12 volt supply
Discussion in 'Gen 3 Prius Technical Discussion' started by alan16uk, Apr 12, 2012.
  1. alan16uk
    alan16uk Junior Member
    west wales
    2 interior 12 volt supply connections.
    the one in the armrest charges phone ok.
    the one under the gear lever does not ??yet it is live.
    any ideas on this please.
    2010 gen3 t4
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Sounds like high electrical resistance in the one up front "under the gear lever".
    A high resistance would make a no-load meter reading look like a normal 12V, but as soon as you put a load on it, the voltage will drop.
    I do not know the proper terminology in Britain, but get it checked out by a professional.
  3. alan16uk
    west wales
    thanks for your info m8
  4. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    Is this a new problem? I have a UK 2011 T-Spirit and can charge 2 phones up front using a splitter.
  5. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    The 12 volt supply connection under the gear lever on my 2011 charges the phone. Could something be wrong with your connection?
  6. El Dobro
    El Dobro A Member
    7,106
    3,282
    I've found with the receptacle under the console, some chargers have to be pushed in harder to make complete contact.
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Makes sense to me. I had the same problem with the outlets in an older vehicle.
