50+ MPG -- A Newbie's Quest
Discussion in 'Gen 2 Prius Fuel Economy' started by Rokeby, Mar 25, 2008.
  1. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    July 4 Weekend Drive; 59.4MPG
    We've just returned from a ramble up I-95 through the Middle Atlantic States
    and return.
    Details:
    * Fri, July 4: Ballamer to Suffolk County, Long Island, New York -- 250 mi,
    speeds ~60 MPH, Temps 72-84 deg F, 59.4 MPG
    * Sat: Drive-about Eastern Long Island, surface roads, traffic lights, four
    start-stop legs -- 76 mi, speeds mostly ~50 MPH, temps 68-82 deg F,
    59.4 MPG
    * Sun: LI to Ballamer -- 250 mi, speeds ~60MPG, temps 68 - 84deg F,
    59.4 MPG. Note: First use of Cruise Control (CC).
    Comments:
    * While the 59.4 MPG is not startlingly good, it is the best I've achieved at
    50-60 MPH, over an extended distance. Best previous over this ground was
    57.4 MPG, IIRC. I'm feeling pretty good about it. My lifetime MPG is now up
    to 49.5. (MPG readings from SCANGuage, three separate daily trips.
    * Long Island is an extremely good area for getting high MPGs; almost
    flat, long, low rolling mini-hills, typical Posted Speed Limit (PSL) on
    secondary roads 50MPH.
    * In Ballamer, 87 octane gas/petrol has been stuck at $3.99 US for three
    weeks or so now. Gas on the NJ Turnpike was also $3.99. On LI, gas was
    between $4.29 and $4.49.
    * Almost all drivers were driving at or within -5 MPH of the PSL; 65 MPH
    on the NJ Turnpike. Very few "rocket men," and those mostly SUVs, in
    denial I guess.
    Although we've had Amapola for 6 months and ~7K miles, this was the first
    time I used the CC. Why? On one hand I wanted plenty of time to learn the
    high-mileage discipline and tricks. On the other, that little stick with all the
    writing and arrows on it was intimidating. It was however, from the
    beginning, my plan to use CC on the return trip. I'm afraid that the results
    don't say very much. On this pretty much flat route, either I'm as good as
    the CC, or the CC didn't do any better than me... a toss-up as far as MPGs
    go.
    But, I must say, slipping along with the CC on was a much more relaxing
    and enjoyable way to roll up the miles. I expect to use CC on long trips
    where the topo is relatively flat from now on.
  2. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    Re: July 4 Weekend Drive; 59.4MPG
    i've just read through this entire thread ... i can hardly wait for our Prius to come in, so i can start "practicing" even HALF of what you've discussed here; along with several items that others reading this thread have tossed into the mix!
    and congrats to you on the GREAT results from your "July 4 Weekend Drive" ... it seems "59.4 mpg" was the correct "answer" for all questions posed!
    "in denial" Rokeby presumes; oh ... it is to laugh ....
  3. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Congrats on the high MPG trip!
    On the Cruise Control issue/question: I've always been a fan of cc, but I have very rarely used in on the Prius. I think this is because I am so engaged in driving this car. I really enjoy it, and I don't like anyone else having any control over it!
    Perhaps a better statement of my use (non-use) of cc is this: I think I can get better mileage than the cc brain. On truly level terrain the cc should do about the same as me. In hillier terrain or where there is at least some up and down travel, I think I do much better by anticipating the rises and drops. By accelerating on the downslope and allowing the car to decelerate on the upslope, I can get much better mileage.
    Of course, all of this could just be make-believe, but I will stick to it, because I just like driving this car.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    No, it's not make-believe. I think you're right on target for freeway driving. See this for more. As long as hills are gentle enough where CC doesn't force inefficiently high ICE RPM, I tend to use CC, but terrain like that is more the exception than the rule in my neck of the woods.
