aftermarket radio and glare
Discussion in 'Gen 2 Prius Audio and Electronics' started by jvierra, Jun 9, 2020.
  1. jvierra
    jvierra Junior Member
    I added a aftermarket radio in order to get Apple Car Play. The unit works great but I have one big problem. If the sun is out it's impossible to see the screen. The sun doesn't even have to be directly on the screen! Tried adding a glare guard but that didn't help. So I'm looking for some suggestions for other aftermarket radios some of you might be using that don't have this issue. Thanks in advance!
  2. dolj
    dolj Senior Member
    8,111
    4,127
    Wellington, New Zealand
    Are you using polarised sunglasses by any chance?
  3. jvierra
    No I'm not. Thanks
  4. lpf
    lpf Member
    133
    36
    Greece
    Where the unit is installed? In the slot below MFD? Can we see a picture?
  5. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Maybe it's the screen itself. I had a sony with carplay in my gen 2 and didn't have any major issues with glare. The mounting brackets did have some leeway for positioning so I would give that a try first. Yes, that involves removing the deck. Again.
  6. jvierra
    I'll get a pic but its below the mfd. Thanks
  7. jvierra
    That's what I was thinking. I wish I had driven it before I put it all back together. Thanks
  8. ColoradoCrow
    ColoradoCrow Senior Member
    1,057
    436
    Leawood, KS
    I
    j
    How did you solve this problem? Changing the angle of the screen? What Head Unit did you go with?
