bluetooth problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by suprat04r, Oct 12, 2012.
  1. suprat04r
    suprat04r Junior Member
    85
    las vegas
    Hi recently i got a new phone and the bluetooth cant sync.. The area where it shows the signal strength is zero.. How can you turn it back on so my phone can sync?
  2. Malcolm338
    Malcolm338 Junior Member
    27
    Carlisle uk
    The signal strength is what is on you phone after connection not the blue tooth.
  3. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I have an HTC EVO and I have to do a battery pull every week or two because the bluetooth on the phone needs a reboot.
  4. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    Try deleting the connection in both the phone and the car. Then set up the Bluetooth again and pair up.
    This usually works on a connection that has gone bad.
