Can I Skip These 2 Steps in CV/Axle Replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert John, Aug 23, 2026 at 12:28 PM.
  1. Robert John
    Robert John Junior Member
    65
    Montreal, QC
    I have to replace the RHS CV/axle assembly on my 2008 Gen 2. The Prius shop manual removes the speed sensor & tie rod end. But in videos I've watched, nobody does that - they just remove the 30mm axle hub nut and 17mm nuts & bolt on the suspension arm - then the hub assembly swings out & off of the axle spline. Removing the speed sensor & tie rod end is additional work that appears to be unnecessary (i.e. if it isn't broken, don't mess with it ;-) Am I missing something here?
    Thanks!
  2. Dennis Brown
    Dennis Brown Junior Member
    42
    Baltimore County
    Three Touring
    I've replace the bearing and never removed the tie rod. I did remove the speed sensor because it was in my way due to how I was removing the bearing. Mine was so corroded in the case I had to use a different method for removal.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,358
    987
    Monument, Colorado USA
    In my 2021 Prius, I just replaced my front driver's side axle and only had to remove the speed sensor and then free up the ball joint on the bottom (two 17mm nuts and a bolt) then pop it off there so I could move it slightly to the side in order to slide the axle out.
    One tip I learned trying to pop-off that pesky thing was to get my longest screw driver with my 5-pound hammer to persuade it to pop off. (And I'm thankful they have notches where you can do that to) But even with that she wouldn't budge so my friend suggested I rotate the other tire 1/2 a turn so I tried that and then she popped free after just two hits.....PHEW.
    Inspecting the leaking axle, the leak was from the seal on the large part of the inside boot was leaking....wasn't any tears in the boots....which is odd (I've never heard of a Toyota doing that)
