Automatic Headlights Mod
Discussion in 'Gen 2 Prius Audio and Electronics' started by gsteirer, Apr 15, 2005.
  1. gsteirer
    gsteirer New Member
    Riverside, CA
    I was truly disappointed when I received my new Black '05 Prius with Burgundy/Grey interior - no automatic headlights? This is a celebrated feature in my Stratosphere Mica '04 Sienna XLE Limted AWD and my Garnet Fire '03 Infiniti G35 Sedan! Both with HID headlamps. When will we see a mod for this...perhaps CoastalTech is working on this? Has anyone tried this type of modification?
    If I had my druthers and more patience, all my cars would be a Prius!
    Thanks - Greg
  2. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    By auto-headlights, do you mean DRL? or that the headlights come on autmatically at night/in dim light?
    They currently do shut themselves off when you leave the car and turn back on when you start it. That is auto enough for me.
  3. Tideland Prius
    16,556
    That's just Auto-Off. Automatic headlights have full on and off functions and automatic dimming of the instrument panel depending on lighting conditions. If I have my headlights on in the day, the dash will not dim until I go into a tunnel or underground lot.
  4. gsteirer
    gsteirer New Member
    Riverside, CA
    Exactly! Not DRL. For those of you that have not gotten to experience the wonderful benefits of automatic headlights, it is similar to automatic air conditioning...as in driving from California to New York and maintaining a perfect 72 degrees of cabin temperature...and thus you will never again touch the headlight switch from dawn to dusk and back. I have to have this feature to be completely happy with my new Prius!!! :)
    We must make this happen!
    - Greg
  5. naterprius
    naterprius Senior Member
    1,843
    Okay, guys, this looks doable. I've checked all the pinouts on the headlight computer; it looks like we'll need the following:
    -the headlight switch (stalk) out of a Canadian Prius
    -the light sensor (goes on dash next to climate control light sensor)
    -some wiring and some pins
    I suspect that the spiral cable (which allows wiring to go through a turning steering wheel) already has all of the circuitry. Without this, it would be impossible to do this properly.
    This is likely about $300 in parts for a "maybe". I'm trying to figure out how to simulate the switches and sensor at the headlight computer to see if this can be done; this one might be late this summer at the rate I'm going on mods these days.
    Nate
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Yes Nate, I thought that too. However, how would you enable it in the body ECU? It doesn't appear as an option in the THHT according to Rick.
    If we CAN get it to work though, then we may be able to get the fogs to work as DRL.
    And as for the stalk, I would just as well add a switch on the dash.
    Now if we can get the specs on the light sensor, then we could build our own. Then maybe the DRL/Auto option will show up in the THHT.
    But, as supposedly was done for the alarm, there may be an undocumented disabling wire.
  7. naterprius
    1,843
    Dan, the EWD clearly shows the circuit for the Auto headlights. My guess is the Body ECU doesn't run different software for US and Canada.
    Grounding pin 18 of connector B5 (19 pin) may provide automatic lights; on the other hand it may throw code B1244. (Malfunction in Light Control Sensor).
    The diagnostic manual only mentions that the sensor emits a signal waveform; no mention of whether the body ECU turns the lights on or off when it sees this waveform nor whether the trigger is when the waveform is absent or below/ above a threshold.
    On a side note, it looks like DRL's could be totally controlled using pin 2 of connector B7 (26 pin) to ground a relay which goes to either the high beams (on non-HID models) or the fog lights (on HID models).
    This would of course require activation in the body ECU with the handheld tester.
    Nate
  8. gsteirer
    gsteirer New Member
    Riverside, CA
    What is more practical...building your own circuit or modifying the ECU? It seems to me that a circuit could be built to utilize the dimmer on the dash and to intercept the headlamp switch on the steering column. Using any old photoelectric sensor, we could build a circuit to trip the headlamps and dim the dash and it would stay pretty clean. Although not as elegant as the ECU mod. I just have no ammunition in that area because I have yet to locate schematics. What do you think?
    - Greg
  9. gsteirer
    gsteirer New Member
    Riverside, CA
    Also, is it difficult to get parts...like the sensor from a Canadian Prius? How would one go about procuring this part, or could we use one from another Toyota vehicle?
