255k High Mileage Prius c... status
Discussion in 'Prius c Main Forum' started by JaxPriusC, Apr 11, 2022.
  1. JaxPriusC
    JaxPriusC New Member
    Hey just wanted to stop in and share my experiences.
    Have used the pc forum many times.
    So I have a 12 Prius C with 255k+ miles.
    At 149.5k (I kid you not) the hybrid battery died and Toyota gave me a new one, barely within the 150k warranty period.
    It burns out lots of bulbs, seems like frequently.
    The left rear tail light fills with water so I drilled a hole (hidden) in the bottom so it can drain
    Still gets 50+ mpg
    Typical Toyota paint starting to look shoddy.
    Slight shake/vibration at low speeds like in parking lot. Don't know what that is.
    Could use a new front Control arm, the old one clunks now and then
    Have tried tons of tires, Pirelli, Continental, Goodyear, etc...
    The OEM Fuel Assurance Max are the best.
    The TPS warning light is on constantly and I don't want to pay for new sensors, checked pressure and all are good
    The rubber strips on the roof come loose and flop around at the car wash
    The air intake snorkel rattles, annoying
    But all in all, typical Toyota quality and I hope to see 300k
    Still on OEM brake pads.
    10k oil changes
    Spark plugs twice
    Coolant flush twice
    Air filters
    Monthly Royal Purple fuel treatment
  2. JaxPriusC
    oh and a new 12v battery a couple years ago and trans fluid
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Have you changed the transaxle fluid?
  4. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Great. Have you ever cleaned the EGR system and the intake manifold, replaced the PCV? Does it burn oil?
    BTW, is the battery warranty 10 yrs / 150k miles? I thought it is only for Prius in CARB states, not for Prius C.
  5. JaxPriusC
    Well they covered it for me... and said it's 150k in California.
    Nope on the EGR or intake cleaning and no oil burning.
  6. JaxPriusC
    just once
    Sonic_TH likes this.
  7. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Amazing they offered that warranty, wow!
    prius C has always been known (or termed and mentioned) to be 8 year/100k
  8. PriusII&C
    432
    147
    For your "shake/vibration at low speeds", you may want to clean the EGR & intake manifold, and see how the car behaves.
  9. JaxPriusC
    Ok here we go...
    262k miles... overheating and dropping coolant levels... diagnosed as bad head gasket. Mechanic said bore scope shows scoring in cylinder walls... thus don't recommend a head gasket repair, but rather an engine replacement.
    So my question for you all...
    I've seen Prius C engine under 50k miles... all over eBay, etc...for $500-800
    How much will a SoCal mechanic charge for the labor to swap engines? Any SoCal shop recomendations?
  10. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Most likely the thermostat got stuck closed, which caused the water pump to overheat and fail, and thus causing the engine to overheat.
  11. Prius C Til it Dies
    Prius C Til it Dies New Member
    Menifee, CA
    OEM 12V BATTERY STILL IN PLACE
    SOLID VEHICLE, NO PROBLEMS AT ALL
  12. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates?
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Hybridpit in Buena Park if you want to keep the car. Where you are now is at the cross road of "do I invest in this car and keep it or do I buy a used/new car? Up to you.
