1000 mile tank
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Apr 9, 2012.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Anyone on track for a 1000 mile tank?
    My fuel gauge just dropped to 1/2 w/550 miles on trip meter and hsi showing 120 mpg
    2 people like this.
  2. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I think iRun has already had a ~1400 mile tank, if I recall.
    I'm at half tank with 100mpg. I definitely drive this car more than my past car (giving our gas guzzling minivan a much needed break).
  3. stephens5.rich@gmail.com
    [email protected] New Member
    39
    Los Gatos, CA
    I'm just shy of 800 miles with 3 bars left on the tank: 108MPG so far, and that is with my 63 mile round trip commute and not getting a full charge at work. I've set up a meeting next month with the property managers and Coulomb Tech to rectify that.
    You gotta love these cars!!
  4. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Currently at ~980 with 2 notches left on the gas gauge. Car range says I have about 80miles till empty.
    Wow... 1400 miles a tank is quite impressive.
  5. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
  6. crewdog
    493
    388
    Woodstock, GA
    That's really above and beyond any expectations. I'm sure that will decrease any payback time.
    Maybe we should have a 1-A division for those of us who don't charge at work, and a 2-A division for those who can recharge at work.
    Thanks to all the folks for posting tips and tricks!
  7. ThatTallGuy
    ThatTallGuy Junior Member
    67
    Southern NH
    And -B divisions for those whose commutes are at highway speeds.
    I don't expect I'll ever see 1000 miles on a tank. With the work recharge, though, I think 75mpg overall might be an achievable goal...
  8. pfile
    pfile Member
    319
    35
    bay area, ca
    agreed, with my 90mi commute (admittedly only once or twice per week) i'm only averaging about 70mpg with maybe 30% in-city EV driving.
  9. stephens5.rich@gmail.com
    39
    Los Gatos, CA
    My first tank. I finally had to get gas!
    EV 499 miles
    HV 533 miles
    Total 1033.1 miles
    9.5 gallons
    CONS 111MPG
    117kwh
    Fuel Saved by Charge: 9.7 gallons
    2 people like this.
  10. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    Does the Car keep track of your EV miles vs HV like this? FYI...I do have the scangauge II for my Hylander Hybrid.
    Thanks,
    Edward
  11. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    There's a screen on the MID/MFD thats called "EV Driving Ratio" that provides the EV/HV ratio, how much electricity was used (for EV), how much gas was used (for HV) and how much gas was saved. The numbers are rounded or truncated. But its at least good for a general idea.
    The screen is resettable, but there are 2 (just like your trip odometer). So in my case, I use one for my "tank ratio" and I have one that has so far been my lifetime ratio.
    Here's a picture
  12. DTKim
    DTKim Member
    52
    32
    Technically, for PiP's, can't you get a 100,000 mile tank if you only drive 10 miles back and forth from work/shopping? Is there a standard for figuring out what your "charging" costs are and mixing it into the calculation to determine true MPG (using cost of energy as the basis)?
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    I don't know if the PiP does this, but I understand the Volt will occasionally (weeks? months?) run the ICE just to keep things from gunking up.
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    As CharlesH pointed out, yes, the engine will run after a prolonged period of inactivity (I think in the manual it says after 120 miles of pure EV?). It would run until warmed-up (or if you shut it off, I suppose).
    There's a spreadsheet some of us are using to track MPG. Since its kind of a pain to track kWh from the wall, we've just been using the EV Ratio display's kWh consumed number to make some calculations.
    http://priuschat.com/forums/toyota-prius-plug-in/106610-pip-mpg-spreadsheet-4.html
  15. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    Here's my first tank. I gassed up last Friday. These miles are all in the normal lane.
    EV 676 miles
    HV 455miles
    Total 1132.4 miles
    8.608 gallons
    CONS 135MPG
    158 kwh
    Fuel Saved by Charge: 13.2 gallons
    This is the first week I have in the carpool lane. It's awesome but i won't get the same results going at this speed. Can't wait to see the results.
    2 people like this.
  16. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Can you please register your fill-up data to:
    PiP MPG Spreadsheet
    Thanks.
  17. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    genetiix's fill-up data is on the sheet already
  18. drash
    drash Senior Member
    2,598
    1,338
    Upstate NY
    XLE AWD-e
    Yeah according to the manual, every 124 miles it'll turn on but I force mine on every once in a while because I dread leaving gas that long in my car. I'm currently doing about 70/30 electric/gas with my short commutes and short trips to 2 local small cities. Currently reads 170 mpg for the month so far. Fuel gage still show 526 miles to go. It is an amazing car.
  19. Clearwater Blue PIP
    Clearwater Blue PIP Junior Member
    36
    Arizona
    I usually fill up when I hit 1/2 tank. But this time I ended up driving until I only had two bars left (1,012 miles on this tank/148MPG). As it turns out, it only took 7.4 gallons at the pump, so I actually had quite a bit of range left. Currently at 51% EV lifetime. My commute includes FWY driving. I'm normally able to get a full charge overnight and another one before returning home each day.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Nice PIP:cool:
