Balance at the cell low voltage limit
Discussion in 'Prius PHEV Plug-In Modifications' started by dan2l, Jan 22, 2010.
  1. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Everyone,
    I have now run my 2005 with balanced at the bottom and capacity matched buddy pairs for another month. I have not needed to do any other balancing and everything is still working well.
    This is now 4 months or so with no balancers connected and no problems. This system is working very well with no user intervention.
    Thanks,
    Dan
  2. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello Everyone,
    It has now been another 10 weeks and everything is still good. The system has run with no balancing.
    But, I am an engineer and so I could not let it be without twiddling with something. So I finally interrupted this process.
    The charger was set to turn off at 55.6v. The newer charger in my other car with the BMS16C balancer charged up to 58.2v and I had a second newer charger. So, I started working with the newer charger going to a higher charge level. Then I got some alarms. So then I started trying to balance manually to make this work. Then I made a few mistakes and corrected them. Finally I decided that the BMS16C was doing a better job than I was doing manually. So I temporarily hooked up the BMS16C.
    Anyway, This system is still very well balanced. But, I can not get it as good as my other car. What I learned is that this older system has the older MottCells that are just cells. That is they do not have any overcharge protection. The other car has the new cells with overcharge protection and the BMS16C. The March 2001 to July 2001 system are configured this way and each of these 3 components(charger,cells,and balancer) are designed to work together. Generally you should not mix Old and New versions of these items.
    So the end result for the subject of this thread is that you do not want to "balance at the bottom" if you have any of the following
    1. Mottcells with overcharge protection.
    2. Any balancer, either DB8s or a BMS16C
    3. CellLogs that do not have the 8 cell power draw fix.
    Additionally you need to be very carefull using the newer charger with "balance at the bottom".
    Thanks,
    Dan
  3. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Hi Dan –
    Some good info here, but I have an additional comment about your conclusions. I just finished adding an additional 2KWh to my original 2KWh system. I charged up the original cells to top where the BMS-16 shut off the charger. I removed those cells and made buddy cells out of the old 16 cells pairing the highest with the lowest as has been previously described in PC. That was probably in one of your previous threads. Next, I made buddies out of the new cells and installed them as cells 9-16 in the new 4KWh system. These cells were fully charged by Enginer. I used the Enginer charger to complete the charging process. To my surprise, when the BMS 16 shut down the charger in the new 4KWh system, the original cells in 1-8 were considerably under charged compared to the new cells. I drove the Prius to get to shut down by the BMS-16 and observed that the old cells were causing the system to shut down early. (no surprise here!)
    I used a variable voltage power supply to add charge to the original 16 cells. The power supply has both voltage and current limiting. The current limiter and will only allow 4 amps to be drawn at 27 volts. The 1 hour of charging brought the old cells up closer to the new cells. It is difficult to tell how well balanced the cells are because after the power supply is removed, the cells will sag back to a lower voltage than when the charger is on. After using up the charge by driving the Prius until the red light on the dash came on, I found that the old cells were still shutting down the system. This time I added only 45 minutes of charge not wanting to make these higher than the new cells. So, I find myself doing manual balancing even with the BMS-16. I’m uncertain as to why the original cells were so much lower. However, slowly adding charge seems to be working to even out the bottom voltage of the old cells after the red Enginer dashboard light comes on.
    Paul
  4. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Paul,
    What are your old cells? Thundersky? Mottcell before 0912...? Mottcell after 0912...?
    When you matched 16 cells pairing the highest with the lowest...
    How did you measure the highest? Voltage or charge level will not work to measure cappacity.
    Thanks,
    Dan Lander
  5. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hello everyone,
    So, I have driven this car and charged a couple of times after removing the BMS16C. It is charging better, so the work I did trying to balance at the top with the BMS16C did help.
    Before, my highest peak at the end of charge was 3.95v. Now that highest peak is about 3.8v. So those high cells are pulled down a little.
    I still have not driven long enough to pull the cells down to see how it is doing at the bottom.
    Thanks,
    Dan Lander
  6. pwp1943
    51
    Boston
    2013 Prius Plug-in
    All cells, both new and old, are Mottcell pre 09/12/10. I used the voltage as read from the BMS-16 to make the pairing decisions. I have no means of measuring actual capacity, but I didn't realize that voltage and capacity aren't related. I will keep adding charge in small amounts to the old cells until I am satisfied with the balance between the old cells and new cells. Then will let the BMS-16 do its job. Perhaps the next version of the BMS will take care of this type of problem by doing the balancing automatically.
    The added capacilty of 2KWh is really great. My round trip commute is so short (13 miles) that I only need to charge every other day unless I make a long trip somewhere.
    Cheers,
    Paul
  7. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Paul,
    I think you are not understanding. I did not ask about pre 9/12/10. The lot code is printed on every cell. it is in a format 090913022 or 091229034 or 100315001. What is that lot code for your new cells and what is it for your old cells.
    Thanks,
    Dan Lander
  8. pwp1943
    51
    Boston
    2013 Prius Plug-in
    Dan -
    Here are the numbers. 16 cells at 100202005 and 16 at 100302005. This took a while to get to you since I've been on a business trip during our recent PC conversations. I got back late Sat. night and could not get to the battery pack which was in the airport parking lot.
    BTW, on Sunday I did another day charging at the bottm to equalize the cells and I am still not happy with all of them. However, I am now happy with 12 of the 16 buddy pairs, which is up from 8. I think I will start to balance at the top for a while. I'm still not clear on which method is the better, but all 16 cell pairs will be balanced when I'm done with this!!!
    Thanks for your interest, as you can tell I am new at this.
    Paul
  9. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Paul,
    These cells are all new MottCells with overcharge protection. They work well with the BMS16C balancer.
    12 of 16 is the best that you will be able to hold over time. This does give you 100% of your battery capacity.
    If you want more information you could go to the Enginer user forum.
    By the way, you are not "at the bottom" as those terms are used in this thread. Balancing at the bottom means fully discharging all cells and matching there voltages exactly at around 2.7v. This is a very risky process that should only be done by experts who have done a lot of research. I personally would never do it again. What you are doing is "Balancing at the top".
    Thanks,
    Dan
  10. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    I agree with Dan on the balance at the bottom warning. It is a rather tedious process and very dangerous if not monitored closely. I had to balance 64 cells in my 8kWh pack and that took quite some time at 10 amps. Fortunately I have not had to do that process since Feb this year and after about 150 cycles I am still within 0.010V margin between my quad buddy cells.
    I am about to get my converter upgrade and BMS16C so I will be experimenting with the new BMS later. I may just keep it there for now and leave my setup alone after I install the 5000W converter.
  11. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Chan,
    If you got your cells before February you do not have overcharge protection. Your cells will not work well with the BMS16C. I strongly recommend that you do not install the BMS16C.
    Thanks,
    Dan
  12. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Thanks Dan. I have an extra string of 16 cells of the motto batteries i purchased from Jack as a emergency replacement. I will run some test to see how they work with the BMS16C since I have an extra converter in the short term. I was planning to test in my Hybrid Altima to see how the MPG would be affected. Just need an extra charger to create another system.
