adding Aux line in to JBL 6 disk in a 2005?
Discussion in 'Gen 2 Prius Audio and Electronics' started by narf, Mar 15, 2005.
  1. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Hi there,
    I've asked this a few other ways but the question comes down to this.
    Has someone out there successfully added an aux-input to the JBL 6 disk system? I've seen references to Aux-boxes, but it's unclear what units this works with. I also have read the Coastal Dave is working on an aux in unit, but that project seems to be a long way off (It's been talked about for almost a year). Any help would be appreciated.
    Thanks
  2. quietcoolone
    quietcoolone New Member
    East Flatbush, Brookly NY
    Narf,
    It is my understanting that if the radio has external cd changer controls then you can connect an <a href=\'http://www.discountcarstereo.com/detail.aspx?ID=705\' target=\'_blank\'>auxiliary input</a> device. The device you speak off is an ipod interface and auxiliary-- but for the money you can probable buy a whole new stereo.
  3. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Quiet,
    The JBL system has the 6 disk changer, radio, and cassette player in a single head unit. It has an external amplifer where all the audio controls happen including volume. I would guess that I could interupt the left and right line outs between the head and amp and build my own interface. I was hoping somebody had already tried this. As far as the Auxbox, I don't think it's that pricey. I've seen it for about 60 dollars. With the cables and such it should be under $100, and you get to keep all the control functions of the stereo.
  4. quietcoolone
    Narf,
    I thought all the connections were on the radio (all but the audio output and controls that go to the amp). so if you were to add a factory XM or auxiliary input (the one i linked to was around $57) -- where would they connect? the amp of behind the radio?
    If that 6-disc in dash changer has external changer controls the auxiliary would connect to it-- as for the price-- i was not referring to the Auxbox but the other mentioned in this forum (VAIS)
  5. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Quiet,
    I haven't had the radio out of the car yet so I don't know if there is a CD changer /XM input on the JBL 6Disk version. It's not shown on the wiring diagram (but the wiring diagram doesn't show it for the basic radio either). I was hoping someone here had that info. ALso, the unit you linked to has the following set of disclaimers:
    "2. With the DF-TOY installed a CD Changer cannot be used at the same time, the adapter takes the place of the CD Changer.----[see our docking stations.]
    4. USASpec DF-TOY is not compatible with Toyota Navigation Radios, factory DVD or XM Radio Systems or Toyota Prius. "
    Have you personally gotten this unit to work with the stock one piece 6 disk changer/cassette unit?
  6. quietcoolone
    i think the cd changer reference is to an external one, (not built-in). I installed the df-toy unit in my girlfriends 4-runner equipped with a factory 6-disc changer radio-- she has to hit the "CD" button twice to access the ipod mini. The radio also has the factory xm option but it\'s not installed.