    On the other hand, I'm always on the lookout for non-freeway alternative routes where I can deploy SHM. ;)
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Time for a little "thread-keeping"
    Son of Gloin,
    My purpose for this thread is to help new owners realize that really good
    MPG figures arent necessarily a given. But, with lots of reading and
    concerted effort, the numbers will come. Right now in the summer, good
    numbers are pretty much a matter of course. As the temps fall in the
    autumn, there be some panicky posts about falling MPGs. Those folks will
    have to learn the tricks to maintain good winter MPGs which may be about
    40-45 for temps in the 30s F. Ill have to go back and do some reviewing too.
    a priori,
    Fortunately, my MPG numbers on this trip do not support having a strong
    opinion on use/non-use of the cruise control (CC). I think you've got it right,
    CC does pretty well on near-flat and gently rolling terrain.
    But, I found that I didn't like the cruise control itself. It controlled the speed
    far too tightly for my liking. If the speed fell even 1 MPG, CC asked for a
    handfull of power to get back to the set speed. On downhills, again it held
    near exactly to the set speed. This constant speed travel at times seemed to
    irritate other drivers who slowed slightly on up hills and sped up some --
    usually +5 MPH -- on downhills. My nomination for a really desirable hack
    would be one where I could dictate how fast the CC responded and how big a
    departure from set speed was permissable below and above the set speed.
    JimboK,
    thanks for bringing reference to these other threads into this one. It is easy
    to forget where you got a particular MPG strategy or bit of information in the
    huge info-heap we know as PriusChat. I really value input from more
    experienced posters like you, a priori, and the many others, whether
    it's new info, or a reminder that there's more here than most of us newbies
    and near-newbies -- me, for instance -- realize. Ill be re-reading the threads
    you've posted to try to keep my MPGs climbing.
  6. bmg21
    bmg21 New Member
    22
    Rochester MN
    Rok, Jimbo had a nice analysis of slightly rolling terrain with the use of CC and manual mode. I've found with easy rolling terrain cc and manually almost comes out even. I've further found this to be true b/c of my new addition of a scanguage. The car will actually go into SHM quite often on slow decents, and usually will not rev the RPM's much higher than 2300 on slightly elevated terrain. I'm sure you can get better gas mileage if you had pretty distinct elevation situations since the CC cannot predict the incline. Hope your quest continues!
    A happy prius owner
    Brandon
  7. JimboK
    2,817
    188
    49
    Chesterfield, VA
    My pleasure. You're doing the same thing I did early one, and still do -- continual study and practice. With steadily improving results even now. This morning, for example, I got my best result ever on my morning commute.
    Congratulations, and keep up the good work!
  8. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    The following is an extract from a post I made to another thread. It has two
    points: the power of the Pulse & Glide technique, and the idea that out-and-
    back MPGs are far nore meaningful than one-way trip figures.
    Here is an excellent discussion of hiway speed max-MPG techniques.
    Pulse and Glide plus Warp Stealth in the Prius II for maximum FE … - CleanMPG Forums
    Note:it is excellent for the amount and completeness of the info it presents.
    It may not be easy to comprehend in one reading... at least it wasn't for me.
    I found that by trying things out and rereading it, I slowly learned what was
    being presented.
    There's lot's of pulse & glide discussion here on PriusChat. Use the search
    function with "pulse & glide" as the search term. For starters. only read
    threads with Pulse & Glide in the thread title.
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    My daily commute is less than ideal. About 14 miles one way. In the AM,
    home to work is essentially a down hill run, a total drop of ~350 ft. MPGs
    are a function of temps, traffic, and whether I'm really paying attention.
    Routinely I get 58-66 MPGs.
    The way home in the PM is another matter. Of course there's that 350 ft. I'll
    have to climb. But there's also a stop sign and eight lights before I reach the
    high point in the trip. (It needs to be said here that I don't (yet) have the EV
    mod.)
    Even with temps in the high 80s-low 90s deg F, my initial coolant temps are
    only ~110 deg F. What this means is that if I do nothing, at the stop sign
    and the first two lights, the ICE wont stop running when I come to a stop.
