ANyone tried small sub(s) in the rear hatch panel?
Discussion in 'Gen 2 Prius Audio and Electronics' started by KTPhil, Dec 31, 2009.
  1. KTPhil
    KTPhil Active Member
    1,379
    I don't want to lose my flat floor, so I'm looking for a clever place to install a small sub or two to boost the low-low end of the JBL on my '05.
    Has anyone tried locating them in the hatch door? Is there room for maybe a pair of 5-6" subs? They could stick out a bit with a frame and grille. Is the plastic hatch cover strong enough to take slamming with the added weight? Is there a frame inside the sub(s) could be mounted to?
  2. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    There's probably room on the inside of the hatch, but the plastic isn't solidly mounted, and you'd likely end up with more vibration than thump. The two little 'cubby' areas behind the wheels are about right for 8" or 10" subs, but you'd have to make a fibreglass enclosure to fit in there.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Could possibly be done but the amount of work required to seal that hatch area up tight and keep vibrations down would not be worth it IMO. Beter off to just put a single sub in the cubby hole or redesign the floor and put a sub inside the storage area.
  4. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    You mean in the hatch door facing forward? Aside from what's already been mentioned I'd also be worried about two things: added weight to the hatch and abusing the subs with all the jarring from closing the hatch. In the cold weather my rear hatch door rises slowly enough as it is, more weight and it wouldn't go up at all without a good shove.
    - D
  5. KTPhil
    1,379
    Thanks for the ideas, everybody. I won't give up the main storage space, but I might give up one cubby. Did it take the open space, or did you also have to remove the little floor/door and use the space below the main cargo level, too?
    I've done fiberglas work before so I guess that's where I am headed...
  6. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Check the specs on the subs you're considering and see how much space you need. I haven't actually done this yet, but I have it on good authority that using the entire left cubby is about right for a 10" sub. There are other threads here that show construction details.
  7. Oppy
    Oppy Smug Apprentice
    26
    Seattle, Washington USA
  8. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Thanks for providing the link for the OP. I meant to go back and do that and got side-tracked. don_chuwish created a very clean and viable subwoofer setup that were I not such a basshead I would duplicate myself.
  9. KTPhil
    1,379
    Lots of nice jobs putting it under the floor for sure! I just need to use it for other stuff (emergency supplies, small tool kit, anything I don't want out in the open when parked...).
    I think I'll be needing to fab a fiberglas enclosure as has been done in this forum, once I get a few solid days off to work on it. Then I'll be shopping for amp, speaker, etc.
    Thanks again for all the great ideas!
  10. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Just get a underseat power one. i did this in my maita. its only 5" in hieght and can easly go under the driver seat. cost about $150.00
  11. KTPhil
    1,379
    It won't fit under the driver's seat when you have the Nav system option. Most amps won't even fit there.