    - Greg
  10. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    If you are looking for schematics, you may like to check this out.
    Automatic headlight switch
    Nate, I wonder pin 18 of connector B5 has any similarities to the pin 2 (TRIG) of the 555 Timer in the above circuit?
    Vincent
  11. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Or for DRL to the fog lights how about:
    Use auto headlight circuit above plus a line FROM the parking lights(to sense when there're on) combined into inverters and a AND gate to drive a relay to the FOG lights. Thus when the parking lights are off and the auto headlight circuit is off the fog lights(DRL) will be on.
  12. DanMan32
    3,799
    27
    Tampa Bay, FL
    I didn't realize the light sensor emitted a waveform. I just checked the repair manual, I am not seeing a waveform from the sensor. Where did you see it Nate?
    Again, according to Rick, the DRL/Auto option doesn't display on the THHT.
  13. gaulfinger
    gaulfinger New Member
    65
    Memphis, TN
    I'm so glad to find this thread! I got my Prius on Tuesday and already miss the DRLs from my last car (and the Auto headlights from my wife's). I hope you guys have great success working this out. For the entrepreneurial types, please know there are folks like me out there who would be willing to pay for such a kit, especially if it uses factory parts from other markets (like Canada).
    Thanks!
    Gary
  14. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Nate:
    Geez that sounds like a giant PITA!
    I'll never again take for granted the DRL and auto headlamps on my Prius. When the salesguy gave me the "orientation tour" of my Prius, he carefully pointed out the Auto setting of the headlight switch.
    I rotated it to Auto and it has never moved since.
    Though if you can figure out an easy way to perform this mod, good for you.
    Jay
  15. naterprius
    1,843
    It seems the biggest problem will be figuring out what the part numbers are for the pins in the Body ECU connectors. Toyota's out of date wiring harness repair manual doesn't list these connectors, so I don't know how to look up the part numbers for the pins. I keep thinking Toyota will release an updated Wiring Harness Repair Manual but don't hold your breath...
    Maybe Rick can help figure this out?
    The other option is to extract an adjacent pin and try to match it up with the pictures the Wiring Harness Repair Manual. (Tedious and uncertain).
    Nate
  16. vincent1449p
    894
    332
    Singapore
    I think your suggestion is workable. To reduce chip count, you can also use a single NOR gate.
    For those without fog lights and if your headlights are non-HID, I think it is possible to reconfigure the above 555 Timer as an Astable Multivibrator. The output can be duty-cycle controlled to get your desired brightness. This way, you get DRL when it is bright and headlights fully on when it is dark.
    I guess it would make this mod much easier if any owner that has the DRL module can provide some details on the waveforms at the light sensor and the headlights.
  17. naterprius
    1,843
    There is no DRL module. The body ECU handles the DRL and AUTO headlight function. The USA car has the same components as the Canada Car, except the light sensor.
    Therefore, it seems all we may need is the light sensor and activation with the scan tool (although this option is reported as being absent in the scan tool menu; very strange since it's mentioned in the repair manual). Also, we will need a switch that can ground the AUTO pin on the body ECU.
    Nate
  18. DanMan32
    3,799
    27
    Tampa Bay, FL
    I think I was thinking of the DRL relay, which the wiring diagram shows as a box, rather than a relay. Also, as you mentioned, the sensor shows as a box with 3 connections to body ECU. Body ECU may be looking for sensor impedance before it shows DRL/Auto features in THHT. That, or US THHT doesn't have code to implement it.
    There could also be an undocumented 'enable' or 'disable' link like some have said there is for the alarm.
    Anyone in Canada take some voltage readings fron the sensor, or from pins 14,15,16 on B6?
  19. rickasmith98
    rickasmith98 New Member
    Winterville, North Carolina
    If you got to this thread and haven't seen the thread posted by PROBLEMCHILD, please look at that. He found an aftermarket kit from DEI called the Nite Lite System that automatically operates the headlights with a photocell. I had it installed on my 2005 prius and it is SWEET because I really missed that feature.