    Taken together, this can easily mean the loss of 1.5 MPGs per my
    ScanGuage. What to do? Why find a way to kill the ICE.
    So here's what I've discovered, hardly a major development, but good
    enough to save those slowly leaking away MPGs. When I come to a stop and
    the ICE doesn't immediately stop, I shift to PARK. Yup, you got it, essentially
    dead in the middle of the road. The ICE stops in a second or so -- the
    computers don't know whether I'm in a parking lot or stopped at an
    intersection. Immediately the ICE stops, (per SG RPM readings) I shift back
    to Drive. I've found that I can save 1-2 MPGs on the way home. When I'm
    lucky, I'll pull into the driveway at 50-55 MPGs for the out and back trip --
    just so long as I've been lucky with the lights and traffic, and it hasn't been
    one of those all too common, "just a little bit fuzzy in the head," days.
    FWIW
  10. nooaah
    nooaah New Member
    380
    Philadelphia
    First tank ever. Recovered from 43mpg in my first 25 miles. :)
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Icing on the Cake
    Last night I pulled a 8 mi, 70 MPG trip at speeds between 30 and 35 MPH.
    Wow!
    It was a lucky conjunction of all the different pieces of the max FE equation:
    * the ICE was fully warmed up
    * air temps in mid-70s
    * traffic was very light -- it was 11 PM
    * I was able to time most traffic lights to roll through without stopping
    * it was on a gently undulating route ( Joppa Rd, Perring Parkway, Taylor
    Ave, Old Harford Rd.)
    * little or no altitude gain, maybe -80 ft in the last mile
    * I was paying really close attention -- unfortunately for my lifetime MPG,
    this is not always the case.
    I suspect that dedicated hypermlers probably could have gotten up to 80+
    MPGs, but for me 70 was wholly unexpected... but quite gratifying.
    So what? Well, in my mind, this signals the end of my Newbiedom. We've
    had Amapola for 8 months now, and put on just over 11K miles, with a
    lifetime FE of 50.5 MPG.
    I'm still looking for greater FE, but no more as a Newbie, Nooby, Nube,
    whatever.
    What level comes next? Aspirant, Practioner, Apprentice, Searcher of Truth
    and Max FE?
    Sign me up!
  12. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    This is a slight expansion of thoughts I posted to another thread discussing
    my feelings on the relevance of the "Leaf Car" symbols used to display
    the amount of regen "achieved" while driving.
    All things considered, it is best to ignore the Leaf Cars.
    Think of the Leaf Cars as energy dust pans that collect small amounts of
    energy that individually are quite small, but if you can collect a bunch you
    have something of limited value. The gas in your tank is like large
    denomination bills in your wallet/pocket book. Leaf Cars are the equivalent
    of change in your pocket returned after you spend one of the large bills.
    Getting down to brass tacks, I've read that the total energy in the HV battery
    is equivalent to three tablespoons of gas/petrol. Further, as an average, one
    of the blue bars on the HV battery mimic could represent three Leaf cars. So,
    without getting overly fastidious about the math, a Leaf Car represents something
    like 1/10th of a tablespoon of gas/petrol. This is truly small potatoes.
    Ultimately, all movement of the car comes from using gas from the tank.
    Unfortunately, in the real world there are a hundred little things that intrude
    on getting the absolute best FE/MPG. It is no surprise to me that I get my
    best FE/MPGs late at night when almost no one else is on the road. If I could
    just get rid of the stop lights and signs, I could get really outstanding
    FE/MPGs.
    At best, the Leaf Cars are Reality Reminders, more likely they are Tokens of
    Failure.
    Reality Reminders result from scavenging small amounts of energy when
    you have to slow down to accomodate the real world in which you drive:
    stop lights/signs, incoming traffic, a really steep hill -- remember you
    already have or will have to climb the upside of that hill trading gas,
    chemical energy, for potential energy which can only be fully realized by
    rolling unimpeded down the hill, and on, and on until you roll to a stop.
