2010 Prius OEM-quality Fog Light Kit Now Available!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danny, May 10, 2010.
  1. olyprius
    olyprius Member
    194
    31
    Looks slick! I plan to do the same!! How many layers did you apply with each can? How long did you wait for each layer to cure. Did you use paint primer first? If not, do you recommend it? Thanks for sharing!
  2. kc5tvd
    kc5tvd New Member
    LaPlace, Louisiana
    I did not use any primer, and no sanding. Used two coats of black, and three or four of the clear. I did light coats, didn't want any runs. Gave each coat time to no longer be tacky, in my area that means about 20-30 minutes. I let them dry for about a week before I installed them, mostly because I didn't have time to install. I would let them set for at least a day before installing.
    They have been installed for about 3 weeks now, and no problems yet. I was happy with the paint, can't tell any difference between the car and the lights. I waxed the car shortly after installing them and it only made the paint closer match the car. No signs of cracking or chipping yet. It is standing up to the Louisiana's highway bugs.:D I think the paint will last, but only time will tell.
  3. mpgz
    mpgz Junior Member
    24
    Indiana
    I've used the Krylon Fusion gloss black on my motorcycle a great deal. I use it on the headlight bezel. It holds up pretty well but I've found that if I let crushed bug guts stay on it too long, it will take the finish off. I've had to repaint it about once every 2 years.
  4. mpgz
    mpgz Junior Member
    24
    Indiana
    Has anybody done the fog light install with the factory steering column tree? I've seen a couple references to it but I'd like to get some more info.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, follow my fog lights link in my signature and in the post if references another thread where the author stalled the stalk.
  6. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    I ordered mine on 6/2 and still have not received it.. dogh.. I emailed him again today..
  7. gradybear
    gradybear Junior Member
    16
    Southern California
    Does anyone know what bulb size for this fog light kit ?
    I am planning to get this kit and install HID on them.
    I am new to here.
    I do not know where to search for it.
    Sorry about it.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    For those of you going HID I assume this is for cosmetic purposes and not for true fog use. If you are planning on using them for actual fog you will be better off using a halogen bulb. :)
  9. gradybear
    16
    Southern California
    I have a quick question, can I just simply connect the wires to my low beam power source ? Because I do not really care about the button and stuff. I rather to have my fog on when I turn on my low beam at night.
    If anyone of you have done that, please let me know.
    Thank you !
  10. bzyrice
    805
    324
    West Palm
    You can do that, but I would suggest getting a relay.. your relay would get the signal from your low beams to turn on.. then you would tap the actual power from the fuse box ..
  11. bzyrice
    805
    324
    West Palm
    Just got it!! Took 3 weeks but I am happy!! Cant wait to get them on!! Thanks!
  12. gradybear
    16
    Southern California
    What kind of relay do I need ? Because I do not really sure which one I will need. I want to make sure everything will work out well before I place the order.
  13. gradybear
    16
    Southern California
    Hi Danny,
    I have a quick question, is it possible to purchase only the fog light lamps instead of the whole kit ?
    Because I do not really need the button, wires, and the light bulbs.
    I just need the Fog light trim pieces (fog light lamps).
    Please let me know if it is possible to make a order without purchasing the whole set.
  14. swoodchuk
    swoodchuk Junior Member
    Bel Air MD
    I puchased these lights and had them installed by a local body shop. It cost me 73$ and the guy said he would like more of those jobs. The lights are just great.
  15. bzyrice
    805
    324
    West Palm
    Just installed mine today on my 2011!!
    The 2011's fuse boxes are different!!! There is a 30 amp fuse above the white wire in the fuse box. So, since the instructions said to use this fuse location I did. When I did and tested the fog lights, I got a "P Lock Malfunction"!! I kinda freaked out since my car has just under 5000 miles on it. I found Puddlejumper's post and put the fuse back and plugged my red wire into an open slot in the top left corner of the fuse box. Now everything works great!! Thanks Puddlejumper!!
    These fogs look good!! I also installed some h11 3000k Hids. to get some extra light at night.
    So, if you have a 2011 and plan on doing this, use the open slot in the top left corner of the fuse box!!
  16. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    How long did it usually take for the fog lights to get shipped out?
  17. bzyrice
    805
    324
    West Palm
    Mine took 3 weeks to get to me.
  18. a1rjumpman23
    75
    Just recieved mine, took about a week and a half but so far very satisfied!
  19. bzyrice
    805
    324
    West Palm
    I am looking to buy a Fog Switch!! For any of you guys who ended up using the stalk fog light switch please pm me how much you want the fog lights switch for. THANKS!
  20. swoodchuk
    Bel Air MD
    I had these lilghts installed according to the instructions and you can have high beams on and the fog lights the same time. Also fog lights and low beams. You can use foglights alone on the first notch with parking lights after you hit the dashboard switch. These lights are bright enough to use as low beams all the time. Great lights.
