1. TSaxman28
    TSaxman28 Wandering Minstrel
    51
    NH
    2019 Prius
    For the last two days I went to start my car and got an error message saying, “Low 12-Volt Battery, Apply Parking Brake Securely While Parking…”. All the accessories are working, all lights come on, but when I press the brake pedal and try again I get another message saying, “Not Ready to Drive, Depress Brake Pedal and Push Power Switch to Start.” Yesterday I called AAA and then gave me a jump but said the battery was showing 12.3 volts.
    Anybody have any idea what is going on?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,969
    Texas Hill Country
    It is possible to have a battery that reads 12.3v but then falls quickly when trying to Ready the car.
    You need a load test on that 12v battery. If it fails you need a new battery.
    Most auto supplies can do it but you may want to move the covers out of the hatch area first.
    BiomedO1 likes this.
  3. TSaxman28
    51
    NH
    2019 Prius
    Thanks for the quick reply. Sorry to be a little thick but why would I need to move stuff out of the hatch area?
  4. rjparker
    11,108
    6,969
    Texas Hill Country
    You don't need to on a gen4
  5. BiomedO1
    BiomedO1 Senior Member
    4,605
    2,414
    Left Coast
    If you continue to get that second error message; your brake pedal switch may be intermittent. That may become dangerous; since that also drives your brake lights.
    I've developed the habit of hitting my hazard lamps when I hit slow moving traffic on the interstate - don't want someone coming around a blind curve thinking I'm going full speed - when traffic is only creeping. I know I've avoided a few collisions; because I've seen several cars lock-up their brakes in my rear view mirror.
  6. TSaxman28
    51
    NH
    2019 Prius
    Thanks for all the super fast replies. AAA just left and his diagnostic show some dead cells in the battery. Considering that it's original battery I'm not surprised that was the issue. Not bad for lasting 7 years.
  7. BiomedO1
    4,605
    2,414
    Left Coast
    Newer cars are very sensitive to voltage variations; because of their computer controls. That said; the first thing to do is to FULLY test the starting battery. Low voltage/amperage can cause all kinds of phantom errors to crop up; so take care of that FIRST - clear all error codes, then see if anything pops back up. A defective part will error again; a phantom error due to low voltage/amperage won't.
    Hope this helps.....
  8. TSaxman28
    51
    NH
    2019 Prius
    Big help...Thanks!!
  9. ChapmanF
    19,025
    The conditions that an ECU has to see to trigger a particular trouble code can be quite finicky, and usually have to crop up on two consecutive drives to trigger the code.
    Because of that, the plan of "clear it, then see if it comes up again" is often not as definitive as it sounds; if the code was reporting a real issue, you probably will see it again, but that may happen weeks or months later.
