Homelink question
Discussion in 'Gen 2 Prius Audio and Electronics' started by mr5150, Apr 24, 2005.
  1. mr5150
    mr5150 New Member
    I got my homelink to program...I think. It seems to take about 5 seconds to activate the garage door opener, whereas the factory opener is almost instant. Is this normal? I've tried reprogramming several times with no change.
    Thanks, Larry
  2. catsbox
    catsbox Member
    295
    Bellevue, WA
    I had the same problem. I changed the batteries in my old opener then re-trained the Homelink, and all works fine. I notice I do need to hold the homelink button down for a bit longer than I did for my old opener.
  3. Steve Goldenberg
    Steve Goldenberg New Member
    126
    Aspen, CO
  4. mr5150
    mr5150 New Member
    Thanks...worked great.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Anyone using the HomeLink for X-10 control? Success? Problems?
  6. Steve Goldenberg
    126
    Aspen, CO
    I use it in CO for just the garage door but in MA I set up my daughter's Homelink to turn on/off exterior and interior X-10 lights. I may have had to teach it several times but evenually it worked and it still does.
  7. jeromep
    jeromep Member
    827
    Eastern Washington State
    I find that the signal strength of the homelink unit much better than any of my remotes, even with a full battery on them. So, even though I have to press the button longer for it to send a signal, I can do it farther away from my house than usual which means the door is fully open by the time I get to my drive way and I don't have to stop and wait for the door to open.
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Same here! Yahoo!
  9. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Bill Merchant\";p=\"87082)</div>
    Yeah, I'd like to know too. I have one set for my garage door and one set for my parent's garage door and was wondering what to do with the 3rd. Someone suggested getting an X-10 to operate the porch light, which would be nice (although I don't see one for a wall switch).
  10. fishinmyeye
    fishinmyeye Junior Member
    The signal strength of my homelink appears low. When I am inside the garage (under the garage's sensor) it works without a problem. But when I come home, it seems the homelink signal is not powerful enough to send the signal through the garage door. I then have to fish around for the original remote opener which works fine.
    I have already tried to reprogram the homelink after putting fresh batteries in the original remote, but no improvement.
    Anybody have any suggestions, remedies or run into a similar problem?
  11. lordbah
    lordbah Junior Member
    52
    Rochester, NY, USA
    There's no change to make so we can just press and release the button rather than having to hold it for about 2 seconds?
  12. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    Maybe the antenna was loose or missing on the receiver end?
