2010 Prius 17" OEM Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by WinstonTheodore, Aug 20, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Tire weight varies on average by about 3lbs.. Switching from a the lightest 15" tire (about 17lbs) to the heaviest 17" tire (about 22lbs) can add 5lbs. or more.
  2. Mdrolet77
    Mdrolet77 New Member
    Montreal, Qc, Canada
    5 out of the 10 you save is huge especially if you consider the added rolling resistance from the wider tire...
    It's almost certain to cancel any gains made especially if you're not doing much stop and go. (Damn those stop signs :))
    edit : any idea on how much the oem 15 inchers weigh in at ?
  3. mattcho
    mattcho New Member
    seal beach, ca
    sold mine. thanks everyone.
  4. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Don't forget that wheels and tires are unsprung weight (not supported by the suspension) and unsprung weight is multiplied by 4. So if you ad 1 pound, you're adding 4 pounds.
    [ame=http://en.wikipedia.org/wiki/Unsprung_mass]Unsprung mass - Wikipedia, the free encyclopedia[/ame]
