2015 prius daytime running lights ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DLRJAZZ, Feb 29, 2016.
  1. DLRJAZZ
    DLRJAZZ New Member
    Conneticut
    New to the forum. I notice that when putting on the drl only top 4 are bright wondering if it is a design floor?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Nope, not a design flaw. Only the top 4 light, the bottom ones that look like they should light up do not, they kept the circle theme going for aesthetics.
  3. DLRJAZZ
    DLRJAZZ New Member
    Conneticut
    Is there a way of lighting the bottom 2
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I guess if you want to modify it by removing, drilling, mounting LEDs, wiring etc etc, sure it could be done, anything is possible by means of modification.
    If you mean can you light them the way they are currently stock from the factory, no you cannot because there is no physical LED in the bottom 2 that could be lit.
  5. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    In Paradox's picture, in the unlit photo, you can see the actual LED component as a tiny yellow rectangle behind the circular "lens" of the top 4. In the bottom two, there is no LED circuit board.
