleyes:
  2. qbee42
    3,079
    It's a standard feature on the 2010, but that doesn't help you. It is not configurable on the current Prius. There are, or were, some third party options for making this happen, but I don't know the details. It has been discussed here many times, so you might want to search.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Closest I recall is the Gen 1 Prius could use the key lock on the driver's side to open/close the window by turning and holding the key one direction or the other.
  4. SillyBilly
    Moscow
    One of colleagues here in Moscow told me that his NHW-20 beeps and refuses to lock the car unless all the windows are shut. Mine doesn't. Does yours (prior to '06)? This would completely satisfy my Altzheimer's...
  5. SillyBilly
    Moscow
    Hm. Didn't find any. Could you feed me the link please?.. :rolleyes:
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Mine will lock with the windows down but it wont if a door isn't closed. You friend may have confused this, maybe. But, I should add, I don't have SKS.
  7. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    I believe your only option is to wire in an aftermarket module, such as the DEI 530T, or Autopage AC-78.
  8. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I don't know about the European models, but the US model has only the driver's window as "smart" (auto up/down). Although, electric, the rest are manually controlled. As said, there's no simple hack.
