California's Water Crisis. Why?
Discussion in 'Environmental Discussion' started by F8L, Jul 28, 2008.
  1. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Your salad must have come from Siberia then... or maybe Alaska. :p
    My garden is doing fine in the heat. It looks like we'll break 100 for the next 5 days or more. Yuck. The 90's were bad enough. July wasn't too bad, I didn't think that August would be worse. D'oh!
  2. tripp
    4,717
    79
    Denver, CO
    Everton are in a rude shock when they come to town for a friendly on Sunday. 77 is considered "hot" in northern england. One of the blogs I read mentioned that Newcastle and Doncaster played in "extreme heat"... 77 degrees. :rolleyes:
    Now if I could only talk the wife into moving.... :D
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I do not know the number for that off the top of my head but I did read that lettuce farmers in the Salinas Valley area were testing out new combination drip-fertilization systems or "fertigation" if you will. They found that apply fertilizer through drip systems can save approx. 100lbs of fertilizer per acre vs. normal sprayed applications. Obviously the drip irrigation systems are much more efficient than sprayers or flooding as well. Interestingly, similar studies done during this time found that adding more fertilizer did not affect crop production and that in some case there was enough available nitrogen and phosphorus to maintain 1-2 crops without any additional fertilizer applications before soil nutrients became "unbalanced". IE we are putting too much fertilizer in our crops. Have not many organizations been saying this for decades?
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Which plays back into the idea of increasing city densities and demanding a stop to urban sprawl... Then we have the ability to create efficient mass transit again. Funny how this works. Some would call this solving for pattern, where one solution fixes many problems. :)
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    Composting works well. Another option I wonder about is the marine head. On our sailboat we use a manual head that uses almost zero flush water - just enough to clean the bowl, and the amount is controlled by the operator. I suppose there wouldn't be enough flush water to work with conventional house plumbing, but it still makes you wonder if we couldn't use something like that in a house. With that head, four people can go for a week and not fill up a 55 gallon holding tank.
    Tom
  6. qbee42
    18,058
    3,077
    Northern Michigan
    I going to post this just to annoy those of you who live in dry areas. Where I live you have to pump water out of your pool or it will overflow from the rainfall. :p
    On the other hand, we freeze our butts off in the winter.
    Tom
  7. Fraser
    Fraser New Member
    667
    Navarre, Florida
    A lot of effort here on various ways to reduce water use. Why not channel that energy into endorsing something productive, like desalinization projects? There is one in the Tampa area, although I don't know its current status -- it had a lot of startup problems. Desalinization plants are commonly used in the Mideast. Seems like California could benefit from such plants.
  8. tripp
    4,717
    79
    Denver, CO
    I suspect that we'll be seeing lots of desalination plants on the coasts. Phoenix, for example, will pay out the nose for desalinated water from CA or the GofC.
  9. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I've heard there are places with abundant rainfall and little snow, green all year round...but then again, it's probably easier to import water than sunshine. :rolleyes:
  10. b2j2
    b2j2 Member
    46
    Edgecomb, Maine
    Sacramento: in addition to the claim that it owns the water by right of first theft, I understand that the city charter prohibits metering. The argument is also that the water is only being borrowed from the river and then returned via sewers (per practice in many other areas of the country).
    In Southern California a significant waste is from over-watering of high water-use landscaping, in some areas contributing to a high water tables causing its own problems (the ground water is unfortunately non-potable in the area I'm most familiar with).
    Obvious solution: require insistent newcomers to intern in Sacramento with the California Depopulation Commission, "CalDePop" (first described by Matt Weinstock of the old LA Daily News). CalDePop publicizes the many reasons not to live in California, emphasizing prevention (tourists are welcome, bring money, now go home), but also extolling the relative merits of other states.
    Naturally I, as a second generation Californian, would be exempt from any mandatory expulsion. I am now here in New England for three reasons: research (mostly in Boston) as to the origin of some of the bad driving of newcomers to California, as an ambassador of CalDePop, and Mainers don't (yet) disparage Californians like Oregonians do.
    I am finding strong support for a "MaineDePop". A current local controversy is the bottling of much water as "spring" water, some local claiming that extraction should be valued at the retail price (more than gasoline!), never mind that much of it otherwise ends up in the ocean. We get about 42 inches of precipitation per year, four times or so the Southern California average.
  11. Godiva
    Godiva AmeriKan Citizen
    10,339
    They can't move here if there's no place to live.
    That's why I say stop building new developments and tear down the foreclosures.
  12. Testm0nkey
    Testm0nkey New Member
    44
    Houston, TX
    Texas is having issues with all the Californians flooding out of the state and coming here (and some people say bringing california problems with them).
    I lived in Colorado when locals got up in arms about the same thing
    Stay where you are just work at finding a solution! =)
  13. Godiva
    10,339
    It's those out of state immigrants driving the Californians out.
    Maybe we should secede and then tighten up our policies. No more transplanted midwesterners or New Englanders looking for sunshine and mild weather.
    Tell everyone about the earthquakes!
  14. Fraser
    Fraser New Member
    667
    Navarre, Florida
    Boulder, Colo., well-known in Colorado as the Peoples Republic of Boulder, tried that some decades ago. Put a legal fence around the town and environs, wouldn't allow newcomers, period. The economy turned so sour the city had to revoke that. Colorado Springs, much more conservative, tried a similar tack by not allowing new natural gas taps. Economy busted so badly it barely returned to a healthy state. So go ahead and push fencing off a town or a state. But don't complain when businesses pull up stakes and you can't get parts for your Cool Black Prius or have to pay double or triple for them because there's no competition, or the only food you can find is grown in the valley because the state won't allow imports.
  15. pdoege
    pdoege New Member
    Orlando, FL
    Desalination plants require power, power requires cooling stacks, cooling stacks require water. So there is a bit of cycle there. California has had power issues in the past.
    If you come to rely on a desalinization plant , and you can't power it, then things are going to get really bad.
    It might be better to just conserve in the first place.
    Peter
  16. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Let's face it. If Florida can take it's very generous water resources and waste those to a point of having to install a desal plant, then anywhere can be overexploited (and is).
    Sad but true.....only economic solutions have a hope of working with the present US population.
  17. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    I never have to add water to my pool. Ocassionally I have to take some out after a storm.
    You can have my pool water when you pry it from my moist dead fingers.
  18. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    Starbucks. They use way too much water. Let's outlaw them.
  19. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    And pets. They drink water. Let's outlaw cats and dogs. Fish, gotta go.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thank you for providing serious responses to this thread.
    I believe you are right but this must be in combination with careful regulation. People responding out of rediclous concerns for their "rights to own a pool" will be hit with an economic hammer if they choose to pursue such ventures. No one has to outlaw a pool or lavish landscaping. Just make it not economicaly viable for the majority of the population by forcing them to pay the true costs of water. if farmers, ranchers, and industry must pay a higher price for water (under new regulation) then so should the moron who feels it is his right to water the street. Prices for goods will rise in response to water pricing and I do not feel it is ethical to allow selfish folk to waste water when everyone else must bear the economic reprocussions of someone elses wasteful lifestyle. This same arguement can be used for many things in life like emissions output as well but that is for another thread. In the end, you should be forced to pay for the damage you cause but since this country is more concerned with rights and non-accountability I doubt we will reach that point. :(
    This form of economic stimulous also shifts the market towards more sustainable pathways.
