What Is Your WORST Prius Fuel Economy?
Discussion in 'Gen 2 Prius Fuel Economy' started by jyl, Aug 31, 2009.
  1. jyl
    jyl New Member
    84
    Portland
    Here's ours.
    For daily city driving - have seen as low as appx 32 MPG in winter. Temps around freezing, short trips with cold starts, climbing a big hill most days. Wife cranks heat to max and is a total leadfoot (P&G for her is Procter & Gamble). 10% ethanol gasoline, and snow tires (Blizzaks inflated to 40 PSI) on steel wheels. Carrying 2-3 kids. In those conditions, I got 35-36 MPG so the leadfoot better half is not entirely to blame.
    For highway driving - Averaged 30 MPG over a 650 mile roadtrip with four occupants, stuffed full of luggage, Yakima rack with 12 cu ft cargo pod on one side of the bars, also stuffed full, two 17-foot sea kayaks on the other side of the bars, straps and cords all over. I estimate about 270 lbs on the roof and a huge amount of aero drag. Rear wheels were squeezed up in the wheelwells. Almost new Nokian WRG2s inflated to 42 PSI. Oil slightly overfilled (1/2" on the stick). AC cranked. 10% ethanol gasoline for 1/2 the trip. Averaged about 70 MPG - no eco-driving, not with the trip already going to take 11+ hours.
    Not negative about it - I think its funny actually. Any other car in similar conditions would have been much worse.
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    We had a tank around 28 MPG once. Daytime highs around 20 Fahrenheit, almost exclusively short trips (<3 miles), plus a good amount of time idling in the driveway trying to get the ice on the windshield to melt.
    It's amazing what you have to do to push this car below 30 MPG.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I had a 37mpg tank once in the early dark days of ownership. Frigid temps, loaded car, 75mph with terrible quartering headwinds on a long freeway drive.
  4. hm800x
    hm800x New Member
    Quebec Canada
    I remember a camping trip with our tent trailer weighting around 1700 lbs with luggage and use of the Prius as generator because of no electricity on camping site. Got as low as 26 mpg but mainly because of using it as generator for about 10 hours.
  5. qbee42
    3,079
    For a whole tank, probably somewhere in the high thirties during the cold and snow of winter.
  6. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    I've had 7.6L/100km in –30°C weather. That's about 31 mpg.
  7. brick
    brick Active Member
    1,083
    79
    Upstate NY
    44mpg (actual...MFD said about 46). Daytime highs were around 20F with mornings in the single digits, and I drove through one major snow storm. At the time I lived in an apartment so the only way to get the windshield clear enough to see was to warm up and defrost before driving off. Needless to say that was before I moved to SC!
  8. richardp
    richardp New Member
    New Port Richey, Florida
    18 mpg......just bought the '07 and discovered that the parking brake was on. Take the brake OFF, and it gets much better mileage. who knew?
  9. richardp
    richardp New Member
    BTW- I'm a newbie here. Where do I go for economic driving tips? After I take the brake off that is.
  10. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Hi Richard and welcome. :welcome:
    Since you list your car as a GenII I've pointed you to the GenII Fuel Economy forum: Gen II Prius Fuel Economy - PriusChat Forums
    My worst tank to date is 40.3 logged between 11/30/05 and 12/14/05.
  11. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    My worst two tanks were both 8.6 L/100km (or 27.4 mpg US). That was late December / early January, really cold weather, mostly short trips. It's hard to think about that because I filled up today with my best tank (4.8 L/100km or 49 mpg US)
  12. nikki&petey
    nikki&petey Junior Member
    Utah
    This week. 43.3 MPG. AC blasting constantly and I had to go up a huge mountain pass twice on this tank.
  13. blippo
    blippo New Member
    255
    VA
  14. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    Mithril has suffered through one tank at 38.2 mpg ... two tanks at about 39.5 mpg. These were primarily the result of EXTREMELY cold winter weather, coupled with mostly VERY short, 'round-town trips.
    He's making up for that now, though. Eight of the last ten fill-ups have resulted in over 50 mpg for an average of nearly 52.5 mpg -- per hand-calculations -- over that stretch ....
  15. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    about 40 MPG
  16. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    During winter, and before I blocked the bottom set of grill slats, I had a tank at 42.2 mpg. It was all short commutes.
  17. ETP
    2,802
    1,170
    Auburdale FL
    54 but the air had leaked out of the tires over the summer. Back up to 46PSI and my MPG is back up 58-60 MPG going to work. AC hits my mileage big time. I did a brain dead flat and rolling check after moving for 20 miles and I got 68MPG. To me that is a stupid check since you should check it fill up to fill up. EH!
  18. ken.miller
    ken.miller New Member
    South Daytona, Florida
    I have 4,600 miles on my 2009 Prius and the best mileage I'm have gotten is 37, the 4,600 mile average is 35.63 and the least is 33.08.:mad:
  19. nhguy78
    nhguy78 whirr...........
    51
    Hudson, NH
    My worst useage is in winter and it gets down as low as 40mpg. This is New Hampshire winters on the highway.
  20. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    March 2009. Cool to cold weather. Uphill from sealevel to the Catskills...against the prevailing weather...on I95 / NYS Thruway...at an average speed of about 75 mph.
    For 700 mi I averaged 41 mpg.
