Backup Camera for Prius 2
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mypolardog98, Apr 16, 2014.
  1. Mypolardog98
    Mypolardog98 New Member
    Anyone has done this. I want one on my car. I saw some units on ebay that goes for about $130-ish. And another member here by the name, 06D, who sells it too.
    question: Is it a hard DIY project?
    Do I have to buy specific camera and the kit? What do you guys recommend? thx
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,460
    92
    I viewed the camera kits on ebay, but then ended up buying one from a vendor on Amazon.
    I used this video as a guideline:
    The video is pretty accurate and complete enough. The silicone spray really helps with stuffing the wires through the rubber boot on the hatch, and the nylon tools (the guy is using them int he video) are a good thing to invest in.
    Factory Connect Camera System for 2012-2013 Toyota Models with 6.1" Screen
    Wilmar W80648 Composite Trim Removal Tool Set
    P.S. I just re-read the title of your post. My experience is for a Gen III Prius.
  3. Mypolardog98
    thank you. I have a gen 3 as well. did it take you long?
  4. Dylan Doxey
    1,389
    3,460
    92
    That youtube.com video makes it look like you can do it in half an hour. It took me several hours, because I was being very meticulous. Overall, I'd say it's a fairly easy thing to do. It's just a bit laborious routing all the wires.
    JesseJ likes this.
  5. chang50012
    chang50012 Junior Member
    16
    WA
    I got the camera kit from ebay and hire local shop to do it for me. They quoted for 2 hours. Base on the youtube video, it should be a doable job if you are handy around the car
  6. our1vue
    our1vue Member
    313
    58
    NY
    mypolardog98,
    Check the Audio and Electronics section. There is a sticky thread that shows/explains how to put in a rear view camera on a 2012 prius and have the picture display on the HU. Chang50012's kit is great for a plug and play solution
    (or if you want a shop to do the work). If you don't mind doing some soldering, running wires, etc, you can buy the pieces and put together your own kit.
  7. Mypolardog98
    Thanks guys. I think I might venture and buy the kit from say, Amazon. $150 sounds about right?
  8. Dylan Doxey
    1,389
    3,460
    92
    $139.99 with free shipping
  9. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    Will this work with the radios that don't have the navigation?
    #9 KeepitSimple, May 30, 2014
  10. Dylan Doxey
    1,389
    3,460
    92
    My car doesn't have navigation.
    The description just says "
    2012-2013 Toyota Models with 6.1" Screen." I think you're fine if you meet that requirement.
  11. our1vue
    our1vue Member
    313
    58
    NY
    Dylan Doxey,
    Does the amazon kit have a 3.3 or a 6.5V camera ? I've been going nuts trying to find this thread so I could as this question. If it is a 6.5V
    camera, I think I'll add a link to it in the sticky thread. Chang50012's ebay kit came with a 6.5V camera that
    eliminated the need for the voltage regulator.
    #11 our1vue, May 30, 2014
  12. KeepitSimple
    KeepitSimple Member
    128
    If you get the 6.5 v camera then that's more or less all you need. Save your $150 and get the $40 eBay camera and if need be the $7 voltage regulator.
