2008 Inverter Fluid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jodee95, Jan 11, 2014.
  1. jodee95
    jodee95 Junior Member
    First just a quick thanks for this site ..I have 34k on my 08 Package 6 Just bought a few months ago at 30K certified used traded my 04 Tacoma even trade They even paid all my taxes and DMV fees for NJ . Was worth the ride into PA.
    I just did my first synthetic oil change. I emailed the service dept at the dealer I bought it at 3 times with no reply. So I will not beg them to take my business Plus all the good DIY maintenance I have learned on here is only going to add to my saying of the vehicle. So finally my question I am planning on changed the trans axle fluid seems straight forward but I can find a thread to change the Inverter fluid can someone help with this... Thanks again..
    PS I went from a 4wd Tacoma and I have to say I was impressed with this car in the snow...
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    It might be a bit too soon to change the inverter fluid just yet. Has the inverter pump recall been performed? If so, then the fluid should have been changed already, although some dealers do not do this.
  3. Patrick Wong
    18,210
    6,517
    It's OK to change the transaxle ATF at this time.
    The first specified change on the inverter/transaxle coolant is at 100K miles and there really is no need to do this sooner. Subsequent changes are at 50K miles.
    When you are ready to do this, buy a gallon of Toyota Super Long Life Coolant and an aluminum transaxle drain plug washer from your local Toyota dealer's parts dept.
    Before you start, make the Prius READY and listen to the inverter coolant pump, located behind the driver's side headlight, after the engine turns off. Notice how the pump sounds like an aquarium pump and you should not hear any air bubbling. Look at the inverter coolant reservoir and note the turbulence in the fluid as well as a step in the fluid level as you look across the front to the back of the reservoir. You need to replicate these sounds and sights after the fluid drain/replace, before you can say you are done.
    The coolant drain plug is located on the bottom of the transaxle, nearest to the engine. Do not confuse with the transaxle ATF drain plug which is further away towards the driver's side of the car. Both drain plugs require 29 ft.-lb tightening torque.
    Remove the coolant drain plug and measure the coolant drained, typically 1.5 quarts or so. Now you know how much new fluid you need to add before you can declare victory on this project.
    Remove the large black plastic cover over the radiator for access to the inverter/transaxle coolant bleed valve. There are six plastic fasteners for the cover. Use a Philips screwdriver to rotate each fastener as you apply upwards pressure on the cover, to pop the fastener out. If you break a fastener (the plastic is brittle especially in cold ambient temps), get a replacement at your Toyota dealer.
    Fill the inverter coolant reservoir. Make the Prius READY. The inverter coolant pump will be noisy and you'll also hear air bubbling in the system.
    Run a clear vinyl hose from the bleed valve to the coolant reservoir opening. Open the bleed valve and let air bubble out through the hose into the reservoir opening. Keep the fluid level at the MAX level in the reservoir.
    After a while, you'll notice that the inverter coolant pump has quieted down and you will not hear air bubbling. You should have added the same amount of new fluid as you had earlier drained out. Tighten the bleed valve and the inverter coolant reservoir cap, replace the black cover over the radiator, and you are done.
    Once you start this project you cannot rest until you have gotten all air out of the system and restored correct fluid circulation. The continued health of the inverter and transaxle depends upon this cooling system. Hence, allow yourself a couple of hours to account for learning curve and to ensure you have plenty of time to do the job correctly.
    AzWxGuy likes this.
  4. Mike500
    Mike500 Senior Member
    2,593
    767
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    I see in my manual under specifications that the Power Control Unit (Inverter) coolant capacity is 2.9 quarts. I haven't done this job myself yet, so I can't quote from experience. Is this typical Toyota "absolute" capacity, or does some of the old coolant remain in the system when it is drained?
  6. Patrick Wong
    18,210
    6,517
    Some old coolant remains in the system. Same is true with the engine coolant, where the NA Prius capacity is around 9 quarts but you will be lucky to get 6.5 quarts out of the system after opening all three drains: radiator, engine block, and CHRS canister.
    This is why the service interval is 100K miles for the factory fill coolant; then 50K miles for subsequent changes.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I changed mine at 30,000 after noticing it was getting a little cloudy. Buy a gallon of SLLC at Toyota for $20.
    Pour a little in a clear glass. Then using a turkey baster suck out a little out of the Inverter reservoir and put in a clear glass.
    Compare the 2. You'll probably see how cloudy the original is. The I coolant is exposed to a very large amount of pure aluminum heatsink which is very corrosive.
    Its pretty easy to change and I usually that coolant and the trans fluid every 30,000. For me that's every 3 years. Both are very inexpensive when you diy it.
    $40 for trans fluid & $20 for SLLC.
    Btw, I noticed an immediate gain in mpg's after changing the I Coolant. The Inverter ran cooler as I checked it with a IR thermometer before and after. Go for it.
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I agree with nh7o--try to find out if the inverter coolant pump recall was performed. If so, the inverter coolant may have recently been changed. Mine was done last fall.
  9. edthefox5
    10,096
    4,837
    Clearwater, Florida
    They typically do not replace the fluid with a pump install. They just duckbill off the hoses and slide it in.
  10. jodee95
    All What a great response Thank you All One more Question
    Was my 2008 Prius included in the recall for the pump? I bought it Certified used from the Toyota Dealer did not see it on the list of work completed. Unless the previous owner did the work?
  11. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
  12. jodee95
    OH what great advise I found who every owned this vehicle before had all the service complete oil changed (All Synethtic) at 1k miles and every 5k after. It had the special service camp. to replace the inverter pump. But because the car was from PA I see a lot of safety checks maybe this was required But the tech also noticed the water pump was leaking so they changed the pump with new coolant. New tires at the Dealer with rotations So the only thing left for me to do is the CVT fluid. Just a great resource Thanks again,,,