    Tokens of Failure occur when you have to slow dow due to misjudging time,
    speed, and distances. This is just another way to waste gas.
    Basically, that Leaf Cars occur in day-to-day driving is understandable, and
    even a good thing. But for the most part, you want to avoid creating the
    little Leaf Cars if you're after good FE/MPGs.
    A better measure of doing well would be the ratio of time spent moving with
    the engine not running -- in a no arrows glide --against trip time when
    moving -- to be meaningful you wouldn't count time when stopped with the
    ICE off, that's a standard feature of the HybridSD once it's warmed up.
    (I understand this can be coaxed out of a CanView set-up. I'm pretty
    sure you can't get it as an XGauge on the ScanGauge.)
  13. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    These are thoughts I posted in another thread on the question,
    "Does it make sense to shift to neutral during driving?"
    Since the subject has to do with FE/MPGs, I'm adding my thoughts
    to this thread as well
    There is additional comment on this question here:
    http://priuschat.com/forums/fuel-ec...ral-during-driving-post766033.html#post766033
  14. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Here are my ramblng thoughts taken from another thread discussing
    the pros and cons of intentionally running down the HV battery State
    of Charge, SOC, at the end of the day.
    Part 1
    There was a follow-up as well. As this is longish already, I'll make that
    a second post.
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Part 2
  16. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Rokeby. Excellent, well-written overview of some of the car's operational nuances. I admire those such as yourself with a talent for composition.
    I saw your posts in the other thread but I didn't take time to digest them then. If I may, I'll offer a few brief comments. You're familiar with some (maybe all) of the links I provide. For the sake of completeness, I'm including them for the benefit of those who aren't.
    It's a little more than a minute (assuming no block heater preheat) until the car reaches S2. It uses a "huge" amount only if the driver gives it considerable pedal pressure. Gentle pressure in that first minute minimizes the SOC hit.
    I would say the best way to use it for propulsion is hardly at all. I make considerable use of it to force ICE shutdown during warmup gliding, coasting, or braking, as described here.
    It's more a function of battery temperature than air temperature, though the latter might play a role too. My observation is that EV is enabled at battery temperatures of ~35F+. In my daily winter commuting, battery temperature drops below that only on the coldest of mornings, low teens (F) or below. Using it heats it, so it might be 50F or more (even if OAT is, say, 30F) when it's put to bed in the evening, and as a large thermal mass it cools quite slowly. The longer it sits the more battery temperature approaches ambient temperature of course, so if it sits long enough, then "EV deny" can certainly occur at near-freezing OAT. See this or more.
    Finally, to backtrack a bit in the thread:
    My goal indeed is to avoid them completely, as this from a recent morning commute shows:
    Again, excellent writeup, and keep up the great work -- with the keyboard and the go-pedal! ;)
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Jimbok, that is one hell of a result. Compared to me, anyway.
    My best all time tank results are right about 70.0 mpg, and I have only managed 80 mpg twice in somewhat fudged round-trips. Fudged in the sense that I didn't start the round trip mpg meter until I had exited my neighborhood, which allowed the engine to warm up.
  18. Nova1
    Nova1 New Member
    San Antonio
    You are so right. Now if I could get my wife to drive like that in her RAV4, we could afford to replace the brake pads she wears out.
  19. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    JimboK,
    Thank you for your comments. You are always :welcome: here.
    As to the use of SOC on start-up, my definition of "huge' is probably
    atypical. I monitor SOC with my ScanGauge and actively fiddle things to
    stay around 60%. The SG shows SOC in 1/2 a percentage point steps. To
    me, a 5% SOC reduction -- 10 steps -- is huge, even though on the SOC
    meter on the MFD there may be no change shown.
    You say poe-tay-toe, I say pah-tah-toe. ;)
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Thanks. Next time I'm in the Ballamer area I'll give you a shout!
